attaching trex to concrete
mick_meyers | Posted in Construction Techniques on April 7, 2015 07:29am
I’m building a deck and have concrete steps which I’ll need to attach trex to.  It’s only the top step or landing about 3 foot square. The trex will lie on top of the landing but will also be attached to 4X8 treated beams.  I’m thinking construction adhesive.  thoughts anyone?
mick
  1. calvin | Apr 07, 2015 09:40pm | #1
    Mick
    If you've thought this out and it's the only way, I'd use PLPremium as the adhesive, it's tenacious stuff.
    clean the hell out of the concrete, no paint if you can.
    no squiggle, blobs every 6".
    Don't walk on it till cured.
  2. mick_meyers | Apr 09, 2015 11:17am | #2
    what's your thoughts on concrete screws or fasteners?  I was trying to stay away from these because the rest of the decking will have the non-visible screws.
    mick
      Mike_Mahan | Apr 09, 2015 01:48pm | #3
      Hidden fasteners
      There are hidden fasteners that screw down. I don't see why you couldn't use these with concrete screws.
    2. calvin | Apr 09, 2015 01:57pm | #4
      Mick
      the heads of tap cons will be too big for conventional hidden plugs, but you could certainly make your own with a 3/8 or 1/2" plug cutter.
      or
      find those conventional plugs and deck screw combos(fastenmaster?) and use a plastic anchor in the concrete.
      either with PLPremium should hold them good.
    3. DanH | Apr 09, 2015 04:42pm | #5
      You could certainly drive some sort of fastener into the concrete, leaving them proud by a half inch or so, then drill matching holes in the back of the Trex and glue in place.
  3. gbaune | Apr 13, 2015 12:10pm | #6
    Hidden Fastener
    Here is a hidden decking clip, can be screwed to the concrete exactly the same as the joists.  The clip is made from marine-grade aluminum and can be used for wood and composite decking.  The screw is stainless steel.
    1. DanH | Apr 13, 2015 01:03pm | #7
      Won't work real well for steps, though.
      1. gbaune | Apr 13, 2015 01:22pm | #8
        Landing
        Should work REAL WELL for the landing that the original poster asked about.
  4. mick_meyers | Apr 16, 2015 12:41am | #9
    thanks for all the great suggestions
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
