Attic Challenge
renosteinke | Posted in Construction Techniques on October 26, 2012 01:41am
Gable roof, low pitch, slither (rather than crawl) down the center. Outer reaches blocked by framing. Either very little insulation – or none in many places. Access also blocked by ductwork.
How would you insulate the topof this house?
PS: Editors …. Having post rejected by SPAM filter.
  1. calvin | Oct 26, 2012 06:04pm | #1
    Reno
    Cut up the roof and do it from above.........
    or
    cut out some ceiling to gain access for your head and the hose, dam that opening on either side and let it fly.
    Work your way over and/or back and do it again.  You could attempt holes in the ceiling
    Sorry, best I can do.
  2. JimB | Oct 26, 2012 06:21pm | #2
    Are there gable vents that could be removed to make accesssing
    some parts of the attic easier?
  3. DanH | Oct 26, 2012 06:39pm | #3
    Remind us of the climate in Reno.  How low is "low pitch"?  3/12?  2/12?  Rough dimensions?  Stick or truss?
  4. Shep | Oct 26, 2012 08:47pm | #4
    You could hire some little kid to crawl around in the attic, if it weren't for those darn child labor laws. <G>
  5. florida | Oct 27, 2012 10:59am | #5
    I've got 5 little cottages that had the same problem. We cut a scuttle in one and tried to blow cells from the scuttle but it didn't work. We took a piece of roof out and went in through the top. that was a piece of cake. Very quick even including the roof repairs.
    xxPaulCPxx | Oct 27, 2012 07:43pm | #6
    Make it easy by doing foam sheets over the deck.
