I had a brilliant thought the other day. (O.K., so that’s a matter of opinion)
Does anyone make a pre-fab attic access panel ? Like something that would slip up into a 22 1/2″ by 24″ hole between 2 trusses. It could have an insulated door on it, and a gasket to seal against air leakage. Maybe have a little trim already applied to it so you could just fasten it into place and walk away. Would probably be better than most of the things I’ve cobbled together.
Whaddaya think?
I had a brilliant thought the other day. (O.K., so that's a matter of opinion)
Does anyone make a pre-fab attic access panel ? Like something that would slip up into a 22 1/2" by 24" hole between 2 trusses. It could have an insulated door on it, and a gasket to seal against air leakage. Maybe have a little trim already applied to it so you could just fasten it into place and walk away. Would probably be better than most of the things I've cobbled together.
Whaddaya think?
