What’s the best way to attach picture moulding to 75 year plaster? I’ll be bidding this next week and want to have some idea of what I may be getting into. Thanks for any help.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Its no different then attching it to drywall really. NAil into the studs with 6b finish nails. The only difference may be to drill pilot holes first so as not to crack the plaster. I've worked in a real lot of old homes with plaster walls and plaster moldings. Even spent quite a bit of time recreating the existing plaster moldings where walls had to be removed. Just cut the existing plaster molding flush and make a profile onto a piece of metal....cut it out .put a handle on it and put up your structolite/plaster and use the formed knife to create the shape. I charged $75 a foot with a one foot minimum. Great money in that.
Good luck and be well
Andy
It's not who's right, it's who's left ~ http://CLIFFORDRENOVATIONS.COM
Thanks Andy. All you guys are great. How do I get rid of the none and get my name up there?
Click on your current name, (none), in the grey area at the top of this post.
In the java box that pops up, choose "My Prefs".
Now, scroll down until you see "Nickname".
Whatever you type in that box will become the name that is seen at the top of your posts.
Whattaya mean, I can't be three people at once ???!!?
If this picture rail is really going to be used to hang things from, do be sure to find and hit the studs.
-- J.S.
I was taught to put down a line of tape (permanent, like clear Scotch Brand or "box tape"). It seems to prevent the plaster from cracking/shattering. Now I use double-sided tape, which even holds up the molding while you carefully nail it: predrilling is an option.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
You hand nailing or shotting a gun. I've had no problems using the trim gun as I would do normally. Olny thing different for me........harder time finding the studs thru plaster. I don't care what the stud finder says......Deep Scan don't do it!
I go back to the old tried and true....knock and drill. Nail at window and door trimmers......look for electrival boxes....usually one side or the other.
Find the ceiling joists too.
If you are hand nailing........predrilling helps. All this depends on the condition the plaster is in. I've seen 25 year young stuff ready to spall if ya breath on it...and 125 year old stuff strong enough and thich enough to hold a finish nail on it's own. And that's what we did......with a helper....run a small bead of liquid nails on the top and bottom of the back......stick and nail off. Just gotta make sure no squeeze thru comes out and ruins everything. Use 2 1/2 finish nails that at least grab the lath every now and again....and it's not going anywhere for a lifetime. Jeff * Jeff J. Buck/ Buck Construction/ Pittsburgh, PA *
2nd Generation Buck Const, 3rd generation Craftsman
Lee Valley Tools sells a nail spinner which attaches to an drill and drives finishing nails without cracking the plaster. Works and is cheap.
http://www.leevalley.com/wood/page.asp?SID=&ccurrency=2&page=32273&category=1,180,42334
Paul
The nail spinner is great for hard woods, although a trim nailer will shoot clean through the wood and plaster without cracks. I retrimmed the dining room with the nail spinner and the living room with a nailer. The time savings with the nailer was several hours for similar sized rooms....that's not a mistake, it's rustic
Thanks Jeff. A great help. I'll be shooting with a 16ga finish gun. I haven't seen the job yet, but now I have some kind of idea. A lttle different than drywall! Oh, my name's Randy. Didn't know the nickname was used as a heading.
Thanks Phil. How thick is the double sided tape you use?
I've used 3M "Scotch" 665 - it comes in 1/2", 3/4" and 1" wide in big rolls (I think they're 33m, a little over 100'). It's quite a thin film and the adhesive is permanent.
3M also make a "removeable" double-sided tape that you can use to test positions of chair rails, picture rails, etc. and it won't pull the paint off if you move it..
Phill Giles
Unionville, Ontario
That double-sided tape idea is great. I was using my wife to hold up the other end of the trim when I was doing my house. When I walked over to hand her the gun to tack her end, she would pull away and wince. ...that's not a mistake, it's rustic
Thanks for the follow up. Good solution when a extra set of hands aren't around.
