On our new construction fireplace, we have a 4″ X 62″thick piece of white pine to be our mantle over man-made stone fireplace (stone wall extends up 9′). I’d like it to stick out 4″. Question is how to attach it- our contractor suggests using a wood bracket that you would see from underneath when sitting on a nearby chair. Ideally, I don’t want to see aything besides just the pine mantle and am wondering about alternate ways to attach it without seeing anything. One idea I read about was to set into the stone a 2 x 4 that sticks out 3″, drill out a hole in back of the wood and press mantle into it. Any feedback or other ideas?
Trying to understand the question here a little bit. Might be a little dense so go with me on the this one. ... Typically I attach a nailer to the stone or brick using masonry screws and construction adheasive. I then make a mantle that will "wrap" around the nailer. You can make the mantle as a box with one side open then place on nailer board and nail or screw using trim screws. Did I hit the nail on the head on that response... Ha ha get it.. .nail on head> A little carpenter humor on that one.
Great carpenter humor! However... I see that I failed to say that the wood mantle is a solid old salvaged wood beam so can't "build" it around anything, I don't think. Or can I?
You could use that method by dadoing out the back of your beam with a router
Connie
KC's method is a good one and here's a thread on the very same thing.
Its easier for me to post this link then type a good answer to you.
62095.1
you couldn't have done that before I spent 10 minutes typing it up?
It took me 20 minutes to find the damn thing!
I did almost exactly what you are wanting to do about 6 months ago.
The only difference was it was with a brick fireplace surround.
I had a 4"x8"x ~7' piece of rough cedar
I installed it using 5/8" all thread doweled into the cedar beam and into the mortar joints between two courses of brick. I drilled the holes in the cedar slightly undersized and set the all-thread in epoxy. Drilling coresponding holes in the fireplace surround the same dia. as the all thread and injected epoxy into the holes before sliding the mantle home.
I did install small corbels for insurance however after I had the mantle on the wall I feel I could have omitted them with no problem.
To make sure the holes all lined up, I clamped a piece of 1x4 to the cedar beam prior to drilling the holes and then used the 1x4 as a template to ensure everything would line up. Make sure to drill the holes perfectly plumb and you shouldn't have a problem.
I did end up having to "beat" the mantle in using a small sledge and a block over the cedar, you may want to have a scrap of 2x and the sledge handy.
I think a similiar approach would work in your instance depending on how smooth the rock face is.
Great idea- thanks!
Have another question for you- how did that mantle look sticking out 8"? This is another thing I am pondering, how far out to have the 4" thick beam protrude and yet still having it look "right". I was thinking it looks best to match the thickness of the beam which means ours should not protrude out beyong 4" even though I'd like it to really be 5" or so.
Without a photo, I can't know the scale of your F/P Mantle relationship, but 4" seems a little slender to me; mantles usually beg to have things set upon them and deeper is good (up to a point, of course).
Might check the local codes to see how far the mantle can come out from the wall with relation to how close it is to the firebox. I can't remember specific codes but it doesn't sound like your mantle will be a problem.
I sent PETA steaks for Christmas.
The rule of thumb I learned is that for every inch of projection of the mantle, it also has to be that many inches above the fire box. Did I say that right?? Ex: 6" projection of a wood mantle means the bottom surface must be at least 6" above the fire box or nearest metal portion of a sealed unit. That's not to say that's really enough, but the companies that make sealed gas units go by that rule.Bruce
Between the mountains and the desert ...
That is exactly what I was thinking... I just couldn't remember until you just mentioned it...Measure once > cut once > get board stretcher....
Personaly I think it looked fine projecting out 8" I wouldn't go any less then 6" because you or the home owner are going to want to set pictures, vases, etc. on it.
We used to use rebar instead of allthread, but the process was identical. One suggestion I'd make, though, is to mount the mantel and steel in the block before you run the stone up (assuming you haven't gotten that far already). That way, the stone can be cut to the mantel, eliminating the long process of scribing the mantel to the stone.
drill in a couple all-thread rods and use epoxy
Drill corresponding holes through the mantle, tighten them down and bung the ends
