Attic wiring
ward121 | Posted in General Discussion on August 23, 2012 12:03pm
  As part of a remodel, I need to rewire the ceilng lights in a 1947 cottage.  Curantly there are 5 lights and I plan add two more.
   The wire is old cloth covered with no grounds.  It runs under the ceiling joist, laying on the ceiling. I have  found three staples so far, so removing it will be simple(cut and pull).
   The wiring forms a loop from one fixture to the next around the attic. I thought of just recreating this but don’t love the idea of drilling holes through the joists and digging in all the insulation.
  Instead I thought I would run along the ridge (where the attic light is) and branch off along the rafters towards the the new fixtures. Providing a 2×4 post where the wire will drop down to the ceiling. The ridge height is only 5 feet. and the space is not used for anything.
  Having crawled around in a few attics (not sure why I always get that job?) I don’t recall ever seeing this done before.
 I really like the Idea of most of the wiring being visable and all the Junction boxes being accesable.
 Any thoughst???
Ward
  1. DanH | Aug 23, 2012 10:37pm | #1
    The only disadvantage of your scheme is that you will need more wire and junction boxes.
    1. ward121 | Aug 24, 2012 12:12am | #2
      That works
      Wire and boxes I've got.  Thanks
  2. ward121 | Aug 24, 2012 12:15am | #3
    back bone with branches
    Love the name! Thanks
  3. Geoffrey | Sep 02, 2012 01:35am | #4
    or... use the old wire as a snake to pull the new wire through as you remove the old
    1. ward121 | Sep 02, 2012 06:23pm | #5
      Old wire location
      Is part of the problem.  It is just laying on the cieling and just hangs across the attic stairway.
Outdoor Lighting
