Attic Recovery
McDesign | Posted in Photo Gallery on January 12, 2007 02:19am
New thread here, now that I’ve moved inside after the “Triumph of the Geometry” thread http://forums.taunton.com/tp-breaktime/messages?msg=82119.1 got me up and into the residence.  There, I built a temporary access stair and dormer cut into the attic
Clients have engaged me to repair / refloor / rewall / re-HVAC / reinsulate the existing attic rooms, so the kids(s) can live safely in there while larger additions & renovations happen downstairs.  Existing rooms were built on 2×6 ceiling joists below; rock was installed, taped once and painted probably 30 years ago.
Basically, I am moving East to West; installing new joists, new subfloor, new knee walls, and replacing the live knob-and-tube wiring (!).  Hip (roof) planes will be strapped for flatness before DW.
But – having some trouble with a neighbor –  “Police Came” http://forums.taunton.com/tp-breaktime/messages?msg=83450.1 and “Got a Stop Work Order” http://forums.taunton.com/tp-breaktime/messages?msg=84020.1
In our county, this is the type of work, an “internal repair”, where the form, fit, or function has not changed, and no permanant exterior changes are made to the fabric of the house, that has never required a permit.  The exterior stair (all screwed together) will be dis-assembled; the ACQ has already been spoken for; the dormer will be enclosed in a permitted addition this summer.
Attic wiring had three circuits; one for outlets, one for lighting, one for downstairs overheads.  They still exist, and have the same function, but with new wire – traditionally done here with no permit.
Our town no longer issues building permits; the town P&Z board looks over a single sheet called a “development permit”, for setbacks, mostly, and the contractor or homeowner takes this to the county for a building permit if one is required.  In this case, I am in a dispute over the requirement for this “development permit”.  My reading of the statute, and eight years of working here does not indicate one is required.  P&Z is being pushed by a nosy neighbor; noone is saying I need a “building” permit from the county.
I, and my clients, are too much Libertarian in outlook to jump through regulatory hoops just because some “might” apply.  Clients are being great; have given me the go ahead to push back as hard as I want.
Anyway, here are some interior during photos:
Here I’ve cut through the wall to get to the dormer –
Old attic storage room looking back into main room –
Side of main room removed; looking into repaired area to the east –
Repaired area –
More wall removal and temp. bracing in main room
Forrest – fighting the good fight
Edited 1/11/2007 6:20 pm by McDesign
Edited 1/11/2007 6:21 pm by McDesign
Edited 1/11/2007 6:27 pm by McDesign
    jonblakemore | Jan 12, 2007 03:27am | #1
    Is the addition permit complete and in hand?
    Jon Blakemore
  2. stevent1 | Jan 12, 2007 03:28am | #2
    Forrest,
    Looks good. Are you doing the electrical?
    Can you add modern wiring downstream from ball and knob? (Our house is full of it and we are slowly replacing as renovations occur/require. First thing we did was a 400 amp service).
    Looking forward to "Attic Recovery"
    Chuck S.
      McDesign | Jan 12, 2007 03:49am | #3
      <Can you add modern wiring downstream from ball and knob?>
      No.  As I understand it, you have to start at or work back to the panel.  In this case, when a modern panel was put in in the '70s, 12-2 w/g romex was run to feed these existing knob and tube circuits hidden in the walls and insulation and between the original and dropped ceilings.  Since I'm pulling up the attic floors, I'm replacing that junk back to the '70s Romex.
      1. stevent1 | Jan 12, 2007 04:14am | #4
        Forrest,
        Same deal here in Columbus. 1920's Bungalo. Heart pine floors. Third owner. Slowly rewiring everything.
      xxPaulCPxx | Jan 17, 2007 11:28am | #13
      Good lord, what are you powering with a 400 amp service?Rebuilding my home in Cypress, CA
      Also a CRX fanatic!
  3. theslateman | Jan 16, 2007 01:08am | #5
    Forrest,
    Does the chimney stay? Looks loke it needs some work where an old thimble used to be.  Just wondering.   Glad to see more of your work.
    Walter
      McDesign | Jan 16, 2007 02:03am | #6
      Chimneys will stay - I've got a place called "Chimney Mischief" coming out from Atlanta to quote on rebuilding / repairing.  They did all our house work 15 years ago, and it's still the best I've seen.
      Worked some more today - Here you can see I've shortened one door another 1-1/2" - that old back wall had sunk nearly 3" relative to the center wall of the house.
      Chimney will be repaired, rough plastered, and left exposed in the attic room
      Here is my scheme for re-powering the 1st-floor ceiling wiring.  The single box hooks to the old wire; it will be replaced as I get to that section - no access now.
      Another pic of the storage room to-be
      Looking forward onto the existing floor that I'm slowly re-joisting and replacing
      Tiny doorway and stair - why I had to build the outside staircase
      Downstairs view of same door.  The stairway was originally from a back porch; I closed it in for the previous owner some years ago.
      These cabinets I had built to enclose the stair -
      Edited 1/15/2007 6:05 pm by McDesign
      Edited 1/15/2007 6:07 pm by McDesign
      Edited 1/15/2007 6:08 pm by McDesign
      Edited 1/15/2007 6:09 pm by McDesign
      Edited 1/15/2007 6:10 pm by McDesign
      Edited 1/15/2007 6:11 pm by McDesign
      1. stevent1 | Jan 16, 2007 02:50am | #7
        Forrest,
        Looking good.
        Will you rebuild the stairs to the attic? When the kids are teens this new space will become a hang out.
        Nice cabs below stairs for the previous owner.
        Chuck S.
        Still rockin. Dry throat.live, work, build, ...better with wood
          McDesign | Jan 16, 2007 02:55am | #8
          Stairs will be rebuilt and widened significantly; and slid toward the rear of the house 6-8', to come up from the as-yet-unbuilt family room addition.
          Above the family room, and adjoining thru the new French doors, will be the two girls' bedrooms.  The big room will be their common room.
          Assuming the police don't come back!
          McDesign | Jan 17, 2007 01:34am | #9
          More work screwing and gluing today.  Finished out around my rear dormer - some of the old joists dropped 3" in 15'-6" - see how much trimmed the bottoms of the doors are!  The new floor is "laser-flat".  Triple 2x8 joists under the little wing walls supporting the dormer sides
          Also did some demo around the existing front-facing gable.  Going to replace that center "window" (really a hinged piece of Plexiglass) with a real circle-top to match the exterior trim
          Edited 1/16/2007 5:34 pm by McDesign
          Edited 1/16/2007 5:35 pm by McDesign
          Edited 1/16/2007 5:37 pm by McDesign
          1. stevent1 | Jan 17, 2007 03:34am | #10
            Looks like good progress. Did you calibrate the laser level? Mine was off and had a surveyer buddy do it with his transit.
            Are you going to build the new circular transom(window top)?
            Chuck S.live, work, build, ...better with wood
            McDesign | Jan 17, 2007 04:09am | #11
            calibration - I just set it up either end of about 80' - seemed to agree.
            I might build the circle top - got that book reprint "Circular Work in Carpentry and Joinery" - itchin' to use it!
            draftguy | Jan 17, 2007 06:09pm | #15
            you're making me feel guilty . . . have an attic just like that that i keep putting off :Pquestion: are you sistering new joists to beef up the structure, or to level the floor (or both)?
            Edited 1/17/2007 10:10 am ET by draftguy
            McDesign | Jan 17, 2007 08:08pm | #16
            Levelling and support both.  Old ceiling joists are SYP true 2x6s; 24" OC; spanning 15'6.  Some sag as much as 3" in the middle, plus the tops of the downstairs walls are not level.  Old attic room floor was T&G 1x8, 1/4" ply, and cheap carpet
            I'm putting in new 2x8s, 12" OC, as well as tying every other one to the sagged joist, so those doubled ones are probably 10" deep in the middle.  Decided on no blocking, because of the 12" OC.
            Darned satisfying project, to carve straight level space where there was crap before!  having to work my way across, to support the roof as I go - it has some 22' long 2x4 rafters!
            Client is pleased.
            Edit - original plaster ceilings (11') are in bad shape; lowered drywall ceiling was put in at 9', 20-30 years ago.  Eventually, I'll go room-by-room and redo the original ceilings and moldings
            Edited 1/17/2007 12:09 pm by McDesign
          5. MikeK | Jan 17, 2007 08:31pm | #17
            Forest,I'm a homeowner with a similar old house attic, 2x6 floor joists. Obviously replacing the joists is not a DIY project. I'd be interested in knowing (ballpark) what the cost of this project is.We also have a tight attic stairway, 22". Did you have to replace the stairway in order to meet code? Thanks for a great post.
            McDesign | Jan 18, 2007 03:04am | #23
            Thanks for the encouragement.  I'm not sure it's not a DIY project.  I've done several of these, and developed a pretty good sequence that is not too bad to do.  I just sister the old joists (screws), and add some more joists and good subfloor.  Getting materials (sheet goods, especially) in and out is always difficult, which is why on this job I required that I build an exterior stair and French doors first.
            Usually, old joists are notched where they sit on the top plates, so a new joist with no notches usually clears all the plaster squeeze-out and mess.  I use lots of screws and glue, and my new impact driver!
            With a bath and a few skylights and HVAC and inexpensive finishes, figure about $45-50 per square foot.  Lots of labor in that, obviously.
            Stairway we were able to ignore, because the house had a "finished" room up there.  I'm just gutting and re-building the space - it was already in use.  Eventually, the house will get a new stair.
          7. MikeK | Jan 18, 2007 08:16am | #32
            <<<Stairway we were able to ignore, because the house had a "finished" room up there. I'm just gutting and re-building the space - it was already in use. Eventually, the house will get a new stair.>>>>Are you telling me that if an attic is finished already that you do not need a building permit to sister in new joists?? And the narrow stairway is grandfathered in even though it does not meet code??
          8. User avater
            McDesign | Jan 18, 2007 03:17pm | #33
            Yes.  Here, we only have to update house to meet code if you increase the value of it more than 50%.
  4. JohnT8 | Jan 17, 2007 08:23am | #12
    Looks like someone had a goodly battle with mud daubers up there.
    "Holding on to anger is like grasping a hot coal with the intent of throwing it at someone else; you are the one getting burned."
    -- Buddha
      McDesign | Jan 17, 2007 02:49pm | #14
      It's mud dauber heaven!  I've got to scrape the side of every joist before I sister it.  With that and the squirrels and mice and rats, it's Wild Kingdom.
      Edited 1/17/2007 6:49 am by McDesign
      1. JohnT8 | Jan 18, 2007 01:17am | #18
        I'd much rather deal with 'em in January than July.
        I've been trying to talk my BIL and sister into finishing their attic for about 3 years now.  They've got a 12-12 roof, so probably have around 1200 sq ft up there that would be useable.  It has two full sized windows on either end and a small dormer window on the west side.  Regular staircase to get up there ("U" shaped with a landing) with a door at the bottom.
        Just a waste not to utilize that space.  Maybe I'll direct them to this thread.
        "Holding on to anger is like grasping a hot coal with the intent of throwing it at someone else; you are the one getting burned."-- Buddha
        1. Hackinatit | Jan 18, 2007 01:31am | #19
          Not so fast, t8...
          That space would also require HVAC, Electrical and, while you're at it, Bathroom.
          Carrying costs include insurance, taxes (higher) and cost per cubic foot to keep temperate.
          Future cost may be that the neighborhood won't support that size house and the addition won't help much in resale value.
          PLUS...
          They may not need it.
          Attic space is valuable as storage.... where ya gonna put your stuff after it's finished out?
          I like the idea of useful space, but make sure of the use. I could easily fill up our 1500' garage/basement with something other than cars (read tools), but I insist that the garage space must be used by cars/truck.Troy Sprout
          Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it."-- Thomas Sowell
          1. JohnT8 | Jan 18, 2007 02:27am | #20
            Previous owner put a sub-panel up there, so electrical wouldn't be hard.  A 1/2 BA would be easy to include, and a full ba with some work.   Of course you'd be tapping into the cast iron soil pipe...which is always a good time.
            For HVAC, I think I'd rather setup an independant system for the attic space.  The 1st & 2nd floors have radiators that can barely keep up.  BIL blew some insulation into the walls, which helped, but I'm still not impressed with the performance.  I think a very well insulated attic could be climate controlled much easier on its own.
            I doubt they would advertise to the tax man that they added 1200 sq ft.  Especially since they just had their full blown inspection a couple months ago (guy toured the whole house with his tape measure and clip board).  Insurance might go up, but I'm not sure what kind of jump you're talking to go from 3k-ish sq ft to 4200-ish.
            Assuming a separate system for the attic, it might decrease the load on the main system because currently the attic only has insulation between the floor joists and the door leading to the attic isn't an insulated door (so they're currently losing a lot of heat to the attic).  But yes, the overall cost would be higher.
            Right now they are about middling in their area.  There are some smaller bungalows, but also some houses larger than theirs.  They have a big, brick Italianate right across the street from them.
            I sometimes suspect that my sister and mom could live in a 500 sq ft house.... just as long as it had 2500sq ft of closet attached to it ;)
            I think the initial plan had been to put the ceiling in around 8-9' and make storage above that.  Off the top of my head, I don't know what that would translate to...maybe 4-600 sq ft-ish?  Currently they are only using a portion on the attic because the previous owner pulled up the t&G floor to jam fiberglass batts between the floor joists.  He had only gotten about 1/4 of the floor back down prior to selling.
            Plus they have a full basement.  Plus each BR has a walk in closet.  And besides which, I think you could give my sister 10k sq ft of storage space and 5-10 years later she would still complain about "not having anyplace to store stuff."
            But it isn't my call or my $$.  :)
          McDesign | Jan 18, 2007 02:53am | #21
          Did some more deom and two trips to the dump today; got lumber for tomorrow before the sleet tonight.  This section has 2x6 24" OC spanning nearly 17', so huge sag.  I'm going with 2x8s on 8" centers (don't want to raise the floor too much to mess up the stair)
          Also replaced this vent
          With this window knocked together from scrap and a piece of old glass
          Edited 1/17/2007 6:53 pm by McDesign
          Edited 1/17/2007 6:54 pm by McDesign
          Edited 1/17/2007 6:56 pm by McDesign
          1. stevent1 | Jan 18, 2007 02:56am | #22
            Forrest,
            Your picks did not show up. You can imbed them without editting your post.
            Chuck S.
            Just like magic. They are there. You can hit preview, open pic, copy, back, revise and paste. YOU taught me how.
            BTW looking good up there. Ready for the Ice?
            Chuck S
            Edited 1/17/2007 7:00 pm ET by stevent1
            McDesign | Jan 18, 2007 03:06am | #24
            Kids just got this new computer with win XP, and if I go to "preview", it won't let me back.  Office computer, 95SE, still works fine, but there's food and wine in here and it's warm.
          3. stevent1 | Jan 18, 2007 03:13am | #25
            Warmth, food, and wine. Sounds like a song.
            That gable end with the new window looks good. Is that your work?
            McDesign | Jan 18, 2007 04:12am | #28
            No - I think the gable end is original - 'teens, I believe.  I will be duplicating that twice on the addition, so we'll see how mine turns out.
            As an additional note, this house was the setting for episode #88 (I think) of  In The Heat of the Night - trying to find some pix from the previous owner.  Some bits in other episodes as well, and some movies.
            FatRoman | Jan 18, 2007 03:30am | #26
            Forrest,Nice work there on that window. That's the kind of design spirit I was talking about in the other thread.Question for you about your sistering method. Do you find the screws and glue to work better than nails? I've got a project coming up that's going to require some joist bolstering and was led to the impressions that: screws are a no-no because they risk having the heads snap off under stress, and the added benefit of the glue wasn't worth the effort. What's your opinion on that?Best,
            SteveTua res agitur, paries cum proximus ardet ~ Horace
            McDesign | Jan 18, 2007 04:08am | #27
            Structurally, I use the #9 x 3-1/2" Grip-Rite deck screws (about $80 for 25# at HD), and I can't break them, even with my handy new Makita impact driver.  I did some fooling around where I screwed 2x4 blocks flat to some installed Advantech, and beat them laterally with a 8# sledge until the screws ripped out or the 2x4s split - never broke a screw, though I bent some.  I don't want to use nailing with old plaster hanging below - a nailgun shakes 'em less, but doesn't pull things together like hand nails (or screws).
            I can see where a glue like the Liquid Nails I use can creep, and thus not really help compared to a solidifying glue like resourcinol, but I feel like it helps fill voids between rough old wood and new wood.
            Same with gluing down Advantech to new joists with screws (#8 x 1-5/8") - kind of belt-and-suspenders, but it can't hurt, and is easy enough to do.
          7. User avater
            FatRoman | Jan 18, 2007 04:55am | #29
            Thanks, that makes sense to me. I don't have room to hand nail, but the screws might be a good call for the impact driver. At least until Piffin sees this and gives me a hard time for thinking about screws :)
            What do you think about a poly glue like Gorilla instead of the Liquid Nails?
            Oh, by the way, there was an article on celebrating Robert Burns in the paper today. One of the selections was Cock-a-Leekie Soup. Leeks and whisky, how bad could it be? http://www.washingtonpost.com/wp-dyn/content/article/2007/01/16/AR2007011600321.htmlTua res agitur, paries cum proximus ardet ~ Horace
          8. User avater
            McDesign | Jan 18, 2007 05:01am | #30
            I think officially the best glue is that kind you mix with water, that sets up hard as a rock.  Never used it, tho'.  I think PL Premium is polyU like gorilla, and expands, and is probably a lot easier to dispense (normal 10 oz tube).  haven't used it; some guys swear by it
            Forrest - I just like the smell of Liquid Nails.  oh - and Gorilla Glue makes me break out in a rash on my trunk and arms and legs and neck and face and stuff
          9. User avater
            FatRoman | Jan 18, 2007 05:19am | #31
            I'll give the PL a try. Count me among those who'd like to avoid a rash.Thanks for the info. Sorry for the hijack.Tua res agitur, paries cum proximus ardet ~ Horace
          10. User avater
            PeterJ | Jan 22, 2007 03:27am | #35
             I think PL Premium is polyU like gorilla, and expands.
            Quite different animals, although both are poly. I'm not a big fan of the foaming poly like Gorilla. PL Premium guns on a lot like any const. adhesive, no foaming, but dries pretty dogone ridgid and holds like crazy. I used it for first time recently to sister joists in saggy bath floor and was a little bit surprised at the ridigity...not rubbery at all. Seems like a perfect application.
            You might want to give it a squirt just to see what it's like. Only caution is the same as Gorilla...don't get it on ya unless you want to wear it for a while.PJ
          11. BillBrennen | Jan 22, 2007 05:32am | #36
            Forrest,You really ought to try the PL Premium. It has very low odor compared to the PL400 or the solvent-based Liquid Nails, which can make me woozy indoors. And it sticks much better. I did destructive tests of 2x4 short scraps glued to exterior brick back in 1991 when the Premium was pretty new, and those tests convinced me it is better. It also does not skin over quickly like the 400 can.If you get it on your skin, you can remove it if you get it before it cures. A bottle of rubbing alcohol and a rag or two in your pouch does the trick. Second rag is only if you are accident prone.Construction mastics are not true structural adhesives, but they do not need to be, either. In your application, the glue is helping to share loads, and keeping things squeak-free. It also lets each sister joist reinforce its partner against splitting, something the screws don't really do. The screws transmit the primary load and the glue helps everything work together. The screws won't creep under the load, so the glue isn't going anywhere either.Nice project. Keep the pictures coming.Bill
          12. unTreatedwood | Feb 14, 2007 10:05pm | #159
            I've come late to this thread, but I want to echo the PL Premium support. I started using it to assemble melamine cabinets when I couldn't locate the white melamine glue. Someone on this BT suggested it. I've used since for all sorts of applications, including some very elegant transome mirrors where the mirrors had to stay put with glue only! There is not enough acid in this PL Premium to eat through the silver backing and several years later, the mirrors still look great. I use PL premium whenever time is not issue, and it needs to stay put! Great stuff.BTW, I have switched to Sumo Glue from gorrilla glue...stronger by far and 1/2 the expansion. check it out!!"The nearest thing to eternal life we will ever see on this earth is a governmental program"  -Ronald Reagan
          13. Piffin | Jan 25, 2007 02:38pm | #63
            "At least until Piffin sees this"I'd use structural screws with PL premium for the ame thing here. Nails would loosen too much of the plaster below.
          14. User avater
            FatRoman | Jan 25, 2007 03:19pm | #65
            Thanks Piffin.No plaster here, only drywall. It's going to be screwed n' glued tomorrow.You have a preference on the Grip Rite vs. Deck Mate?Glad to see not even an innocuous comment like that gets by you :)Tua res agitur, paries cum proximus ardet ~ Horace
          15. Piffin | Jan 25, 2007 03:28pm | #66
            I use GRK screws - not familiar withthe others.Even with SR below, the banging with nails would give you pops in the surface to repair.
          16. User avater
            xxPaulCPxx | Jan 22, 2007 06:23am | #37
            I never had luck with the Grip Rites, using the 3" self drilling points.  The ones I was using were #8 though, not #9.  I broke probably 10% of them driving them in.
            I have had no problems with the "Phillips Deck Mate Square Driv" screws, in #8 3" and #9 3.5", though neither have the #17 self drilling point.
            With those #9 3.5" screws, its easy to overdrive deep into the wood.  Until I got used to it, I could bury those screws at least an inch into the wood - Douglas Fir, BTW.  Never broke off a head.
            I could also tear a 16ga. Simpson strap of them - again, the screw would not break!
            Unfortunatly, McFeely's just stopped making their round washer head 2 7/8 Promax screws - they had only 1.5" of thread.  They are perfect for pulling together 2x and will NOT SPLIT WOOD, like regular flathead types do.  I just bought the last 500 thay had.  Other star drive companies make similar screws though, I haven't beat them up yet though.Rebuilding my home in Cypress, CA
            Also a CRX fanatic!
    davidhawks | Jan 22, 2007 02:45am | #34
    Enjoying this thread VERY much.  Type of project that is right up my alley.
    Heading to "Triumph" now.  Working backwards, oh well.
      McDesign | Jan 22, 2007 07:53pm | #38
      Watching your project, too.
      Here's a catchup here at lunch (job is across the street!)
      Got this done Saturday - had to go with 8" OC, because of 16'5 clear span and 2x8s.
      Pulled up the old flooring and junk from the last of the main room
      Got the sistering of the last four joists done; now I'll go back and fill in after lunch - gotta put some transverse ductwork in under the floor as well.
      Here you can see the centers of the old 2x6 joist are 2-3 inches down - they are together with the new ones at the plates!
      Edited 1/22/2007 11:53 am by McDesign
      Edited 1/22/2007 11:54 am by McDesign
      Edited 1/22/2007 11:56 am by McDesign
        davidhawks | Jan 22, 2007 09:53pm | #39
        I'm amazed (though I shouldn't be) that the house only had 24" O.C. 2x6 to start with.  I guess that space was never intended to be occupied by more that Christmas ornaments.
        Pre or Postwar construction???  You might have already said.
        How much wiring did you have to address prior to your sister act??
        Looks like you've given them a floor with some integrity now.  Keep up the good work.
        1/2" ice on everything here in the mtns. today,  guess I'll try to teach myself some Sketchup so I can design my next project.
          McDesign | Jan 23, 2007 01:59am | #41
          1920's construction, I think.  Very typical for around here.  The stairway up there is original, so I assume it was always used as an upstairs room.  Interestingly, it came off the back porch, not from inside the house.  Students at the college down the street (became Emory University) would board with townspeople, and many old house had this exterior-only access.
          Did some more after lunch - rest of the joists in, jiggered my spacing a little to make two chases for 8" R6 Flex to get HVAC to the far side of the attic.
          Temporary props wedged in, down to new joists and subfloor; fragment of old knee wall to be removed.
          Floor and stud knee wall in new location
          Hopefully get this end done tomorrow.
          Edited 1/22/2007 6:03 pm by McDesign
          Edited 1/22/2007 6:04 pm by McDesign
          Edited 1/22/2007 6:05 pm by McDesign
          1. stevent1 | Jan 23, 2007 01:33pm | #42
            Forrest,
            That's a lot of good looking work. Many houses of that era in the south have underbuilt roof systems. No snow load issues.
            What type of bearing will be below your new knee walls?
            McDesign | Jan 23, 2007 02:37pm | #43
            Bearing under the knee walls in the main room is double or triple joists, depending on the place.  The side sections, with the 7' roof peak, are just a toeplate on Advantech, transverse over the new joists (12" OC)
      2. theslateman | Jan 23, 2007 12:55am | #40
        Is this a real thread or a figment of my imagination?
          McDesign | Jan 24, 2007 02:12am | #44
          I checked - today was real.
          Finished joists and subfloor in little bay / niche area.  Client wanted to push the knee walls back, and build in windowseat storage on either side, 20" deep out to the 6' wide entry opening and new window trim.
          Cleared the area for new double 16' LVL beam for transverse wall (reaches 13' at the peak).  This upstairs room is about 20" wider on each side than the downstairs room (where all the pretty new joists end).  Need to go to the dump with that pile; too muddy today.
          Installed and braced the beam.  It's deeper than it needs to be; this end gets notched down to floor level for a doorway.
          Forrest - got a date with planning and zoning tonight . . .
          Edited 1/23/2007 6:13 pm by McDesign
          Edited 1/23/2007 6:17 pm by McDesign
          1. stevent1 | Jan 24, 2007 05:09am | #45
            Forrest,Nice!Building from the top down.Chuck S.
            McDesign | Jan 24, 2007 05:45am | #46
            <Building from the top down.>
            You know it - in a plaster house, I'd always rather work that way!
            Forrest - scored at P&Z tonight
          3. JohnT8 | Jan 24, 2007 06:22am | #47
            How'd the P&Z go?
          4. theslateman | Jan 24, 2007 12:32pm | #48
            Forrest,
            I get tired just looking at all the work you are doing by yourself!
            Nice looking work- what great usable space that will be when you're done.
            Keep those pictures coming.
            Walter
          5. seeyou | Jan 24, 2007 01:07pm | #49
            >>>>>>>>>I get tired just looking at all the work you are doing by yourself!Yeah, looking thru this thread, I keep making calculations about how many trips up and down those stairs with a load.http://logancustomcopper.com
            http://grantlogan.net/
            It's like the whole world's walking pretty and you can't find no room to move. - the Boss
            I married my cousin in Arkansas - I married two more when I got to Utah. - the Gourds
          6. theslateman | Jan 24, 2007 01:52pm | #50
            Grant,
            That was my thought exactly. All that material had to come up those stairs   WOW!
            Thank God for Reiman-Georger power ladders for us roofers
          7. seeyou | Jan 24, 2007 04:04pm | #51
            >>>>>Thank God for Reiman-Georger power ladders for us roofersI sold mine 10 years ago. It was never very useful for the type of work I get. Now, telehandlers and boomlifts are another story. If I was Forrest, I'd have rented a lift rather than built the stairs. http://logancustomcopper.com
          8. User avater
            Sphere | Jan 24, 2007 04:50pm | #52
            "If I was Forrest, I'd have rented a lift rather than built the stairs. "
            Or Hose A and Hose B..
            The secret to a long life is knowing when its time to go.  M. Shocked
          9. theslateman | Jan 24, 2007 08:43pm | #53
            Grant,
            I hear ya,but for my work they are priceless.
            Looking to get an 80' boom next week to scope out twin steeples on a Church here.
            Will post pics of that when we get them.
            Walter
          10. Brian | Feb 09, 2007 02:07am | #145
            Slateman - in college I painted steeples and replaced slate using a 100' retired ladder (fire) truck - that was my first summer building, and I got over my fear of heights within a few weeks.
            I wish I had some pictures - that was cool work.  The local paper would come out whenever we set up a job.
             Treat every person you meet like you will know them the rest of your life - you just might!
          11. JohnT8 | Feb 09, 2007 07:52am | #146
            You could probably go to the local library and check out their archives to find the old pics.
            http://cgi.ebay.com/ebaymotors/Fire-truck-ladder_W0QQitemZ140083933889QQihZ004QQcategoryZ6737QQssPageNameZWDVWQQrdZ1QQcmdZViewItemjt8
            "One of the fondest expressions around is that we can't be the world's policeman. But guess who gets called when suddenly someone needs a cop." -- Colin Powell
          12. User avater
            McDesign | Feb 10, 2007 01:47am | #147
            Couldn't help but notice there's a FIRETRUCK in my thread!  You know, what starts with "F", ends in "K", and rhymes with "duck"?
            Gonna get me busted . . .
            Anyway, not to pull your focus.  No pix today.  Wiring (with the electrician); replacing lots of old first floor overhead feeds; adding some switch legs for some o'heads that didn't have 'em.
            Planned the attic circuitry; decided to add a 125-Amp sub panel in the new laundry room.  I need 14 positions, and didn't want to fish down 8-9 home runs, and that main panel will have to move when the bedroom it's in becomes a bathroom.
            Now I just need a 1/0 sub-feed set (4 conductors, I know, I know) to a single big breaker in the main panel.  Got a GE; got it mounted in a wall more than 6' high.
            Put (5) keyless nekkid bulbs and a couple of switches in the unfinished areas of the attic (through the two short doorways I framed yesterday).
            Got a new pressure gage; pressurized the water supplies, no bleed down in the first 4 hours - let it sit all weekend.
            Forrest - fixin' our dishwasher tonight, gonna' get the car back on the road this weekend.  Gotta babysit now while DW goes to self-defense class . . .
          13. User avater
            McDesign | Feb 13, 2007 01:32am | #148
            Supplies and DWV held pressure all weekend; screwed and glued down the last subfloor.
            The bathroom ceiling will have a small flat at the 10'6 level, just large enough to enclose the exhaust fan and the DWV vent, and make the penetrations to the rear roof plane.
            New sub panel goes here - in the upstairs utility / laundry room.  Yes, I took out the ground / neutral jumper bar!
            Edited 2/12/2007 5:33 pm by McDesign
            Edited 2/12/2007 5:34 pm by McDesign
          14. vintage1 | Feb 13, 2007 05:00pm | #149
            Forrest,
            I have been following this thread and would like to add my compliments to your work.  Nice job.
            Slight hijack.
            Since you work alone, (and get way more done in a day than I can) I wondered if you could share any tricks or tips for installing t&g sub-floor solo?  Is there anything that you do to make it go faster?
            I have a project coming up that will be ~400 sqft. of subfloor and it seems like it would be a little tedious by myself.  I have decked several new houses before but we always had 1 guy gluing, 1 guy swinging sheets and 1 guy screwing.
            If you have a better way, I would love to hear it.
          15. User avater
            McDesign | Feb 13, 2007 08:28pm | #150
            <installing t&g sub-floor solo>
            Here's a quickie diagram and a 6-step program (twice as easy as a 12-step program).
            For whacking it, all I really use is an 18" piece of 2x6, end wise (it's harder), and a 2# hammer.  I put it on top of of the tongue, and it bears against the ~1/4" of the sheet above the tongue.  Keep it square, and don't kill it with the hammer.  If it doesn't go in well, there is some other problem.  I've made grooved pices, but they seem to split.
            Make sure the groove is clear (I drag a speed square along it), and the tongue is undamaged - trim it with a knife if needed.
            The glue  (make sure it doesn't extend beyond the sheet; less clean-up later) makes the sheet slide pretty well - I usually have one foot on the new sheet, pushing it along the right way.
            I definitely make sure the piece will fit the first time - no fun picking up the gluey mess by myself!
            Forrest - hoping I'm helping
            Edited 2/13/2007 12:29 pm by McDesign
          16. JohnT8 | Feb 13, 2007 10:12pm | #151
            You're doing renovation, so I thought rule #1 was to trim it to length so that it would fall on the joist?
            I was going to use a sledge and a block of wood for mine (getting into the groove), but  couldn't remember who I loaned my sledge to, so have been using a 4lbs hammer instead.
            Who ever borrowed my sledge, I WANT IT BACK.
          17. User avater
            McDesign | Feb 14, 2007 01:31am | #153
            Nah, I lay out the joists so I don't have to trim!
            Much . . .
            This is just to get the tongue and groove to engage solo.
          18. JohnT8 | Feb 14, 2007 07:16pm | #158
            I usually do screw no-glue, but this time around dieselpig talked me into adhesive & ring shanks (via the Hitachi coil framer) (more sq ft this time than I usually do).   So far I've liked it.  Seems like a nice solid floor.  I use the sacrificial 2x4 and 4lbs hammer to tap it into place and then pop a couple nails to hold it there.  If the joist doesn't line up on one of the printed lines, sometimes I'll laser the joist to give myself a nailing reference (takes about 10-20 seconds to get the laser line lined up).
            I'm slow at putting it down, but I'd be even slower if I was screwing it.  If you're screw & adhesive, you've probably got a rock solid floor.  jt8
          19. vintage1 | Feb 13, 2007 10:50pm | #152
            Forrest,
            Thanks for sharing and for taking the time to draw.  One question, why the screw in step 5?
          20. User avater
            McDesign | Feb 14, 2007 01:32am | #154
            The screw in #5 is just to quickly pin the sheet, so you don't get it half-screwed in and realize it shifted as you started!
            Forrest - done that
          21. vintage1 | Feb 14, 2007 01:41am | #155
            thanks
          22. mikeroop | Feb 14, 2007 03:38am | #156
            i do it similar to forrest but i fasten it at his #5 first and stand on previously nailed sheet at #1 and pick up slightly on the sheet and slam it home!! no sledge and much faster. just my 2 cents. don't want to step on any ones toes though
          23. vintage1 | Feb 14, 2007 03:18pm | #157
            thanks
          24. User avater
            McDesign | Feb 15, 2007 02:18am | #160
            Okay - two days of learning to strip.
            Kind of fun, once you get in the groove!
            Here you can see where the DWV vent sneaks out.  The vent fan duct will exit just to the right of that penetration (straight "down" in the picture)
            Edited 2/14/2007 6:20 pm by McDesign
            Edited 2/14/2007 6:22 pm by McDesign
          25. Hackinatit | Feb 15, 2007 02:57am | #161
            I love seein' the work, Forrest.
            Why did you use 1x instead of ripped 3/4 ply? Around here you can buy the AC ply MUCH cheaper than the yellow pine.
            BTW I think (don't know 'cause I ain't there) that I'd give up some height for a lower exit on that DWV so's it'd be less visible from the front facade.
            Notice how I mixed "Southern Drawl" and Latin in the same sentence... edumacated redneck I is.
            FWIW I use cleats and pony clamps on LONG pipe to draw decking together... ain't hit a sheet with a maul yet. ;-)Troy Sprout
          26. User avater
            McDesign | Feb 15, 2007 03:04am | #162
            <Why did you use 1x instead of ripped 3/4 ply?>
            Don't know - I'm a newby at this.  (20) 1x4x8's cost about $24 at HD today (that one bath / laundry room took 35 pieces) - hard to fault that price, and I think the YP is stiffer, maybe?
            That vent is on the back roof plane, but I will paint it gray, because it is visable (bright white) from the side
            Forrest - learnin'
          27. stevent1 | Feb 15, 2007 04:27am | #163
            Forrest,Looking good.
            I agree, 3/4" plywood rips would be "bouncy" to nail into, fine for screwing.What are you doing to reinforce the existing rafters since sheetrock and insulation is a lot of weight? Is the barrel vault still a go?Chuck Slive, work, build, ...better with wood
          28. User avater
            McDesign | Feb 15, 2007 04:37am | #164
            Dunno about the vault.  I'm thinking!  This room and the storage room on the other are easier - just sistering with 2x4s.
          29. stevent1 | Feb 15, 2007 04:52am | #165
            Forrest,I saw the 2x4's. How are you reinforcing the load at the ridge? Thank the heavens we don't have to deal with snow loads.Our house was also built in in the 20's and I figured 2-1/2 to 3 weeks to get the roof load and bearings to the foundation worked out.Chuck Slive, work, build, ...better with wood
          30. User avater
            McDesign | Feb 15, 2007 05:00am | #166
            In this room, as well as the storage to be ceilinged next, there's really only a foot or two of actual ridge - the rest are hip ridges.  I'm just ignoring the main ridge in the big room for now!
            Forrest - thinking
          31. User avater
            McDesign | Feb 18, 2007 02:27am | #167
            Did some last couple of days - got all the wiring completed for the old house; most of the new in.  Got the first (bath / laundry) skylight installed.  Met with my HVAC guy; he's got a plan, and we knmow where the ducts will go.  We're shooting for the install in a couple of weeks. 2-1/2 Ton Heat Pump; still pricing the different SEER choices.
            Edited 2/17/2007 6:28 pm by McDesign
            Edited 2/17/2007 6:29 pm by McDesign
          32. stevent1 | Feb 18, 2007 02:38am | #168
            Forrest,
            Nice work.
            Skylite looks like it will add a lot of light. Is it a Velux?
            I put 2 Velux in the loft of my shop that open/with screens.
          33. User avater
            McDesign | Feb 18, 2007 02:44am | #169
            Yes, Velux - all I'm comfortable with.  Love installing them with the EDL flashing kit.  I mounted that one flush with the wall; the DW goes smoothly up the wall into the DW receiver slot.
            The big room gets (3) 22x54" ones - all these are FS series; fixed/ventilated
          34. Hackinatit | Feb 18, 2007 03:27am | #170
            I've built more than a few industrial control panels, and I gotta say that the service box meets any I've seen built. I am impressed.
            BTW That's how they should ALL be assembled.Troy Sprout
          35. User avater
            McDesign | Feb 18, 2007 03:58am | #171
            Thank you!
            I really like wiring - probably too slow, but I'm confident in it.
            Forrest - I mean, the elctrician says this
          36. DonK | Feb 18, 2007 05:37am | #172
            Going back a few steps to your knee walls - I saw some verticals, under the beams. Did you put in short horizontal nailers at the top of the walls or use a different method for strength in that area? Curious why you didn't put horizontals all the way across, then knee walls under them.
            BTW - Can you send me some of the energy you've got. Mine's always missing.
            Don K.
            EJG Homes     Renovations - New Construction - Rentals
          37. User avater
            McDesign | Feb 18, 2007 06:14am | #173
            The rafters were just too inconsistant to put a plate under them.  Doing the studs individually meant I could at least start with a true, plumb knee wall.
            Forrest - just found out I don't have any ice cream for bedtime
          38. JohnT8 | Feb 23, 2007 10:02pm | #175
            What's going on here?  We're starting to get pic withdrawl.  Where's our pic fix?
            "The cynic is one who knows the price of everything and the value of nothing."  --Oscar Wilde
          39. User avater
            McDesign | Feb 23, 2007 10:51pm | #176
            Sorry man!  Back to work Monday; HVAC sub to get his stuff done.
            Family vacation this week - skiiing in NC.
            Kids loved it (3, 6, 9; first time), but geez, man, skiing -what a waste of money and time and energy for adults.
            Forrest - not seeing the point
          40. dedubya | Feb 24, 2007 03:48am | #177
            where did ya go?Boone or Blowing Rock if you went to Boone I paid for a lot of the new additions to Appalachian St. university- well I feel like I did anyway.
          41. User avater
            McDesign | Feb 24, 2007 04:09am | #178
            Went to Cattaloochee (Maggie Valley).  Super weather - 62 degrees Wednesday & Thursday afternoon - cooler and a bit rainy Tuesday.
            Kids never got cold (not used to snow, ya' know)
          42. Hackinatit | Feb 24, 2007 04:41am | #179
            Skiing is great, when you ain't waiting for someone to keep up. ;)Troy Sprout
          43. User avater
            McDesign | Feb 24, 2007 04:46am | #180
            Man, I never even strapped in.  Skiied once about twenty years ago at Keystone, and that week was fine.
            Don't see why I'd do it again.
            Forrest - making' stuff is ALL there is
          44. User avater
            McDesign | Feb 28, 2007 03:19am | #181
            Okay - catch-up pics.
            Finished last of re-wiring old K&T.  Each box cover has a diagram in Sharpie
            Floored in further attic area for HVAC air handler; CPVC coming up to HWH; PVC HWH pan drain going down - condensate drain will tie in, no doubt.  HVAC guy to decide where disconnect goes.
            Wing wall for stair
            Skinning both sides of the short wing with 3/4" makes it bomb-proof - hate wiggly half-walls.
            Furring and strapping the front bay - just starting tonight.
            HVAC starts tomorrow - 80 degrees up in there today!
            Edited 2/27/2007 7:20 pm by McDesign
            Edited 2/27/2007 7:21 pm by McDesign
            Edited 2/27/2007 7:22 pm by McDesign
            Edited 2/27/2007 7:24 pm by McDesign
          45. stevent1 | Feb 28, 2007 04:41am | #182
            Forrest,
            Looking good. Do you mastic the plywood to the wing wall?
            I sometimes carriage bolt the corners into the joist structure below before decking, similar to a newel post, for rigidity.
            Does this project require any MEPS inspections?
            Chuck S.
            Edited 2/27/2007 9:34 pm ET by stevent1
          46. User avater
            McDesign | Feb 28, 2007 04:58am | #183
            Some subfloor adhesive.  What's MEPS?  Mechanical, Electrical, Plumbing, Structural?
            Nah.
            This is off the radar 'cuz it's in the house.  Later additions will be normally permitted.
          47. User avater
            davidhawks | Feb 28, 2007 06:41am | #184
            Coming together nicely Forrest.  How much K&T did you leave connected, and do you just make your junctions in a box as usual or is there a special connector.
            David--full of dumb questions.Live in the solution, not the problem.
          48. User avater
            McDesign | Feb 28, 2007 02:16pm | #185
            No K&T left connected.  Ran Romex all thge way down into mew wall switches, receptacles, or into the ceiling light boxes.
            There actually are two pieces of old black - 2-conductor wire feeding the lights to the room made from the closed-in back porch, but that's probably '40s-'50s work.  Seems okay, just no ground.  I can't get to it to replace it, but that room will come off soon as part of the larger additions.
            All K&T is pulled out.  Don't know of a connector - does anyone?  I could see it being handy, but might be a liability.
          49. User avater
            McDesign | Mar 01, 2007 01:29am | #186
            More stuff today
            Straightening the old rafter planes - 3"of perpindicular; 2" out of level in 12'.
            Back side
            HVAC guys working - one usual guy was in jail . . .
            Front bay finished strapping
            Side finished strapping
            Edited 2/28/2007 5:29 pm by McDesign
            Edited 2/28/2007 5:30 pm by McDesign
            Edited 2/28/2007 5:31 pm by McDesign
          50. MikeK | Mar 01, 2007 07:41am | #187
            Forest,
            Thanks for taking the time to post all the photos - good stuff.  I'm a DIYer considering doing a similar attic conversion. I'm getting quite an education from your post. Looks like you get along well with the plumber and electrican :-)
            Please excuse my ignorance. I was wondering how you aligned the sistered rafters to be in one plane.  Are you stretching a string line(s) across? What is the process.
            Thanks,
            Mike K - Old house remodeler - Aurora, IL
          51. User avater
            McDesign | Mar 01, 2007 04:27pm | #188
            Thanks!
            Lets see - to align rafters, I establish my level "crease line" where the wall bends to the ceiling hip.  All rafters start there for that wall.  To establish the a ridge top intersection (like yesterday), I make a horizontal string line, once I establish each end by dropping a plumb line to the center line drawn on the floor.  Of course, then I make sure it's level.
            If the hip rafters go up to an as-yet undetermined point, I establish a story stick; like "at 78 inches in from the knee wall the bottom of the rafter is exactly 102-1/4" off the floor.
            I do all the complete rafter sisters first, then some strapping extended toward the corners, and eyeball along the mounted strap to project where it should mount on the extended end.
            Kind of finicky, my first time doing this, but as Mike Smith said "It's just so civilized" (said with pinky bent just so)
            Back to work - got to go around THREE HVAC guys today - AD's out of jail.
          52. User avater
            McDesign | Mar 02, 2007 03:07am | #189
            Here's more from today.
            Almost finished the strapping in the storage room - tedious but fun; strings and sighting.
            Air flow-wise, we needed to get air to both sides of the storage room, so we have this "moose crossing" over the dormer.
            But, I was able to turn it into a plus (a change order).  The dormer was already a couple of feet wider than planned, to line up over rafters, okay?  I boxed in the duct verticals, and added a shallow closet (with cabinet above) onto each side.  Client had wanted some small closets, so this was perfect.  Overhead will get a false beam down 4"; matched with a similar false beam at the intersection of the dormer shed roof with the main 10/12 roof - needed to hide some meat in there, anyway.
            Airhandler installed; just needs to be plumbed tomorrow - maybe even cranked up if time permits.
            HVAC decided we needed to overpressure this storage room (two 6" one one side, and one 8" supply on the other)
            Then vent it through the ceiling out into the main, vaulted room, where there are three distributed returns.
            Here, the supply for the front bay will be built into my windowseat cabinets (actually one bay to the left, to wash the outside wall)
            x
            Edited 3/1/2007 7:08 pm by McDesign
            Edited 3/1/2007 7:09 pm by McDesign
            Edited 3/1/2007 7:12 pm by McDesign
            Edited 3/1/2007 7:13 pm by McDesign
            Edited 3/1/2007 7:14 pm by McDesign
          53. User avater
            FatRoman | Mar 02, 2007 04:56am | #190
            Forrest that's coming along nicely.Question for you...you do the strapping/stripping so that the drywall isn't attached directly to the rafters, thus; it's not subject to the expansion/contraction of the roof and therefore shielding against the drywall seams opening up, yes?A very long winded way of saying strap = no crack :)Thanks,
          54. User avater
            McDesign | Mar 02, 2007 05:04am | #191
            I'm doing the strapping for two reasons - to create flat planes out of this really crooked and hilly roof, and to tie everything together before the DW tries to do it.  I guess the DW isn't really "isolated", but at least any point stresses are spread out by the screwed-on strapping.
            I'll use just 1/2" DW, and my finisher can do arrow straight joints if I get all the intersections right.
            Forrest - hopin' for no cracks, since it's across the street from my house!
          55. User avater
            McDesign | Mar 02, 2007 05:06am | #192
            Forgot that last pic of the front bay -
            Also notice how they make the rigid have a "dead" cushion of a couple of feet after the flex pull-offs.  Say this measureably increases airflow.  More work for them, so I guess it works!
            Edited 3/1/2007 9:08 pm by McDesign
          56. User avater
            davidhawks | Mar 02, 2007 06:45am | #193
            My guy said the same thing when he did my brother's house.  I stupidly asked if I could tap the end-cap in the trunk if I needed an extra 6" for the kitchen.  He said only if I wanted to kill the whole system.  I had always thought that the blower did all the work when actually it's pressure.Live in the solution, not the problem.
          57. User avater
            McDesign | Mar 03, 2007 12:19am | #194
            HVAC guys plumbed it, cranked it up, cleaned up, and were out of here by late lunch today.  All I need to do is install the stack of grills & registers when the DW and paint is finished.
            Can't say enough good about 'em.  2-1/2 days for a fairly ductwork-intensive job, all in the littles attic spaces around the three big rooms.  be nice to dry the DW mud with the air circulating.
          58. User avater
            ErnieK | Mar 03, 2007 02:24am | #195
            This is true...pressure is everything.  Been doing duct for 30 years and rarely saw a end cap tapped, that is until I checked out the one I currently own.
            Bozo put 2 - 6" taps in the cap.  Might as well just left the end cap off.
          59. User avater
            McDesign | Mar 06, 2007 02:40am | #196
            Good day today - got those HVAC guys out from underfoot!
            After some thinking, here's my sequence for the main roof.  I needed to get the skylights in (which meant cutting lots of purlins, and stiffness), and take out all the old bracing.  I decided to build temporary walls of 2x4x10s, resting UNDER each rafter, so I'd be free to sister either side as I needed.  Measured, got to depo, built my props, and removed all the old bracing before lunch.
            Looks like a church
            Now, up on top, I transferred my layout through, and removed the shingles wider than my RO.  Removed the old ventilator mushroom; scabbed in a piece of decking.
            Then cut out the ROs
            Then set the three skylights
            Then put on the self-stick underlayment all around
            Finished up left side, woven in with that wonderful Velux EDL flashing
            Finished up right side the same.  Piffin will notice I haven't yet swept my roof membrane up the 10/12 pitch - that's next, now that I know where the skylights are.
            Still need to address the awful chimney flashing on all three chimneys - lots o' leaks
            Here's the inside - will need to move that rafter (I centered the skylight)
            All 4 visible with no walls DWed
            From the side yard - (4) skylights, vent fan hood, and DWV vent.  Pretty well hidden from most views.
            All done by 6!
            Forrest - a happy kind of tired
            Edited 3/5/2007 6:41 pm by McDesign
            Edited 3/5/2007 6:42 pm by McDesign
            Edited 3/5/2007 6:43 pm by McDesign
            Edited 3/5/2007 6:44 pm by McDesign
            Edited 3/5/2007 6:45 pm by McDesign
            Edited 3/5/2007 6:46 pm by McDesign
            Edited 3/5/2007 6:47 pm by McDesign
            Edited 3/5/2007 6:52 pm by McDesign
          60. Marc | Mar 06, 2007 05:10am | #197
            Forrest,
            Is that chimney as crooked on the inside as it looks in the photo?
            Marc
          61. User avater
            McDesign | Mar 06, 2007 05:58am | #198
            Yes!  Most chimneys here are corbelled over to penetrate the roof at at the ridge or center of a hip.  Looks kind of scary.
          62. Marc | Mar 06, 2007 02:03pm | #200
            First one I've seen. Thanks
          63. User avater
            davidhawks | Mar 06, 2007 07:25am | #199
            Wow, you had one he!!uva productive day.  Must be that lack of travel time.  You're right, that Velux flashing should be the model by which all flashings are made!Live in the solution, not the problem.
          64. User avater
            McDesign | Mar 08, 2007 02:18am | #201
            Another good day -
            String line to establish underside of ridge line; centered in room and 150" off the subfloor.
            New 2x8 SYP rafters just above line; intersect knee wall at 47" off subfloor.  Because the original ridge was not centered over the house, my ridge line is moved 2-1/2" toward the back of the house, which allows me to just run my rafters long and attach also to the other side.  Lots of space for insulation on that, the south, side - like 12"!
            Blocking around the "hanging" rafters
            Really warped old rafter that sat on the chimney
            Blocking and new joists around chimney
            West side of house front finished and strapped
            East side of front finished and strapped
            Still need to create the intersections with the front bay, and then do this on the back plane with all the sklights and the intersection with my shed dormer.
            My InsulWeb roll will be delivered Friday; wanna' get it right up!
            Edited 3/7/2007 6:19 pm by McDesign
            Edited 3/7/2007 6:20 pm by McDesign
            Edited 3/7/2007 6:21 pm by McDesign
            Edited 3/7/2007 6:24 pm by McDesign
          65. seeyou | Mar 08, 2007 02:24am | #202
            You gonna blow cellulose?http://logancustomcopper.com
          66. User avater
            McDesign | Mar 08, 2007 02:26am | #203
            I plan to blow JM "Spider"; chopped fiberglas, if I can convince the company I've used to do the Mooney/mesh thing.
          67. stevent1 | Mar 08, 2007 04:12am | #204
            Forrest,
            Looks good up there.
            Still in tornado clean-up mode in Columbus.
            That existing roof system is typical of construction in Georgia. No ridge board.
            Are you planning on any wind braces or rafter ties? How do you plan on keeping the outside walls from spreading with the additional weight of sheetrock and insulation?
          68. User avater
            McDesign | Mar 08, 2007 04:17am | #205
            Spreading, I'm confident that the new floor joists and new subfloor will act as a giant tension diaphram.  Also, the knee walls will help.  Also, the shed dormer in back and gable bay in front will help absorb thrust.  Also the shed-roofed porches that wrap the house will help absorb lateral thrust.
            Forrest - not rationalizing.  Really!
            ps - hope you had no tornado damage?
          69. stevent1 | Mar 09, 2007 06:04am | #211
            Forrest,
            No damage in our neighborhood but severe damage a mile North.
            The 2X8 SYP you added to the roof system is certainly an improvement on the existing. Probably outlast all of us.
            Keep up the good work and posts.
          70. User avater
            McDesign | Mar 09, 2007 02:40pm | #212
            Thanks - got your e-mail, but no newspaper link included - glad you're okay.  I was working in the attic last week with the HVAC guys when we got the tornado watch, and they decided I'd put so much wood up there it was safer than a basement.
            There's a '60s brick ranch a couple of miles from here that I remember my folks taking me to in 1972-ish to see the mostly intact roof sitting in some trees about 300 feet from the mostly intact house.
            I show the kids the house now, but it's just a normal house, anymore!
          71. MikeSmith | Mar 08, 2007 04:43am | #206
            just got  a new roll of InsulWeb from Regal....   $123 including UPS
            sure beats my local  $160...
             keep on keeping on... it's looking goodMike Smith Rhode Island : Design / Build / Repair / Restore
          72. User avater
            davidhawks | Mar 08, 2007 06:49am | #207
            That is a big day.  Man, you're killin that thing!  I don't envy the little task of tying all those "intersections" together though.  Way tedious, nearly impossible to be productive.  Iffn anybody can figger out how though, It'd be Forrest.Live in the solution, not the problem.
          73. User avater
            McDesign | Mar 08, 2007 03:07pm | #208
            Thanks - it comes and goes.  The first pic in that post, the only one dated 6 March, shows a string.  One day's work; mount a string line.  Next day, hang a bunch of wood.
            Forrest - DW says I need your abs!
          74. sharpblade | Mar 08, 2007 09:04pm | #209
            Great work Forrest, thanks for showing us. I'm particulary interested because I'll be finishing an attic project I started at my own house. Much smaller than yours. Still busy emptying it from 7 years of storage stuff.
            I have no experience using a string line on such a long dimension. Wouldn't there be a bow in the line from its own weight, preventing it from being 100% straight? Negligeable? I was thinking about rigging up a lazer line to do same.
            thanks again.
            charles
          75. User avater
            McDesign | Mar 09, 2007 01:51am | #210
            Nah - just pull it really tight.  It won't sag more than the thickness of a snapped line.  Braided line will take quite a bit of tension.  My laser was gonna' be hard to set up there, and it was easy to hold the new rafters just above my line.
            Today, I used the fact that I put the top piece of strapping right on the line, so I could rest the back side rafters on it - much easier!
            Here's the way I built the headered opening "after the fact", and moved that one rafter across the middle skylight.
            Here you can see the criss-crossed new rafters - easy with no ridge board
            Here is the cool chimney view through one skylight.  Once the chimney is restored, it'll be gorgeous -
            Forrest - gotta finish ALL strapping tomorrow!  That'll be it for framing - FINALLY!
            Edited 3/8/2007 5:52 pm by McDesign
            Edited 3/8/2007 5:53 pm by McDesign
          76. User avater
            McDesign | Mar 10, 2007 01:35am | #213
            Almost finisged framing today - just a couple of intersections to do; just to bushed by 5:30 - had to clean up.
            Here's some extra tricky blocking so they ceiling planes can wrap the crooked old chimney
            Here's the nice and tight intersection with the other gable wall.  by dropping my ceiling planes, I hid the fact that my room is a few feet wider than the unhipped main ridge.
            Here's the final intersection with the shed dormer and all the blocking around the skylights to pick up the DW - this time it WILL fit in the darn slots, perfectly!
            Forrest - ready for the weekend!
            Edited 3/9/2007 5:36 pm by McDesign
            Edited 3/9/2007 5:37 pm by McDesign
          77. User avater
            McDesign | Mar 10, 2007 01:39am | #214
            Strapping info needed (notice i didn't call it "stripping"
            Do I need to "picture frame" block around skylight wells like this?
            Do I need to make a solid edge at the edge of the ceiling plane like this?
            I tried to engage you in a mind-meld today, but was unsuccessful . . .
            Forrest -did it anyway
            Edited 3/9/2007 5:39 pm by McDesign
            Edited 3/9/2007 5:40 pm by McDesign
          78. MikeSmith | Mar 10, 2007 03:59am | #215
            you don't NEED to do it...but i like to do it
            just like you don't NEED to make solid inside corners.. you can use metal drywall "clips" for your corners.... but  why ?
            i love furring... piffen loves furring.. and now you love furring  ... is this a national trend ?Mike Smith Rhode Island : Design / Build / Repair / Restore
          79. User avater
            McDesign | Mar 10, 2007 04:22am | #216
            Thank you, kind sir!
            To quote a John Turturro movie about a builder, "There's two ways to do this - the right way, and my way.  And they're both the same!"
            Forrest - feelin' like I need a little more blocking
          80. seeyou | Mar 10, 2007 05:05am | #217
            >>>>>"There's two ways to do this - the right way, and my way. And they're both the same!"Is that in "Box Full of Moonlight" or something like that?http://logancustomcopper.com
          81. User avater
            McDesign | Mar 10, 2007 05:08am | #218
            This one
            http://www.imdb.com/title/tt0104783/plotsummary
          82. stevent1 | Mar 10, 2007 05:10am | #219
            Forrest,
            Looks like you are rebuilding that house from the inside out.
            Nice work!
          83. User avater
            McDesign | Mar 10, 2007 05:32am | #220
            <Looks like you are rebuilding that house from the inside out.>
            Yes, I think about the "big picture" sometimes, and wonder if I approached it right, but I did it all myself, without waiting on anyone else, the roof's never been off or leaked due to my work, and the family has been COMPLETELY undisturbed, so I guess it was the right way to do it.  Never had to stockpile lots of lumber; yadda yadda
            lots o' darn wood, tho'!
            Forrest - ArachniHombre
          84. User avater
            McDesign | Mar 15, 2007 02:58am | #221
            Update time.
            Started to stretch on the InsulWeb - got my quote today, looks good, try to do it Monday - along with another job ('60s ranch attic re-insulate) for a previous client
            Ceiling, too - to DW needed before loose fill
            Put off the front bay intersection till I had to do it - so crooked before . . .  And it really is the focal point of the room.  Basically, I just established a string line at the theoretical intersection and worked to it.  Only 18,523 pieces of wood.
            Here's the left side ready for fabric
            Here's the right side just starting
            Here's the darn thing, finished
            DWed the skylight shafts to prep for the blown-in.  One skylight shaft is 8" deep, one is 10" deep, and one is 12" deep.  MY ceiling is straight - the roof isn't!
            Here's the finished shed dormer area - boxed in the overhead duct; framed the twin closets with cabinets above.  For lighting, I used (6) 4" IC can lights I got at a rummage sale.  They only take a 50w r-20 lamp, so that's why so many - plus it looks cool.
            Moved the original stairwell door off the last step; moved it about 18" over on the landing to center it under the new knee wall.  From above -
            From below - also put in two small stairwell fixtures
            Edited 3/14/2007 7:58 pm by McDesign
            Edited 3/14/2007 7:59 pm by McDesign
            Edited 3/14/2007 8:00 pm by McDesign
            Edited 3/14/2007 8:01 pm by McDesign
          85. stevent1 | Mar 15, 2007 04:38am | #222
            Forrest,
            Are you using the white 'Elmer's as Mike Smith recomends for the insulweb?
          86. User avater
            McDesign | Mar 15, 2007 04:49am | #224
            Yes - I bought a gallon, and a selection of little foam rollers - haven't experimented yet; maybe tomorrow.
          87. stevent1 | Mar 15, 2007 12:39pm | #226
            I think You have more than patience, I think you seek perfection in an unperfect world,
          88. JohnT8 | Mar 15, 2007 08:51pm | #228
            Wish ya lived local.  I'm sure I could keep you busy for a while.jt8
            "The flower that follows the sun does so even on cloudy days."--Robert Leighton
          89. User avater
            davidhawks | Mar 16, 2007 12:18am | #229
            Can't wait to see this thing drywalled, although It'll be a shame to cover up all your fine work.  Like you, I've learned that the finished product will only be as good as the substrate.  It definitely pays to take the pains now in order to prevent them later.Live in the solution, not the problem.
          90. User avater
            McDesign | Mar 16, 2007 02:19am | #230
            Thanks!  DW guy came this AM to measure; they'll stock it (55 sheets) Tuesday and hang Thursday (assuming insulation Monday).  I'll get the Class 5 finish, where they spray the entire job with a heavy surfacer - makes the sheen consistant with the real oblique light we're going to have - more on that below.
            Finished Insulmeshing on the street side - see the (5) ceiling boxes?
            Other side - see the (5) more ceiling boxes?  They're at 110" off the floor
            The reason for the ten light fixtures; I sold them on my lighting design (clap-clap!).  I was concerned about the giant ceiling being too dark at night, and I like indirect but even light.  We'll use ten of these fixtures below, which are opaque ceramic sconces - upwash only - no light comes through, and only a tiny crescent downwards.  the idea is that each row of five bounces off the opposite side's ceiling plane, and from thence to a shadowless floor.  Should be cool, and we can get lots of lumens/sq. ft. without hotspots.  This is a kids' study room, after all.
            Another thing - Finalizing light fixtures today, the client said, "wouldn't it be cool if the vanity light could mount on the chimney? Oh well . . ."  Then he went to work.  Here's my solution.  Dug out the morter; encased 12-2 Romex in 1/2" square steel tubing.  I'll use a metal 90 transition to get in the back of the pancake box, and screw the box to the brick  Once the square conduit gets into the roof plane, the wire comes out to the switch on the side wall.  The whole conduit will get encased in that high heat fireplace caulk.  Chimney will be plastered and painted later.
            Close up - mock-up only!  I know the electricalmetricians are going to yell at me . .  .Yes, it's hot.  I only work that way.  It's more sporting.
            Added some sconces locations here in the front bay - they'll be good lights to leave on and make the three-part window glow from the street.
            Forrest - tired of holding my arms above my head!
            Edited 3/15/2007 7:20 pm by McDesign
            Edited 3/15/2007 7:21 pm by McDesign
            Edited 3/15/2007 7:22 pm by McDesign
            Edited 3/15/2007 7:28 pm by McDesign
          91. User avater
            McDesign | Mar 17, 2007 01:12am | #231
            Clean up and kneee walls today.  My concept worked.
            I used the 1/2" foil-faced foam (foil out).  This will form a backer to blow the "sticky fiberglas" against.  Did it bay-by-bay; reached around and nailed with the plastic-washered nails.
            Also put in baffles to keep the "dry" blown-in the rafter bays from sliding down.
            View from the back side
            All seams and the baffles Great-Stuffed in place from the back side.
            Edited 3/16/2007 6:12 pm by McDesign
            Edited 3/16/2007 6:13 pm by McDesign
            Edited 3/16/2007 6:14 pm by McDesign
          92. User avater
            McDesign | Mar 19, 2007 05:16am | #232
            More done tonight - finally ready for insulators.  Finished the 1/2" foam; lots of hours and 3 gallons of glue rolled on the strapping
            Forrest - tired
            Edited 3/18/2007 10:17 pm by McDesign
            Edited 3/18/2007 10:18 pm by McDesign
          93. JohnT8 | Mar 20, 2007 07:12pm | #233
            Looks good.  Did you get the insulation blown in?
          94. User avater
            McDesign | Mar 20, 2007 07:59pm | #234
            Tomorrow (Wed) at noon, according to the dispatcher.  I'll take pix and post tomorrow PM.
          95. User avater
            McDesign | Mar 22, 2007 02:37am | #235
            Fun day today - up at 5, working on guv'mint projects in the shop, then the insulators show up.  Here's the whole sequence (sorry, dial-uppers!).
            Needed to cut "windows" thru the knee wall so they could blow a blanket on the old ceiling.
            Pieces cut out and numbered
            Flanged with scrap and more Elmers
            Batts in new shed dormer - how 20th century!
            Dead space area with new blanket
            16" total insulation depth!
            Pieces re-installed in prep for JM Spider
            Another snow picture
            Guy on the right is blowing in the JohnsManville Spider "sticky 'glas"; the guy on the left is vacuuming with the return hose.
            Working away -
            Front bay all fluffed; un-trimmed
            Trimmed alleyway to gable
            Shaving the front bay - upwardly-rotating carpet-covered roller.  Can't be too tough; he's on the phone!
            Close-up of the glue injector that sprays along with the chopped 'glas - two fan nozzles
            Sweeping the DW attachment faces with a cut-down corn broom
            Blowing dry fluff again, into the roof planes
            Finished!  Quiet in here!
            Blow truck
            Blow truck interior
            Forrest - tired from watching!
            Edited 4/18/2007 6:23 am by McDesign
          96. stevent1 | Mar 22, 2007 02:53am | #236
            Forrest,
            That's pretty slick. When they shave it, it the materiel recycled? You may have mentioned earlier but what is the R-Value at 16" ?
          97. User avater
            McDesign | Mar 22, 2007 03:06am | #237
            <When they shave it, it the material recycled?>
            Yeah - the suction hose goes back into the hopper in the truck.  With the same amount of air coming and going, it doesn't really get too dusty in the work area.
            Not sure about the total R-value - what I pay for is an "R-38 blanket" on top of whatever old insualtion might be there.  They always appear to overfill, so I guess they anticipate some settling in these free areas.
          98. User avater
            davidhawks | Mar 22, 2007 03:21am | #238
            Forrest,
            You oughta be tired from posting!  It would take me 2 hours to put that much stuff on BT.  Thanks for taking the time.
            Is the insulation plan yours, or did you consult someone, or maybe get what you needed right here at good old Breaktime? Live in the solution, not the problem.
          99. User avater
            McDesign | Mar 22, 2007 03:40am | #239
            Thanks!  I usually sit here and post as I'm eating dinner.
            I read about JM's Spider product either in FH or JLC a few years ago, and have tried to use only it ever since - great stuff, and I like this company - Wilson Insulation; couple locations in Atlanta.  I like that the glue can be turned on or off, so it's just one product in attics or open stud cavities.
            The ceiling / roof insulation scheme here sort of grew out of the Mooney Wall thread.  I came up with the foil-coated foam board backer for the knee walls.  Yesterday, just that really kept it noticeably cooler in there.
          100. Shep | Mar 22, 2007 04:23am | #240
            Forrest-
            thanks for the updates. job looks great, and the HOs should be pleased.
            You have any idea on how much longer you're going to be on this job, or are ya planning on working there until retiring? <G>
            ( a long job for me these days is only a week or two)
          101. User avater
            McDesign | Mar 22, 2007 05:01am | #241
            It better be three weeks or less - I've got another to start!
          102. User avater
            Sphere | Mar 22, 2007 05:33am | #242
            Geeze-us man....doing and photoizing is hard enuff, then posting the pics takes some more effort..and ya gotta eat.
            Thanks, I can appreciate the effort...(G) .
            Looking sweet. So? when was it you were coming up to KY? LOLInmate # 40735 At Taunton Federal Penitentiary.
          103. User avater
            McDesign | Mar 23, 2007 02:01am | #243
            Hey - more today - is there a get-together in KY?  Do we bring jelly?
            Got the tub and shower riser in and drain plumbed - the plumber did, I mean.
            Got the split studs stretched from 6'8 to 7' and installed
            DW delivery guys had to get between the tree, the overhead branch, and the septic tank!  Curved branch at the knuckle eventually fell on his head . . .
            Easy as pie - just could stretch far enough to the cart
            Stocked and ready to go tomorrow!
            Forrest - designing tomorrow on the next job, while real DW guys do their stuff
            Edit - DW guy even brought some trick 135º corner bead for the entry angle into the front bay - he wanted metal there, seeing as it was a kids room!
            Edited 4/18/2007 6:24 am by McDesign
          104. User avater
            Sphere | Mar 23, 2007 02:15am | #244
            Dry Wall?  Heck I have a radiused copper pan that might could fit it....
             No kidding, you rock on man...nice job.
          105. JLazaro317 | Mar 23, 2007 03:20am | #245
            What kind of pocket door frame are you using? I haven't seen one like that before. I use Johnson pocket door frames.
            John
            J.R. Lazaro Builders, Inc.
            Indianapolis, In.
          106. User avater
            McDesign | Mar 23, 2007 03:34am | #246
            Stanley, I think.  I've got a few of them in our house, 10-15 years old, do fine, and I can get them at HD.
          107. seeyou | Mar 23, 2007 04:22am | #247
            Hey, thanks for the pics. I've not seen that system before. It's foreign to this area, AFAIK.http://logancustomcopper.com
            "We have enough youth, how about a fountain of smart?"
          108. JLazaro317 | Mar 23, 2007 04:25am | #248
            I'll have to check them out. Locally here at 84 Lumber they stock these Johnsons we've used for years.
            Also I was meaning to ask why you use the FG insulation vs. cellulose? Just curious. I got away from the FG attic insulation because of air movement through it vs. cellulose being more dense and stopping air movement. John
            Indianapolis, In.
          109. User avater
            McDesign | Mar 23, 2007 04:30am | #249
            I've heard bad things about applying DW right over thick, wet cellulose.  Also, my DW guy says cellulose bulges out the ceiling mesh - he was happy to see that the FG doesn't seem to.  I also like that they can just turn the glue on and off - stud bays and ceilings
            This FG is pretty dense tho'
          110. Piffin | Nov 21, 2008 03:44pm | #340
            I use Johnson kits, which look just like what Forrest has there, but I can order them with longer legs that don't need to be stretched as he did.
          111. JLazaro317 | Nov 21, 2008 05:32pm | #341
            We use Johnson kits also. I think we may need to revisit the one we use, but it seems to be the only one that is readily available around here.
            This is the one we use:
            2700
            PREFABRICATED POCKET DOOR FRAMES
            MAX DOOR SIZE: 36" x 80" x 1-3/8" [914mm x 2032mm x 35mm]
            MAX DOOR WEIGHT: 200lbs. [91kg]*
             click here for details
            Pre-fabricated pocket door frame delivered factory assembled. The 2700 is manufactured to a finish thickness of 3-1/2" (90mm) and will accept doors up to 1-3/8" (mm) thick. Removable .055 6063T6 aluminum track with convex rails, rust resistant steel reinforced timber split studs, jump proof three wheel 3/4" (19mm) dia. hangers. 14-16 gauge zinc dichromate plated steel components. *Heavy duty track/hanger combination available for doors weighing up to 200 lbs. (91 kg.)John
            Indianapolis, In.
          112. Piffin | Nov 22, 2008 04:33pm | #342
            Yours is pre-assembled.
            mine use same head track, and include the steel wrapped 'studs' like Forrest shows in his photo The standard package comes with the right length for a 6'8" dopor, but I can special order for a 7' door. johnson also has a more heavy duty track for doors weighing over ___#s. I don't remember the load exactly.Forrest linked to this thread from another one about spider insulation is what found me here and I saw that door comments
          113. MikeSmith | Nov 22, 2008 04:46pm | #343
            we use johnson too.... sometimes the standard kit... sometimes the heavy duty
            in either case we screw 1/2" plywood to the steel studs, both sides , ....or we throw the steel studs away and use 2x4 flat
            the ply makes a wall one inch thicker than normal...  the 2x4 makes the wall 2 inch' thicker than normal
            we had too much trouble with sheet rock screws / warping / trim  with just the regular kit studsMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          114. Piffin | Nov 22, 2008 06:06pm | #345
            "we had too much trouble with sheet rock screws"yah, then there is the door I riddled with about 18 finish nails from my Paslode installing waniscot ....
          115. john7g | Nov 22, 2008 06:54pm | #346
            that makes me feel better about the 1 door I shot & repaired 3 different times.
          116. Piffin | Nov 22, 2008 09:38pm | #347
            seems like you'd have run out of four letter words the second time. Did you have to dig into your reserve verbiage the third time around? or just throw a BFH threw a window?;)
          117. john7g | Nov 22, 2008 09:49pm | #348
            used 'em all up th e1st time. Was humble the 2nd two.  got real good at fixing/hiding them in 3 sesions though.
          118. JohnT8 | Nov 26, 2008 07:34pm | #349
            I'm picking up all kinds of your bad habits.  Two "Smith-isms" in one pic.jt8
            The creative individual has the capacity to free himself from the web of social pressures in which the rest of us are caught. He is capable of questioning the assumptions that the rest of us accept. -- John Gardner
          119. MikeSmith | Nov 26, 2008 08:13pm | #350
            you got it.... makes it pretty nice, no ?Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
          120. JLazaro317 | Nov 22, 2008 04:50pm | #344
            I can honestly say that we've never had problems with the unit we use even though it seems a bit flimsy. We anchor it very well and it is nice that it remains only 3-1/2" thick. It's the only unit we see so it must be a regional preference. The only downside is that it is size specific. It would be nice to have one that could easily be adjusted.John
            Indianapolis, In.
          121. User avater
            McDesign | Mar 24, 2007 03:08am | #250
            Rockin' today - what can I say about it?  The guys do a crisp job; they said all the angles were tough!
            I spent 3 hours measuring the house downstairs, and some hours on the computer drawing "as-built" drawings, and some speculative sketches to leave with the client over the weekend.
          122. User avater
            Sphere | Mar 24, 2007 03:34am | #251
            Yowlll..that is nice rock'n work. My upstairs is sooooo similar..I need to hide them pics before the DW sees them.
            Sweet.Inmate # 40735 At Taunton Federal Penitentiary.
          123. seeyou | Mar 24, 2007 04:06am | #252
            Nice sheetrock work. You almost don't need mud.http://logancustomcopper.com
          124. User avater
            McDesign | Mar 24, 2007 05:59pm | #253
            Ha!
            Here's a crew of EIGHT today - making it fly!
            Edited 4/18/2007 6:25 am by McDesign
          125. stevent1 | Mar 24, 2007 09:47pm | #254
            Forrest,
            Looks good. Looks like paint can start next week. Are you going to sub that out as well?
          126. seeyou | Mar 25, 2007 12:04am | #255
            >>>>>>>>>>Are you going to sub that out as well?I'm shocked that he let insulation installers and Dw installers/finishers on the property. But it looks like they're up to his standards.http://logancustomcopper.com
          127. stevent1 | Mar 25, 2007 12:11am | #256
            Grant,
            Are you saying 'no hablo ingles' I am sure Forrest got their I-9 info.
            Chuck S
            Edited 3/24/2007 5:11 pm ET by stevent1
          128. seeyou | Mar 25, 2007 12:41am | #257
            >>>>>>>>>Are you saying 'no hablo ingles' No sir. What I was saying is that he's done everything by his lonesome (including picking up lumber, IIRC) and suddenly there's subs on the job. I can tell from the way he approaches each task how well he's thought it out and planned the next step. Early on, I assummed from the way he operates that he's an anal retentive nut (I mean that in a good way) and no one wanted to work with him. Now I realize, he's just doing the stuff that's fun to him and getting paid for it. Rock on, Forrest.http://logancustomcopper.com
          129. User avater
            McDesign | Mar 25, 2007 12:49am | #258
            <doing the stuff that's fun >
            Man, you got it right - Once the framing's done, the next coupla' steps are cookie-cutter.  Best to sub that to people that are really good at knocking that out.  No way could I do enough DW to be as fast and good as those guys - plus, I've been using their boss or now, his company, since 1999.  Just checked the job, here at 5 on Saturday, its all done and scrapped out (into my P/U).  They'll finish Mon and Tues.
            Kind of like the stripes on this first pic!
            I've spent billable CAD time while they worked, and followed up the next leads.
            I'll probably trim out and paint - it's fun to see it come together!
            Edited 3/24/2007 5:50 pm by McDesign
            Edited 3/24/2007 5:51 pm by McDesign
          130. seeyou | Mar 25, 2007 01:06am | #259
            Keep the pics coming as it progresses. I did a 30 sq copper roof/box gutter/metal cornice/3 layers of shingles tear off job by myself (my son bent some pans and hauled trash to the dump, but other than that it was solo) about 8 years ago that I wish I had documented better, so I could show off. I bought my first digital camera after I finished that job and I lost my polaroids.http://logancustomcopper.com
          131. stevent1 | Mar 25, 2007 01:36am | #260
            Grant,
            In no way did I mean anything negative. It seems almost all finish trades seem to have a lot of ethnic employees. Heck. My masons and brickies are ethnic. You are right. Forrest is a perfectionist and achieves it.
          132. User avater
            davidhawks | Mar 25, 2007 04:04am | #261
            Fantastic job Forrest!  I can't wait to see how you treat that chimney.  Character is one thing, but your work has made that lummox look worse than ever.
            As an aside, I've used the Johnson pocket doors also, like the other poster.  Good quality, but pricey.  How proud are the Stanley folks of their product?
            ThanksLive in the solution, not the problem.
          133. User avater
            zak | Mar 25, 2007 08:16am | #262
            I've used Stanley and Johnson pocket door kits (the boxed ones, not the prebuilt units).  I didn't think they were much different.  The track is exactly the same as far as I can see, the main difference is # of wheels on the rollers- Johnsons have 3, Stanley 4.
            That said, the roller thing does seem to make the johnsons a wee bit smoother.  They're both about the same to adjust.  I've paid about $50 for the Stanleys.  I think the Johnsons are a few dollars more.zak
            "When we build, let us think that we build forever.  Let it not be for present delight nor for present use alone." --John Ruskin
            "so it goes"
          134. Brian | Mar 25, 2007 02:26pm | #263
            pocket doors...
            Stanley makes/made a pocket door kit with a one-sided track, not at all like the Johnson.  I used them in a house 8 years ago - the box said they would never skip the track.  It lied - they were terrible.  If the current Stanleys have the double track, thats a different story...
            I had to talk my wife into pocket doors again b/c of the character of those loser doors in our last house.  Treat every person you meet like you will know them the rest of your life - you just might!
          135. User avater
            McDesign | Mar 25, 2007 03:38pm | #264
            Thanks!
            <that lummox look(s) worse than ever.>
            Client has to make some decisions by Wednesday - chief among them whether we'll deal with the chimneys now (make 'em wood-burning-safe) or later (keep & add some gas-burning capability).
            I kind of hope they decide to do it later, so I can try and make them beautiful "as-is".
            I see them as two pieces of asymmetric sculpture in otherwise angular rooms.
          136. User avater
            davidhawks | Mar 26, 2007 04:13pm | #265
            Forrest, you are an optimist in every sense of the word.
            BTW, what's the next project?Live in the solution, not the problem.
          137. User avater
            McDesign | Mar 29, 2007 01:28am | #266
            Here's today - lots of little pix.  The top coat was sprayed by the DW guys - some sort of thin mud.  I cleared out the tape over all the elec devices, sanded the odd bits, and cleaned and vacuumed.  Ready for paint, once the client decides - all lighting ordered.  Flooring guy coming by for a quote tomorrow.  I like all the clean white planes after the mess of building the darn thing!
          138. User avater
            Gene_Davis | Mar 29, 2007 01:52am | #267
            Never in a million years would I bury and lose that corbeled chimney.  Way way too much going on there.
            That is really a huge attic you're working in, Forrest.  None of the photos up to now really delivered the scale of it like these post-rock ones.
          139. seeyou | Mar 29, 2007 02:33am | #268
            I think the chimney keeps things in perspective. Nice clean lines from the new work contrasted with the realness of the original construction. Wait a minute, I'm gaying this thread up.http://logancustomcopper.com
          140. User avater
            McDesign | Mar 29, 2007 02:38am | #269
            <clean lines from the new work contrasted with the realness of the original construction>
            Yeah!  Thats what I thought, too.
            David said I was just being optimistic.
            Sigh.
          141. dug | Mar 29, 2007 03:04am | #270
            Forrest,
                           What type of flooring are you thinking of installing?
              Excellent job, Bet you're glad to be at the end of this one though. Man that was a lot of work, but it appears to be worth it. How many sq. ft. did ya recover?
                dug
          142. User avater
            McDesign | Mar 29, 2007 03:17am | #271
            <How many sq. ft. did ya recover?>
            Just under 1200 sq. ft.
            This area will temporarily get inexpensive carpet and vinyl in the bath/laundry; will all be replaced with 3/4" T&G Mountain Lumber reclaimed heart pine when we do the main addition later this year or early 2008.
            The delay is because we really don't know at this point how the as-yet undesigned addition 2nd floor will tie on to this part, though it's a given that the existing narrow stair will go away - hate to try to lace that in later
          143. stevent1 | Mar 29, 2007 03:50am | #272
            Looks good.
            Better than good. Would you consider a parge coat on the chimneys?
          144. User avater
            McDesign | Mar 29, 2007 04:09am | #273
            I got a plan for the chimneys, if the client decides not to rebuild them now.
          145. TommH | Mar 30, 2007 01:30am | #274
            Is the thinned sprayed-on mud sanded after it dries or is it smooth enough for paint?
          146. User avater
            McDesign | Mar 30, 2007 02:19am | #275
            <Is the thinned sprayed-on mud sanded after it dries or is it smooth enough for paint?>
            Depends on the finish you want, I think.  As-sprayed, the wall feels rough - maybe like 100-150 grit?.  But, using a pretty fluffy roller would more than take care of it.  The stuff sands GREAT, and isn't gummy, so one swipe with a sanding sponge or screen and it's like glass.
            Frankly, I completely sanded the bathroom, which will be semi-gloss applied with a short-nap roller, and just hit any really rough spots in the main room and storage room.  They get flat with a long-nap roller.  I'm interested to see the result over the next few days.
            Those rooms took (30) 12', (30) 10', and (20) 8' sheets and 20 gallons of the mud/primer
            Forrest - gotta' get a book-on-tape to paint to!
          147. stevent1 | Mar 30, 2007 04:45am | #276
            Forrets,
            Those drywall pics show the importance of planing out the substrates for a great looking drywall job. DW said your first pic was almost Cathedral-like. Thank you for sharing your artistry with BT FREE.
          148. User avater
            McDesign | Mar 30, 2007 04:50am | #277
            Thanks!  I love the way the light through that south-facing window bounces off the floor and makes the bay niche outline glow.
            Customer had some relatively diverse paint color thoughts; then saw it all glowing in that primer, and they've decided to go B/M "linen white" throughout.
          149. stevent1 | Mar 30, 2007 05:17am | #278
            My favorite is "Museum White". A blank pallete. Easy to paint over as plans evolve.
            Our current home is Russian White.(B1)
          150. User avater
            McDesign | Mar 30, 2007 01:05pm | #279
            I've been talking about "the addition" to this house to come next (probably 2008); here's the current state of our noodling.  Here's the house "as-is" downstairs.  The attic triple window would be at  the bottom of the drawing; the shed dormer with French doors would be at the top.
            Here's the "possible".  We think the shape is generally correct; we're working on the layout of the top left and top right rooms (probably won't be bedrooms), and the back porch will probably be full width, like the existing front porch   Note the house has been "symmetricalized"; you can walk straight through from the front door out onto the back porch.  Back (top) will have a stairway and two bedrooms above the family room
            Forrest - movin' on
            Edited 3/30/2007 6:06 am by McDesign
            Edited 3/30/2007 6:08 am by McDesign
          151. kgregor4 | Mar 30, 2007 01:58pm | #280
            You've certainly got your work cut out for you with this one. But little doubt that it will end up another showplace.
            First thing that jumps out at me on the original floorplan is the landlocked bedroom. Glad to see that it's gone.
            On the proposal the top 2 bedrooms, which you note might not end up as 2 bedrooms, both open off the family room. I always try to envision line of sight were the door left open. And save a library or study, dislike rooms which open directly off another.
            Look forward to the thread which will document all the work.
          152. User avater
            McDesign | Mar 30, 2007 02:07pm | #281
            <the landlocked bedroom. Glad to see that it's gone.>
            Yeah - it feels weird - especially with the three windows!  That "L" or "T" shaped area in the back was a porch enclosed in the '50s.
            This "proposed" drawing was an attempt to maintain three bedrooms on the main floor, but you're right, it's a bit awkward.
            The upper left bedroom area will likely be a large master bath; the Ba and MBa on the drawing would become his & her closets.
            The upper right area will likely become an office and a laundry room, with a horizontal hall going to the left just above the kitchen, to the outside wall, then a breezeway to the detached garage to be added off to the right and back a little.
          153. JLazaro317 | Mar 30, 2007 02:35pm | #282
            I bow to the master. I like what you've done with the plan! Can't wait to follow that thread. Maybe you could talk them into letting you start right away. Will they be living in the house during that project?John
            Indianapolis, In.
          154. MikeSmith | Apr 07, 2007 11:24pm | #294
            forrest... this whole series is cool... i think i like this one best ....
          155. stevent1 | Apr 08, 2007 01:42am | #295
            Forrest,
            We call that "Museum White". Each room is a blank palette.
            I agree with Mike Smith. That is a great shot. I hope you can convince the owner to put in Heart Pine floors to match the rest of the house. If not, at least Yellow Pine with a shellac finish.
          156. MikeK | Mar 30, 2007 08:21pm | #283
            In your proposed plan there is not much connection between the Family Room and Kitchen. This is not ideal for the lifestyle of most Families. Have you considered putting the Family Room directly behind the existing Kitchen. If the Kitchen and Family room are connected as one space the small Kitchen will be perceived as being larger.
          157. User avater
            McDesign | Mar 30, 2007 10:24pm | #284
            Pretty cool - we'll talk about it.  I think their desire for a straight-through North-South axis will need to be worked in there.
            Thanks for the input -
          158. MikeK | Mar 31, 2007 12:52am | #285
            I live in a 1890's house. As was typical back then the Kitchen was through a narrow corridor at the back of the house, while the Living Room was at the front of the house. My wife hated not being able to keep an eye on the kids while she used the Kitchen, or being able to watch TV.  We recently put an addition on the house with a new Kitchen/FR combo, and we like it much better. The Kitchen is about 13' x 16', and the FR is about 12' x 16', not very large rooms, but because the rooms are designed to be visually one space the rooms don't appear small. By combining the two spaces you may be able to offer a more efficient, lower cost solution to the clients. Of course the lifestyle of the clients may differ from mine.  Just curious, which side of the house faces South? Where are the stairs going in the new plan?
            Of course then there is the existing foundation, existing load-bearing walls, mechanicals, zoning, etc to work the design around. May be difficult to go from concept to a working plan. Should be a fun design challenge. Good luck on your project! Thanks for taking to time to post all the attic photos.
            Mike K - Old House Remodeler - Aurora, IL
          159. User avater
            McDesign | Apr 07, 2007 03:47am | #286
            Hey, getting it trimmed out and painted.  Just simple SW Duration "Extra White" was their expedient choice.  Satin on all DW; SG on the woodwork.
            Storage room - walls done; just caulked and filled baseboards tonight.
            View Imagex
            Side of storage room
            Chimney with secret process finish
            Cut-down doors to attic and HVAC - thresholds to come
            Bath with skylight
            Chimney again, vanity light goes on wire; pedestal lav below.  Brick "shelf" makes the new daughter tenant very happy.
            Edit - just wanted to remember what it looked like before!
            Chimney close up.  Process goes like this.  Vacuum with stiff brush.  Make special secret mixture of concrete bonding admixture (HyBond), WB saltillo tile sealer, white Elmers glue, vermouth, and some water to get viscosity right for Wagner power painter.  Spray it on.  Exactly two hours later, brush on Kilz 2 WB.  Do not backbrush; will tear off.  Let dry overnight.  Hard as rock in the morning.  Then, carefully latex caulk all holes.  Dry overnight again.  Then, one or two coats of, in this case, Satin SW Duration.  Client loves the look, and the clean feel of it after the previous powdery mess.
            Simple door frame in bath.  All MDF; used 5/8" for posts; 3/4" for lintel.  Clean, simple look.  3' X 7' Victorian door gets frosted glass panels and refinished white
            Coped some base around the chimney penetration.
            Forrest - wrapping up
            Edited 4/18/2007 6:26 am by McDesign
          160. Shep | Apr 07, 2007 04:23am | #287
            That's probably as good a use for vermouth as any other.<G>
            The job looks real nice. Your clients better be happy with your work.
            I've spent the last week doing a ceiling treatment on a bedroom cathedral ceiling. I should finish up Monday. The whole job's about $7 Grand. I gotta remember to take some pics.
          161. User avater
            McDesign | Apr 07, 2007 04:46am | #288
            Post pix!
            Forrest - picture junkie
          162. Shep | Apr 07, 2007 05:07am | #289
            My problem is that I get so wrapped up in doing the work that I forget to take pics.
            And when the job is done, I want to pack up and move on to the next one.
            I really have to try to remember. I've had jobs that would look great in a portfolio, but never took pics.
            Shep- gettin' forgetful
          163. stevent1 | Apr 07, 2007 12:50pm | #290
            Looks really good. Did you have to do any point-up on the chimney? Your secret process is no longer a secret. I copied it for future use.
            I like satin for walls. Easier to wipe stains and kids messes off.
            Chuck S
            Edited 4/7/2007 5:55 am ET by stevent1
          164. User avater
            McDesign | Apr 07, 2007 03:17pm | #291
            No point-up other than caulk.  Chimney will only be used for gas logs until such time as it is majorly redone and largely replaced, so until then it's a sculpture.
            Forrest - just made a fire in the kitchen; our draft fan in the downstairs back furnace failed just as it got warm a few weeks ago - figured the cold weather was over, and I'd fix it later, and it was 46º in here with all the cold and wind last night!
          165. User avater
            Gene_Davis | Apr 07, 2007 08:55pm | #292
            Re the color choice:  Mon Dieu!
            Had we known before we began this thread that the whole effort would be just one big white-out at the end, we would have gone back to Leni Riefenstahl for a thread title.  One of her early works, and she starred in it herself, "The White Hell."
          166. User avater
            McDesign | Apr 07, 2007 10:22pm | #293
            Wow, dude, you know stuff!
            Been cutting in semi-gloss white on base against white satin walls all morning - my eyes hurt!
          167. JohnT8 | Apr 10, 2007 07:19pm | #296
            OK, what're you working on this week?
            "We ourselves feel that what we are doing is just a drop in the ocean. But the ocean would be less because of that missing drop."-- Mother Teresa
          168. User avater
            McDesign | Apr 11, 2007 03:34am | #297
            <OK, what're you working on this week?>
            Finishing up the main room - bathroom only needs fixtures installed, and the storage room is complete except for carpet.  Gotta trim out and top coat main room before all carpet on Friday.  Better be through by then!  Also, got with the monster house people, and signed a design contract - got some clear direction and gave them the "you can't have that, it's too expensive" talk, and they got real.  Signed a SOW contract with the three bathroom job people - start two weeks from yesterday.  And a flooring job mid-next week for a repeater.
            Today I played with the big chimney and my secret process.
            Brush and vacuum and spray with special recipe - flood it on - about two gallons for this.
            When dry to the touch, 2-3 hours, when you can't rub up any grit, the WB Kilz, really dabbed on with a 2" sash brush.  can't go back over it; it will tear the surface.
            Who put this darn wall here?
            Ready for caulking up the pinholes tomorrow, top trim, and paint Thursday.
            Forrest - flailing about in all directions
          169. stevent1 | Apr 11, 2007 12:32pm | #298
            That's a slick process. Will you have to line it if they use gas logs?
            Sounds like you have some nice jobs lined up.
          170. User avater
            McDesign | Apr 11, 2007 12:37pm | #299
            According to my chimney guy, the chimneys are fine for gas logs as is, and with my paint.  Two fireplaces (one each chimney) currently have gas log setups.  Later, the chimneys may get serious rebuild and relining for wood, but that's in the future.
          171. Thaumaturge | Apr 11, 2007 05:50pm | #300
            Great project, great pics, great job.
            Did this in my own (smaller) attic a couple years ago and should have sub'd out the drywall to your guys - nice work.
            I'm glad you keep repeating that the chimney will get a rebuild someday as it broke my heart to see the brick painted even though it was in pretty rough shape.  In it's natural state it provided a nice counterpoint to the crisp and clean remodel.
          172. User avater
            McDesign | Apr 11, 2007 08:36pm | #301
            Thanks!  Roof leaks had leached out the lime in the mortar; walking past, the mere breeze would dislodge a spray of sand.  Structurally okay, but darned messy!
          173. User avater
            McDesign | Apr 12, 2007 03:24am | #302
            More today - top coats in main room; lights installed tomorrow.  Nineteen fixtures in that main room!  That's (6) cans, (10) ceramic upwash hip sconces, two Rejuvenation wall sconces in the front niche, and another one over the stair.  Gotta get the bath fixtures mounted, too.
            Added a layer of reflective 1/2" foam to the attic doors (cut-down HD pre-hung hollow core) - made a noticeable difference feeling the door with your hand on a hot afternoon.
            Also added weatherstripping to both doors
            Client-chosen temporary vinyl (antique heart pine next year, with major addition)
            Caulked chimney pinholes and uglies visible after primer - this side anyway.  Had to come home to babysit - DW has changed from Aikido / Self Defense classes to Yoga!
            Forrest - feelin' safer
            Edited 4/11/2007 8:34 pm by McDesign
          174. Shep | Apr 12, 2007 04:12am | #303
            A wife who's into yoga?
            You're a lucky man.
            A bottle of wine, and those yoga lessons can be put to good use <G>
          175. mcf | Apr 12, 2007 05:00am | #304
            The blown in insulation looks very similar to the product the insulation company I hired to do my attic and knee walls yesterday. They use fiberglass by certaineed. I believe it is InsulSafe4. They claim it doesn't settle and that the density is controlled at the pump.
            If you are using the same product have you noticed any settling since being blown in. I am looking forward to this installation since my home has next to no insulation.
          176. User avater
            McDesign | Apr 12, 2007 05:06am | #305
            I haven't noticed any settling, but it's only been a few weeks.  They tack up little half-yardsticks all over to get the depth consistant, and certainly filled more than the 8" I paid for.
            i would think the 'glas wouldn't settle like cellulose, because it's lighter and fluffier, but each little fiber of glass is stiffer than a cellulose, or wood fiber.
            Don't know if they anticipate settling or just like me ;-)
          177. Squash | Apr 13, 2007 05:58am | #306
            Forrest,
            Looks beautiful... absolutely beautiful.  You have outstanding attention to detail and obviously a good deal of patience and ingenuity.  I tip my hat to you.
            Nick
          178. User avater
            McDesign | Apr 14, 2007 04:05am | #307
            Thank you sir!
            Here are today's work details -
            The upwash sconces installed - good but . . .
            You can see the 100 W halogen bulbs if you are near the edges of the room - too harsh, IMHO.  I cut out an experimental shade from aluminum sheet; the client likes it - will probably hit it with high temp white paint.
            Trimmed out the two little closets and installed base.  Client likes the above cabinets without doors; will use as a display shelf.  Just caulked and puttied so far.
            Closet only deep enough for shelves - 11"
            Client actually checked to see if I put in the 1-1/4" bit of base on the left - of course!
            Made the jambs; the wall is flatwise 2x4.  Easy to rip two 2-9/16 jambs from one 1x6.  Outer casing is 1x6 MDF; inner is that FJ crap that comes on prehungs
            Another picture of the shade experiment
            Trimmed-out storage room door kind of tucks behind the chimney -
            Edited 4/13/2007 9:16 pm by McDesign
            Edited 4/18/2007 6:27 am by McDesign
          179. seeyou | Apr 14, 2007 04:39am | #308
            Looks great. What's up with the light fixture on the right?http://grantlogan.net/
          180. User avater
            McDesign | Apr 14, 2007 04:51am | #309
            <What's up with the light fixture on the right?>
            I'm trying to block the direct line-of-sight to the bulb.  First attempt.
          181. stevent1 | Apr 14, 2007 04:57am | #310
            Forrest,
            Nice trim work. The sconces look great.
          182. Thaumaturge | Apr 14, 2007 09:00pm | #311
            More great pics.
            I have to say I am not a fan of those sconces although your very clever modification did help.
            With all that halogen up there I'm guessing the heat in the summer is going to build up nicely.  Of course, the top notch insulation job should help mitigate the problem.
            Do the skylights get the Velux blind kits?
            The blinds in my skylights are closed a good deal of the time during the summer in my attic reno and it really does help.  They also get closed during the night as the full moon can occasionally act like a spotlight sometimes. :-)
          183. User avater
            McDesign | Apr 17, 2007 06:10am | #312
            Trim painting, and some artful scribing around the chimney top today - had to use my paper doll technique - laid out a true line on the ceiling, then cut paper bits to fit to make the eight pieces.  Pretty extreme fitting!  Also got the chimney top-coated.
            Really happy with the way it turned out - DW was real impressed when I just  downloaded these pix - said it was "art"    :-)
            Forrest - going to bed; carpet in tomorrow
            Edited 4/16/2007 11:14 pm by McDesign
          184. stevent1 | Apr 17, 2007 12:17pm | #313
            Great technique. That attic looks better than most living rooms.
          185. JohnT8 | Apr 17, 2007 06:46pm | #314
            Be careful, she might be lining you up for some "art" work in your own house ;)
          186. User avater
            McDesign | Apr 18, 2007 04:33am | #315
            More details today + carpet (temp 'til wood floor next year)
            Vanity fixture grows from the bathroom chimney -
            All the sconces installed and caulked; paint them ceiling color tomorrow
            Trimmed out the wing wall - that's extra 1/4 rnd lying on top
            Trimmed down the experimental shade (on the right); got sign-off from client.  Will duplicate this ten times and paint them flat white -
            Little silliness on a switch / door casing interference - not really a better place to lay out the box due to stuff in the wall - the idea is that it refelects the ceiling angles -
            Forrest - more final bits tomorrow
            Edited 4/17/2007 9:45 pm by McDesign
            Edited 4/18/2007 6:28 am by McDesign
          187. User avater
            McDesign | Apr 18, 2007 04:53am | #316
            Commercial carpet in the storage room
            Edited 4/17/2007 9:53 pm by McDesign
          188. stevent1 | Apr 19, 2007 03:38pm | #317
            Forrest,Nice switch detail. Did you use a box extension?You have done a great job on that attic!Chuck Slive, work, build, ...better with wood
          189. User avater
            McDesign | Apr 19, 2007 10:08pm | #321
            I have now - just pulled the plate back off to paint this morning; I actually just bandsaw the front 3/4" of another box off - it's cheaper and better.
          190. grpphoto | Apr 19, 2007 06:52pm | #318
            > job should help mitigate the problem.Actually, it'll make it worse. It'll hold the heat from those halogens in.George Patterson, Patterson Handyman Service
          191. FHB Editor
            JFink | Apr 19, 2007 07:57pm | #319
            Forrest,
            I haven't read through all of the posts, but those electrical boxes look like low voltage (orange color) - what's the plan for those?Justin Fink - FHB Editorial
            Your Friendly Neighborhood Remodelerator
          192. User avater
            McDesign | Apr 19, 2007 10:04pm | #320
            Hah!  it's all 12V!  No, really -
            I, I mean my electrician, installs all devices and turns everything on before insulation.  I tape over everything with masking tape, to seal out the JM Spider spray, and spray paint the taped-up boxes orange to be visible to the guy shaving off the excess.
            It all stays on until the DW is finished - helps the DW guys remember where the boxes are, and keeps mud out of the receptacles - I like them to tighten-up the cutouts so I don't have to use jumbo device covers
            Just my way
          193. noelski | Apr 20, 2007 03:39am | #322
            whats that white stuff?
          194. User avater
            McDesign | Apr 20, 2007 03:45am | #323
            <whats that white stuff?>
            Johns-Manville "Spider" blown fiberglas insulation.  Basically dry blown through a hose, with an add-on nozzle at the end that sprays glue along with the fiberglas; makes it "sticky" enough to stack up in stud cavities.
          195. arnemckinley | Apr 20, 2007 03:20pm | #324
            mcdesign,
            you have made this job look so neat to the point that i find myself ashamed of some of my past remodelling sites. organization is such a huge part of remodelling, more so than in new construction, or maybe it's just so much harder to stay organized in remodelling. it's something that i srtuggle with. you make it look easy.  thanks for your conributions.
          196. User avater
            McDesign | Apr 21, 2007 03:28am | #326
            Thanks for the kind words.  Client is "moving in" as I am assembling the bathroom.  I try to stay after them to keep it neat . . .
            Still need to make the three-part window frame - will be shop-built and applied.
            Made the (10) final sconce shades this AM; aluminum sheet, snipped and flattened and painted flat white on the outside
            Main part of storage room full
            Alley of storage room full
            Yes, the thermostat is behind the furniture - must move it.  Somewhere.
            Client likes the little side closets do much, she decided today she wants glass doors and display shelves.  Okay.
            Forrest - winding down
            Edited 4/20/2007 8:37 pm by McDesign
          197. stevent1 | Apr 21, 2007 12:36pm | #327
            Forrest,
            Those sconces worked out very well. Looks great.
          198. seeyou | Apr 21, 2007 05:23pm | #328
            Looks great. I bet those sconces below the skylights make an unusual glow on the outside at night.http://grantlogan.net/
          199. JohnT8 | Apr 23, 2007 05:45pm | #329
            Sheeze, they either must not have been able to walk through the downstairs, or now have a couple empty rooms down there.
            [edit]  I thought inglenooks had a fireplace, not a window ;)
            "The lowest ebb is the turn of the tide."-- Henry Wadsworth Longfellow
            Edited 4/23/2007 10:47 am by JohnT8
          200. paulwaterloo1 | Apr 23, 2007 06:28pm | #330
            Great job on the whole thing....not only does it look fantastic, but you know what is behind the walls is top shelf work!
          201. User avater
            draftguy | Apr 23, 2007 06:36pm | #331
            all that work . . . just to store some mattresses, old couches and laundry basketsGreat effort though. Some very ingenious solutions and craft, including the temporary stairs outside. Appreciate all your time, documentation and explanations as well (makes it worth the price of admission) :)
          202. User avater
            McDesign | May 02, 2007 03:27am | #332
            More details -
            Pocket door to bathroom - 3'x7' Victorian door; two top panels routered out from the back and etched glass panels put in.  Threshold is underway!  Once the stairway is removed, the door will be converted to hinged, and centered under the ridge.View Image
            Inside view - just used some tiny HD stop molding to retain the glass this side - man these rooms need some art!View Image
            I've done this a couple of times in attic showers.  It's a curved telescoping shower rod (for more volume  inside the curtain); trimmed with a pipe cutter, and with the right hand mount rotated.View Image
            Attaches thru ceiling DW to strapping here - new holes drilled in rod to match angleView Image
            Corner of laundry area; this will get a free-standing Japanese screen to block view of the mechanicals.  Yes I always use an expansion tank.  I mean my plumber does.View Image
            Ha ha!  Chimney flashing still leaks!  Somebody better get on that . . .View Image
            Looking up from the existing laundry room (yes that is an 80º corner)View Image
            Looking downView Image
            It's almost installed!View Image
            Edited 5/1/2007 8:40 pm by McDesign
          203. JohnT8 | May 02, 2007 05:47pm | #333
            Well dang it man, don't leave us hanging!
            I don't remember seeing any pics on the pocket door framing, did I miss them?  And I like that door, but that space up there needs some color.
          204. User avater
            McDesign | May 02, 2007 07:36pm | #334
            Here's one before the door was re-done
            Edited 5/2/2007 12:36 pm by McDesign
          205. User avater
            McDesign | Jul 26, 2007 01:36am | #335
            Finally got back over there and the new center window and hand-made "Richardson Romanesque" window frame installed.
            Edited 7/25/2007 6:37 pm by McDesign
          206. User avater
            Sphere | Jul 26, 2007 02:48am | #336
            Tempered Glass?
          207. stevent1 | Jul 26, 2007 02:50am | #337
            As always. Looks good.
          208. User avater
            McDesign | Jul 26, 2007 03:25am | #338
            <Tempered Glass? >
            Ummmm. . .  who wants to know?  I know the original two smaller windows aren't.
            Forrest - pretty even-tempered
          209. User avater
            Sphere | Jul 26, 2007 03:33am | #339
            I just figgured the center one =big $$$$.
          210. JohnT8 | Apr 20, 2007 05:00pm | #325
            Make sure we get a full array of final shots before you vanish from the scene.
          211. gzajac | Mar 15, 2007 04:40am | #223
            McDesign
            I have enjoyed your thread immensley. I wish I had half the patience you have doing this kind of remodel. People will be impressed with the before and after pictures of this project.
            Do you enjoy these kind of projects as much as your writing seems to portray?
            Keep the pictures coming
            Greg In connecticut
          212. User avater
            McDesign | Mar 15, 2007 04:51am | #225
            I really do enjoy jobs like this.  The kind where you can see the broad strokes before you start, but have to work through all the little particulars that come up.
            Lucky to have jobs like this - it's become my niche, I think/hope!
          213. User avater
            ErnieK | Mar 15, 2007 02:34pm | #227
            I have to agree with Chuck...I am impressed with your drive for perfection.  Very uncommon in this day and age.  I love following these picture threads you guys produce, despite being a longtime tinknocker.  Very informative!
            Keep up the fantastic work...(good doesn't cut it)!
          214. User avater
            davidhawks | Feb 20, 2007 05:30am | #174
            I enjoy plumbing and wiring these size projects too.  I learned what little I know about those trades out of necessity and too many $200.00 service calls to relocate an outlet or DWV line.
            Don't get me wrong, those guys have definitely earned the right to bill whatever they think it's worth.  The main thing is being able to avoid shutdowns b/c I'm waiting for a plumber or electrician.
            Looking good.  How many boards gonna take to cover up all that work?   Live in the solution, not the problem.
          215. User avater
            McDesign | Jan 25, 2007 02:25am | #54
            <If I was Forrest, I'd have rented a lift rather than built the stairs.>
            Ah - but they are more than stairs!  How would I use a lift by myself? I still have to get material off the relatively weak 10' wide shed roof and into the attic.
            The nice stairs mean I can just grab stuff off the truck, walk up and in with it, and plop it down wherever I need it - one handling operation.  Also, it's a nice work area.  Also, it carries me over the little building and stairs below, so's I can throw stuff in my good old truck (don't want to scratch it, ya know).
            Lift just wouldn't do all the things the stairs do - and wouldn't be so purty.  I'm so sold, I may never do major attic work without building one again.
            Forrest - convincin' myself I can live without a lift
            Edited 1/24/2007 6:26 pm by McDesign
            Edited 1/24/2007 6:28 pm by McDesign
          216. seeyou | Jan 25, 2007 03:21am | #56
            >>>>>>>>>>How would I use a lift by myself? How did you take those pictures by yourself?I'm talking about a boom lift that you drive from the basket, not a fork lift/telehandler.Don't get me wrong, I'm not criticizing your method, I was suggesting an alternate. It's the John Henry syndrome as someone here mentioned previously. I'd rather let machinery make my life easier than kill myself proving that I can outdo it.It would take us about the same amount of time to stock the lumber with either method, but I would have spent a lot less of my personal energy. The older you get the more this matters.BTW, I know you don't watch TV and don't like sports, but I'm watching a fantastic basketball game: KY vs GA .http://logancustomcopper.com
            It's like the whole world's walking pretty and you can't find no room to move. - the Boss
            I married my cousin in Arkansas - I married two more when I got to Utah. - the Gourds
          217. JohnT8 | Jan 25, 2007 06:10pm | #73
            I think he must have better knees than I do.  I cringe at the thought of carting all that material up the steps.  Wouldn't even want to listen to my knees creaking up that flight of steps that much.  And you couldn't pay me enough to cart it up a ladder!
            LOL, I think I'll stick with my ranch project.  Only two steps.
            "Holding on to anger is like grasping a hot coal with the intent of throwing it at someone else; you are the one getting burned."-- Buddha
          218. Shep | Jan 25, 2007 08:26pm | #78
            He's still young.
            Forrest will start thinking about more machinery to lighten the load as he gets closer to 50.
          219. seeyou | Jan 25, 2007 10:25pm | #79
            Yuphttp://logancustomcopper.com
          220. User avater
            McDesign | Jan 27, 2007 02:11am | #90
            Shep <!----><!---->
            Jan-25 2:26 pm
            To:
            seeyou <!----><!---->
             (79 of 90)
            84041.79 in reply to 84041.57
            He's still young.
            View Image Options
             View ImageReply
            Jan-25 4:25 pm
            To:
            Shep <!----><!---->
             (80 of 90)
            84041.80 in reply to 84041.79
            Yup
            I feel like I'm overhearing two old-timers talk in the elevator at the home.
            No, I mean that wink, really!
            Edit - talkin about gas at twenty-five cents - gad!
            Edited 1/26/2007 6:46 pm by McDesign
          221. Shep | Jan 27, 2007 03:41am | #93
            With any luck, you'll be able get to our advanced ages.
            <G>
          222. MikeSmith | Jan 27, 2007 05:58pm | #97
            you might be able to live without a lift.. but you've obviously got a photographer on staff
          223. seeyou | Jan 27, 2007 06:58pm | #98
            From what I know of Forrest it's probably a tripod and a timer, both of which he built himself.http://logancustomcopper.com
          224. User avater
            Sphere | Jan 27, 2007 07:44pm | #99
            LOL...My thought too.
            Alls well here. Finally.
            The secret to a long life is knowing when its time to go.  M. Shocked
          225. MikeSmith | Jan 27, 2007 08:34pm | #100
            i thought that too, but i wanted him to confirm itMike Smith Rhode Island : Design / Build / Repair / Restore
          226. ANDYSZ2 | Jan 27, 2007 08:44pm | #101
            I figured it was the track car's cockpit camara with remote control and zoom features.
            REMODELER/PUNCHOUT SPECIALIST
          227. User avater
            McDesign | Jan 29, 2007 04:30am | #102
            Yes!  I built the camera from an old TV and a laser inferometer, using a Heathkit plan and some screen door hardware.  Oh yeah, and some Snapper Comet parts.
            Forrest - really, DW took the picture
          228. emmetnee | Jan 29, 2007 11:49pm | #103
            This is a really good thread, I've been following you're progress,  its going really well. You keep you're work area nice and tidy
          229. User avater
            McDesign | Jan 30, 2007 01:36am | #104
            Thanks!  It's easy when I'm "in", not way up "on" a roof.
          230. seeyou | Jan 30, 2007 01:38am | #105
            >>>>>>>>>some Snapper Comet parts. The worst riding lawn mower ever made. You crack me up, man. Any progress pics?http://logancustomcopper.com
          231. User avater
            McDesign | Jan 30, 2007 01:41am | #106
            Not today - clearing out all that old insulation and tracing K&T wires and measuring.
            Forrest - I loved Snapper Comets when I used to mow yards - especially the wheelies!
          232. seeyou | Jan 30, 2007 01:46am | #107
            >>>>>especially the wheelies!I forgot about that. They almost needed wheelie bars. That big single blade scalped badly. Most mowers of that size had twin blades.http://logancustomcopper.com
          233. User avater
            McDesign | Jan 25, 2007 02:33am | #55
            More pix from today -
            Finished flooring the main room, and built a bit of knee wall.  Temporarily covered the stairwell (right foreground) so I wouldn't fall into it.  The new wall will be built on the orange LVL and in the slot, on the downstairs top plates, a couple of feet inside the old wall. This will center the main room on the front-facing gable bay, and the dormer on the back.  Room is almost 37' deep front to back, and about 22' wide.
            De-skinned the last wall
            Took the last wall completely down, pulled all the old DW and insulation.  That chimney will be exposed in the bathroom or laundry room somehow.
            Looking back at the transverse wall I built last week, and the funny crooked chimney that will be the focal point of the room (plastered).  Come to think of it, I'M the focal point of a room when I'm plastered.
            Also filled the truck to the top of the cab, got to the dump without anything blowing out, and filled it up again just now.  So much nicer than a big 'ol dumpster tearing up the yard, and I can come back by the lumberyard with the next stuff
            Forrest - got a plan
            Edited 1/24/2007 6:36 pm by McDesign
            Edited 1/24/2007 6:45 pm by McDesign
          234. seeyou | Jan 25, 2007 03:42am | #57
            >>>>>>>>>>>Also filled the truck to the top of the cab, got to the dump without anything blowing out, and filled it up again just now. So much nicer than a big 'ol dumpster tearing up the yard, and I can come back by the lumberyard with the next stuffOn that note, I use a 12' dump trailer. I can park it in less space than your truck takes up and still have the truck available to pick up something I forgot if necessary. Ever busted a back window out of the truck throwing into it from the second story? Using your truck, you have to dump (or hand unload) before you can do anything else. You're strapped to that task 'til you complete it. I've never been to a dump that smells too good either. It's nice to roll in, open then tail gate, lift the bed, dump, drop the bed and drive away. It took me about as long to type this as it does to complete the task. Then I back haul supplies and can drop the trailer and don't have to unload right now.To cost this out, I have about 14K in my 45' boom and my dump trailer together. I've spent about 1K on maintenance in 2 years and I rent both pieces of equipment out on the few occasions that I don't need them. Keep giving us progress pics. I'm impressed with your skill and ethic. I just hurt too much to do it your way, and I know you've taken some hard knocks.http://logancustomcopper.com
          235. stevent1 | Jan 25, 2007 03:54am | #58
            Forrest,
            Nice progress. It's easy to get plastered when when one is the focal point.
            I may have misread, but why is the double LVL needed if it is resting on the top plates of a wall below?
          236. User avater
            McDesign | Jan 25, 2007 04:23am | #60
            The front part of the wall, that will rest on the LVL, is offset about 20" from the downstairs wall (between the entrance hall and library).  The back part of the wall, beside the stair, in that slot, does line up with a downstairs wall (between MBR and hall, so I'll just stud on top of that double top plate.
            Darned double LVL wound up being $166.
          237. User avater
            McDesign | Jan 25, 2007 04:18am | #59
            Now a dump trailer, I would flat LOVE!  Unloading at the dump's never that fast, much as I try.
            Someday I'll investigate a trailer.
          238. User avater
            davidhawks | Jan 25, 2007 04:48am | #61
            Looking good Forrest.  They've really got a dance hall up there don't they.  Had no idea that place was so big.
            I'll soon be shopping trailers myself, but not dump.  Around here the equipment operators at the landfills/transfer stations are always glad to hook to a strategically located chain wrapped around a timber and embedded in your load of debris.
            They just back up and the trailer is all but empty.  Did roofing tearoffs for years this way before buying my 1-ton dump.  Now I'm w/out trailer or dump.  Go figure.
            David...starting over.
          239. Piffin | Jan 25, 2007 02:51pm | #64
            Count me as impressed overall.But quit dreaming about that dumper and go get one. I figure I paid for mine in labour savings in two years or so.
          240. Hackinatit | Jan 25, 2007 03:30pm | #67
            You already have a dump truck...
            You just haven't installed the components that make it work.
            http://www.stealthdumptrucks.com/Troy Sprout
            Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it."-- Thomas Sowell
          241. User avater
            McDesign | Jan 25, 2007 03:46pm | #68
            I was just talkin' to DW about that very thing, moments ago.  Always been a dream.
          242. ravz | Jan 25, 2007 05:44pm | #71
            Love the work your doing, and love watching the progress.. Can you post pics of how the ends of the joists are supported? did you have to do any fancy notching? also, are you sistering the existing joists?  I saw in one pic all the ends of the new joists ending mid span, is there a bearing wall below at that point, or are you going to header off etc.. at that point?
            ThanksRav
          243. User avater
            McDesign | Jan 25, 2007 05:59pm | #72
            Thanks!
            The new joists all sit fully across the downstairs bearing walls top plates, and are just toenailed on.  All old joists are sistered; new ones are put in between.
            Once I established my "laser level" floor plane, I had to notch or shim both ends of all the joists.  I tapered the notches out, so as not to make a stress riser.  Given the number of joists and close spacing, there's not a lot of load on any one joist.
            The maximum I had to notch the 2x8 joists was about 1-3/16"; the maximum I had to pad one up was about 2-1/2".  Essentially, the top plates of the downstairs walls varied in the vertical plane by about 3-3/4" across the house.
          244. User avater
            McDesign | Jan 31, 2007 08:27pm | #108
            Finally got some pix to answer you!
            First, I set up the neat new rotary laser to a rigid point (Obviously I already did this, but bear with me.  On this job, I set the height of the laser at 6-3/4" above the level of the tops of the joists.
            Then I hold the tape at each place on the top plate that a joist will rest, and write down the measurement the laser shoots at.  I will then subtract 6-3/4" from that number, and that is the vertical height of the joist needed.
            I notch the bottoms of that number is less than a 2x8 ~7-1/4"); add shims if it's more than a 2x8.  This works because the old joists were notched over the plates, and the ceiling level is down about 1-1/2" from the top of the top plate.
            Here on the other side, which will be the laundry area, I have to hand load all the old insulation into bags to expose the area for measuring, and uncover hot (!) K&T wiring.
            Lots of 55-gallon bags - I spread it back before I put on the subfloor.
            Here is the bathroom part finished - these joist also had to be aligned to accomodate the plumbing - in soon.
            Edited 1/31/2007 12:28 pm by McDesign
            Edited 1/31/2007 12:29 pm by McDesign
            Edited 1/31/2007 12:33 pm by McDesign
          245. seeyou | Feb 01, 2007 12:38am | #109
            >>>>>>>>>these joist also had to be aligned to accomodate the plumbing - in soon.Just curious - you doing the plumbing also?http://logancustomcopper.com
          246. Shep | Feb 01, 2007 01:25am | #110
            I hope not.
            He's gonna start making me look bad soon. I don't know where he gets all that energy.
            Must be something in that Georgia water.
          247. stevent1 | Feb 01, 2007 02:05am | #112
            Forrest,As always, good looking job. What do you mean 'allign the joists for the plumbing'?Chuck Slive, work, build, ...better with wood
          248. User avater
            McDesign | Feb 01, 2007 02:16am | #113
            I had some flexibility in adding and sistering joists (exact placement, which side to sister, that kind of thing.
            I laid out the room and existing joists in ACAD, located all the plumbing fixtures, designed the DWV that would be under the floor, and then laid out my new joists.
            The fixtures are red, the walls are blue, the DWV is green, the old joists are black lines, and the new joists are fat gray lines.
            I'll have to make sure I tell the plumber!
            Edited 1/31/2007 6:16 pm by McDesign
          249. User avater
            McDesign | Feb 01, 2007 03:05am | #116
            Well, I had taken more pix for you today, anyway!
            Laundry area cleared out - last place to re-floor!  Note the joist propeller
            Hot knob and tube wiring under the loose-fill insulation.  The "electrician" is replacing it all with 12-2 Romex back to the panel.
            This is looking between the original ceiling and the lowered ceiling - exposed wire nuts to the box in the '70s lowered ceiling!
            Bearing condition at one top plate - had to notch the new joists
            Bearing condition at other end - had to shim the new joists
            Notching is never really a good idea, but at least I kept from having a stress riser.
            All installed.  The spacing scheme is that every other joist sisters an old one, at random position, every other one is exactly 2' OC.  blocks hold it until subfloor.
            Full length (32'), taken from down a wing that won't be floored, just used for HVAC mechanicals.  All this won't won't be floored, of course - just the parts from 50" kneewall on up.  Big room is to the left; laundry area is near, bathroom area is on the other side of the chimney, which will be left exposed.
            After the plumber and electrician finish, I'll pour all the loose fill insulation back in before the subfloor.
            Forrest - feelin' wordy tonight.  Must be the Valpolicella Valpantena - Ripasso.  Whatever all that means
            Edited 1/31/2007 7:06 pm by McDesign
            Edited 1/31/2007 7:07 pm by McDesign
            Edited 1/31/2007 7:08 pm by McDesign
            Edited 1/31/2007 7:09 pm by McDesign
            Edited 1/31/2007 7:11 pm by McDesign
            Edited 1/31/2007 7:13 pm by McDesign
          250. seeyou | Feb 01, 2007 02:31am | #115
            I used to be just like him and then age and gravity overtook me.http://logancustomcopper.com
          251. Shep | Feb 01, 2007 03:10am | #117
            LOL I know the feeling.
            I used to do almosty everything on a job- masonry, framing, to finish. Now some days I don't even want to pick up a bundle of trim.
            And to think you're still working with all that heavy metal
          252. User avater
            McDesign | Feb 01, 2007 03:25am | #118
            < some days I don't even want to pick up a bundle of trim.>
            Not sure what form of snide comment to make here.
          253. Shep | Feb 01, 2007 04:53am | #120
            HAH!
            I stumped Forrest!
            It's the little victories that can make me a happy guy.
          254. seeyou | Feb 01, 2007 04:47am | #119
            >>>>>>>>And to think you're still working with all that heavy metalI still listen to heavy metal. Most of the metal I work with is pretty darn light.http://logancustomcopper.com
          255. JohnT8 | Feb 01, 2007 06:13pm | #125
            There's one up your alley:
            http://forums.taunton.com/tp-breaktime/messages?msg=85033.1
            Maybe you could ship Sphere down there with a van load of copper.
            Wishing I could be like Forrest
          256. User avater
            Sphere | Feb 02, 2007 02:09am | #127
            Don't give him any ideas like that. Atthe time of your post he and I were out unloadingthe days project materials.
            It was nice and warm today, above 32 I think.  That heat in the Bayou would kill me.
          257. User avater
            McDesign | Feb 01, 2007 02:05am | #111
            <Just curious - you doing the plumbing also?>
            Umm - why?  I'll post some pix once the DWV under the floor is completed . . . by someone . . .
          258. seeyou | Feb 01, 2007 02:27am | #114
            >>>>>>Umm - why?Just wondering if you were doing everything yourself or if you were subbing anything. You answered my question. Have fun.http://logancustomcopper.com
          259. dug | Feb 01, 2007 06:17am | #121
            Forrest,
              As always, looking good.   Which laser do you have and how do you like it? I've been shopping for one, but I can't make up my mind.
               Funny, I fell like no matter what I buy, there will be a better one out in six months.
               Looks like we're gonna get some rain tomorrow, maybe I'll do some more searching.
                dug
          260. User avater
            McDesign | Feb 01, 2007 06:22am | #122
            I got this one - my first, but couldn't be happier with it
            http://www.amazon.com/Stabila-04100-Manual-Leveling-Rotating/dp/B00005V5NL/sr=8-3/qid=1170300055/ref=pd_bbs_sr_3/105-4957414-7584450?ie=UTF8&s=hi
            It can be set on its side, and has vials for that, to establish a wall plane - darned handy in an attic across the roof.
          261. dug | Feb 01, 2007 06:46am | #123
            Forrest,
              How hard is it to level? I've been looking at the self leveling lasers but, dang those things are pricey.
              dug
          262. User avater
            McDesign | Feb 01, 2007 06:50am | #124
            Pretty easy to level (couple of twirls of the little thumb wheels while you watch the vials), but you really have to put it on something solid - not a floor you're walking on, unless you're over a foundation or downstairs wall.  Those vials are sensitive!
            The really funny thing is, you're crouched over it, leveling it, get it just right, turn it on to make sure the rotation motor doesn't throw it off, and THE VERTICAL BEAM GETS YOU RIGHT IN THE EYE!
            Forrest - seeing green spots
          263. User avater
            davidhawks | Feb 02, 2007 01:57am | #126
            Didn't you use your laser to establish the floor height in the attic?
             I just picked up a fixer-upper in Statesville that has floors undulating like the North Atlantic.  How can I set up a laser--given the presence of interior walls--to help me locate a benchmark to start from?
            Fixing the up and down in the floor shouldn't be too tough once I figure out where to begin.  The floor system is typical Southern style pier & girder w/brick curtain wall @ perimeter.
            Thanks,
            David
          264. theslateman | Feb 05, 2007 11:25pm | #128
            Forrest,
            Have you had a camera tripod malfunction?  We haven't been treated to any work shots lately.
            Don't expect to build us up like this and have to go cold turkey!!!!
            Walter    horsing around a little
            Roofers get bored with 20 below wind chills.
          265. User avater
            McDesign | Feb 08, 2007 03:25am | #129
            Okay - catch up time.  Beautiful here today - felt like spring.  Work has been slow, this has been like putting together a Chinese puzzle!  I (the plumber, I mean) needed to frame and floor enough to get all the supplies and DWV in, while still allowing access in case the pressure checks show up anything.  Finally figured it out.  Also, had to put in wires to rewire the removed scary K&T wiring (the electrician, I mean)
            Here's the toilet to the left, and the shower to the right.  Will be a normal 32x60 steel tub, tile surround.  Venting goes around the room to vent out the rear roof plane.
            Here you can see the large opening for the 3' X 7' pocket door, and the small opening that may be later opened up for a door.  The bath is to the left; the laundry is to the right.  There is no dividing wall; the skylight (to come) is in the rear roof plane (upper right), and will be the only natural light in there.
            Notice how the chimney is just out there in front of God and everybody!  I think it will be cool, and matches the one in the main room.  They both will be plastered with my "hand" technique, where I Hy-Bond the surface, and rub in Durabond by hand.
            Here's a closeup of the laundry box - collected vent line is starting up the roof pitch.  laundry box is high; to be over the washer.  This one may spend a lot of time "off".
            The far end; HWH will be here, and the pressure gauge and valve for the duration of the construction (like to have air in all my lines while I'm nailing!)
            This pic is standing back to the tub, showing the little pass-through behind the chimney where you'll see the side of the washer.  Pedestal lav sits centered on the chimney; supplies and waste through floor - through an S-TRAP!  Hah-hah!
            Here's a close-up of underfoot as you walk in the door to the bathroom, and the drain manifold.  Toilet comes from lower left, tub from middle left, lav from center, and washer from upper right.  Main drain drops down in front of chimney, in an existing chase beside the chimney, down through the first floor into the crawl.
            Pressure test it all tomorrow, finalize and cushion all the pipe supports; do some more framing; pour all the old loose fill insul back in the floor, and put in subfloor maybe Friday.
            Forrest - ready to play with the roof framing!
            Edited 2/7/2007 7:31 pm by McDesign
            Edited 2/7/2007 7:33 pm by McDesign
            Edited 2/7/2007 7:37 pm by McDesign
            Edited 2/7/2007 7:39 pm by McDesign
            Edited 2/7/2007 7:41 pm by McDesign
            Edited 2/7/2007 7:46 pm by McDesign
          266. theslateman | Feb 08, 2007 03:36am | #130
            Forrest,
            It's looking really good!  Will it be sheetrock or plaster?
            Do you clue your clients in to these threads?  Or is it too risky with all the loose cannons rolling around the deck?
            Thanks for the update    One candle couldn't have been too tough  !!!
          267. User avater
            McDesign | Feb 08, 2007 03:48am | #131
            Thanks - it will all be sheetrock - it's just an attic, after all . . .
            I do share the threads with clients, if they've got a good sense of humor - everyone has, so far!
            Forrest - ate the last slice of pie just now
          268. theslateman | Feb 08, 2007 03:53am | #132
            They must wonder about some of your "cyber associates"
          269. Shep | Feb 08, 2007 04:21am | #134
            Hey, Forrest-
            I read in the latest issue of JLC that you folk in Georgia are going to have to be liscensed by Jan., 2008.
            Is that going to affect the kind of work you do?
          270. User avater
            McDesign | Feb 08, 2007 01:28pm | #136
            I'll take the test and get the license for one of the three categories - no problem.  I had gotten all the paperwork to exempt myself from taking the test, but . . .
            Kinda' figured it wouldn't be sporting, and none of the other established guys would have taken it, so I'd be "better"!
            Probably raise prices - anything that raises "barriers to entry" does that.
            Forrest - now I've gotta' study
          271. Hackinatit | Feb 08, 2007 04:17am | #133
            Jeez! Sniffin' all that glue for both supply and waste lines and no windows...
            If you'd had more candles to blow out, you may have 'sploded. ;-)
             Troy Sprout
          272. User avater
            davidhawks | Feb 08, 2007 05:15am | #135
            Your DWV and H&C look great Forrest.  It's so good to see someone who takes pride in EVERYTHING, not just the "money view".
            Keep up the great work.
            David
            BTW, can you send some of those temperatures about 400 mi. north please?  11 deg. this AM.  Never saw 40 today.  Yea I know, there's a roofer in Maine would kill for 40.
          273. theslateman | Feb 08, 2007 04:10pm | #137
            David,
            As one roofer in Maine 40 would be really up there.  After an incredibly mild Nov. ,Dec., and ealy Jan. we've been really blasted with cold temps.
            Our highs this week will be teens with lows of 5 to 15 below.
            Hope you get a warm up  too.
            Walter
          274. stevent1 | Feb 08, 2007 04:12pm | #138
            Forrest,
            Looks like a thorough job. Keep up the good work. Tell us more about that plaster technique when you apply it.
          275. theslateman | Jan 25, 2007 03:58pm | #69
            Troy,
            Thats a great link to a great looking product.  Thanks.
            Walter
          276. Hackinatit | Jan 25, 2007 05:17pm | #70
            Even better for the DIY Dump bed
            http://www.dumpbeds.com/Troy Sprout
          277. JohnT8 | Jan 25, 2007 06:43pm | #75
            I haven't looked in a while (I'm truckless at the moment anyway), but last time I looked, I think they ran $2-10k.
          278. seeyou | Jan 25, 2007 07:56pm | #77
            http://www.appalachianmfg.com/DUMPERPAGE.htmHere's the trailer I have - I paid $3500 for it about 2 1/2-3 years ago.http://logancustomcopper.com
          279. JohnT8 | Jan 25, 2007 06:42pm | #74
            So would you guesstimate around $500/yr for the maint cost of the boom?  That is with steady use?
            BIL and a couple of his neighbors with tall houses have considered purchasing a group boom.  One of them has a building to store it in, and they live close enough together to not need a trailer (small town).
            LOL, I'm just sorry I missed them filling the last rental boom up with diesel.  They drove it down to the station and filled 'er up.jt8
          280. seeyou | Jan 25, 2007 07:54pm | #76
            >>>>>>$500/yr for the maint cost of the boom? Yeah - so far. I've had one repair bill for about $600 which included an oil change and a tune up (plugs and wires). I've put a new battery on it and had a flat tire. I'm waiting on a part (kill switch on the dash is bad and one of the joysticks is getting sloppy so I'll replace it), but for a 10 year old machine it's been fairly trouble free. I haven't had it quite 2 years yet.We run ours down the road if there's a gas station nearby. My advice to the BIL is to get a 4x4 if it's gonna be off the pavement any at all.http://logancustomcopper.com
          281. User avater
            Sphere | Jan 26, 2007 12:21am | #80
            Hey, we fixed that Joystick at Delight's with Geocel and a rivet shank..you mean you really had it fixed by a pro?
            Damm..we failed. ( sniff).
          282. seeyou | Jan 26, 2007 12:46am | #81
            It's not fixed yet - I've ordered the part and I'll swap it out.http://logancustomcopper.com
          283. User avater
            Sphere | Jan 26, 2007 01:51am | #82
            Man, speaking of swapping out parts..I ain't doing well with the new meds. Day 7.  I might be a maybe for the AM if I can't shake this feeling of unwellness.....I am in flux.
            Funny that Forrest's thread is Attic Recovery, that is where I am..now where did I put them toys?  That was an aerosmith allusion if I was obtuse.
            Damm, I ain't well. I wish it was the flu, but I know better,,,I feel nauseous and energetic at the same time..a walking puke.
            Time to get all the red Lego's in a row, and the blues in a short pile...and send the yellows to the wifes nostrils.
          284. User avater
            McDesign | Jan 26, 2007 02:58am | #83
            Not to pull you off subject (!), but i did work in the attic today.
            Design work this morning; planning the bathroom and laundry that will eventually be on the other side of this wall.  Had to get an idea so I could frame in the door openings in this transverse wall.  Tons of measuring and little pieces!
            The 6' wide opening is for a pocket door (old 3'x7' Victorian door; panels removed and replaced with frosted glass; passageway biased toward the left.
            The smaller opening will go directly into the adjoining laundry room once the stairs are moved back, to the right - a later project; I'll just drywall over the opening now.
            Edited 1/25/2007 6:59 pm by McDesign
          285. User avater
            Sphere | Jan 26, 2007 05:08am | #84
            Well....Ok, but I still hate you. (G)
          286. User avater
            davidhawks | Jan 26, 2007 05:52am | #85
            I can't believe that ceiling fan is still living up there.  You must be a finesse guy too.  I think it comes with age.  Scratch that--MATURITY.
            Still looking good.  What about the LVL's where they run into that doorway?
          287. User avater
            McDesign | Jan 26, 2007 01:30pm | #86
            I'll notch the LVLs wher they cross the doorway.  Not ideal, but at least it's in the first 3', and not in the middle.  Will still have plenty of meat under the notch - like 8-1/4".
            Ceiling fan was fun - i just broke the rock out around it; hope it didn't crash - not yet, anyway!
          288. Snort | Jan 26, 2007 05:01pm | #87
            Wow, a laundry room on the third floor! You'd better leave your stairs for washer and dryer replacement, ha.Thanks for the reports, it's an intersting project, and so neatly kept, too<G> "But to be honest some folks here have been pushing the envelope quite a bit with their unnecessary use if swear words. They just put a character in to replace a letter. But everyone knows what they're saying." Sancho
          289. User avater
            McDesign | Jan 27, 2007 02:00am | #89
            Here's some more - I swept for you, even.  After finding the bag full of money, even.
            Finished framing the last (NW) corner.  Joists had been cut; were sitting on the door frame!  I bridged them to good structure.  I'll move that downstairs door back 2-3' to enlarge the stairwell a bit.
            Just cuteness picking up the old rafters - fun framing, drriven in tightly.
            This is a view looking in the front tripartate windowacross the full 38' ballroom expanse at the new French doors.
            And this is looking the other way, in the doors at the front window
            This is the area for next week - a full bath and laundry room go here.  i mean, like, once it has a floor and walls and all.
            Edited 1/26/2007 6:03 pm by McDesign
            Edited 1/26/2007 6:04 pm by McDesign
            Edited 1/26/2007 6:06 pm by McDesign
            Edited 1/26/2007 6:07 pm by McDesign
            Edited 1/26/2007 6:09 pm by McDesign
          290. Snort | Jan 27, 2007 02:20am | #92
            You sure Santa isn't stuck in that chimney?Sure looks bigger when it's cleaned up<G> "But to be honest some folks here have been pushing the envelope quite a bit with their unnecessary use if swear words. They just put a character in to replace a letter. But everyone knows what they're saying." Sancho
          291. theslateman | Jan 26, 2007 05:24pm | #88
            Forrest,
            You could use better lighting than that head banger provides!
            Makes us all realize what our attics could become.  Thanks!
            Walter
          292. User avater
            McDesign | Jan 27, 2007 02:13am | #91
            Pulled the fan down today.
            The exciting news is, I showed the client this issue of FH about the curved ceiling, and they want a serious quote for that curved ceiling up there!
            Hot dang!
            Forrest - working on it now
          293. stevent1 | Jan 27, 2007 03:49am | #94
            Forrest, Curved ceilings are not to tough. Talk the owners, your neighbors, into a vaulted/compound curved ceiling with an eyebrow dormer.That is a massive attic. I know no structural permit is required but how about the electrical before close-in?Chuck Slive, work, build, ...better with wood
          294. User avater
            davidhawks | Jan 27, 2007 06:00am | #95
            Which issue #???
            I've got one about 15 years old that outlines the eyebrow Chuck's referring to.
            Seems like I also remember one on an expansive barrel vault.
          295. User avater
            McDesign | Jan 27, 2007 04:15pm | #96
            The new issue that just came - it's a flatter vault.  Bent 1x4s to hide a deep structural ridge beam.
            I know the one you mean - a barrel vault with coffering built up with layers of 1X.
            I'll put regular Velux skylights on the back - no eyebrows . . . sigh
          296. theslateman | Jan 25, 2007 02:20pm | #62
            Forrest,
            I'd say your plan is working out to a T.
            I think the stairs were a great idea- just glad I'm not the one hauling all those materials up them!
            My reference to Grant about ladder lifts dealt with bringing my materials up and down- it's not applicable for your job here.
            Thanks again for another informative, well done thread.
            Walter
    McDesign | Feb 09, 2007 01:39am | #139
    Whew - hit the wrong button!
    Another beautiful day!  a little cooler, but sunny - I thought some up your way - I heard Oswego, NY got 7 FEET today, with 3 more to come.
    Finished the last corner of the laundry room; framed access doorways for the two unfinished attic areas.
    Client might floor this one for unconditioned storage
    HVAC goes in here
    Hand excavated mountains of old insulation to expose the last of the hot K&T - darned dramatic to be under 8" of 'glas.
    Scary stuff! Gotta get the 'lectrician right on that tomorrow
    Hey hon', can you add a switch to darling's overhead?
    Here's where the wires drop down to the '70s 200-A panel
    Hey, I pressurized my supply system today (the plumber's work) AND IT LEAKED DOWN!!!!!!!!!!1
    Then I realized by some selective isolation that my cheapy gage was leaking!  Hope that's all - get one tonight
    Forrest - itchy
    Edited 2/8/2007 5:43 pm by McDesign
    Edited 2/8/2007 5:44 pm by McDesign
    Edited 2/8/2007 5:45 pm by McDesign
    Edited 2/8/2007 5:46 pm by McDesign
    Edited 2/8/2007 5:49 pm by McDesign
    1. JohnT8 | Feb 09, 2007 01:41am | #140
      insert the pics already.  Sheeze, don't make me OPEN them myself!
      "One of the fondest expressions around is that we can't be the world's policeman. But guess who gets called when suddenly someone needs a cop." -- Colin Powell
    2. JohnT8 | Feb 09, 2007 01:46am | #141
      Sheeze, that wiring is enough to make you wear rubber gloves.  Sure gotta be careful how you scoop the fg up!
        McDesign | Feb 09, 2007 01:50am | #142
        < wear rubber gloves>
        Yes!  I got bitten twice.  Didn't do my usual, which is to snap my head up and impale my scalp on a roofing nail!
        1. JohnT8 | Feb 09, 2007 01:53am | #143
          ouch.  Wonder how the place kept from burning down.
          Since I'm not a pro, could you go into more detail on how you're pressurizing your drains?
            McDesign | Feb 09, 2007 02:02am | #144
            Haven't done the drains yet, because I have to get the bottom drain leg through the first floor, and cut into to their library wall - company this weekend, so Monday maybe.
            Basically just glue KO plugs or expanding plugs in everything, cap the roof vent, and put ~10 psi in it for a day or so.  Haven't ever had a drain leak.  The only supply side leaks I've ever had were at threaded connections.
            Forrest - I mean the plumber
