Attic remodel
butcher | Posted in Construction Techniques on January 18, 2003 07:56am
I have friends who purchased a house that was built in 1910.  It has an open attic space that they want to finish into a family room.  It has dormers on each side.  The rafters are the old style 2 x 4’s, 16 inches on center.  There was a pony wall added later to help support the rafters.  The dormers were only for dressing and the rafters run through the dormers.  My question is, how do I run a header to attach to the rafters so that the dormer can be used?  How do I take down the pony wall and still provide support for the rafters?  I need to run a header on the attic side of the dormer to attach the rafters to, so that the dormer space can be used.  Any advice would be greatly appreciated.
                                                              Cutter
  1. Piffin | Jan 18, 2003 08:07pm | #1
    You probably need to sister 2x8s to the 2x4 rafters to make them strong enough to handle the load, and to create enough space for minimal insulation. A doubled 2x8 at either side of the dormer might handle the transfered loading.
    Your biggest problem will be the heating/insulation/ventilation/condensation problems that make it look like you have created a leak in the roof two moinths after you finish.
    What about the floor framing? If might sag if not beefy enough.
  2. r_ignacki | Jan 20, 2003 02:58am | #2
    cut the entire roof off and throw it out.
    New rafters, sheathing, roofing, etc etc.. while you're at it, fix the chimney.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
