Auxillary Fence Idea for All Y’all
basswood | Posted in Tools for Home Building on November 4, 2006 05:20am
I’ve been making my add-on fences for my SCMS and table saw out of rips of MDO plywood. Light, strong, straight, smooth, and great for writing on. I can make notes on the fence for a variety of precise measuments.
MDO handles weather pretty well too (for those outdoor set-ups). I use both 1/2″ & 3/4″ MDO depending on the situation. Some of my fences are “L-shaped” (with both aux. fence and aux. table) for the slider.
I left my stuff on the job this weekend, I’ll take some pics next week & post ’em.
  1. wrudiger | Nov 04, 2006 06:56pm | #1
    Saw your post in the other thread and wanted to ask you about your fences.  My SCMS is bolted into a table in the shop, with extended low fence to accomodate a sliding stop, so I don't have room for the factory tall fence.  It hasn't been a problem yet, but one of these days...   Looking forward to the pics!
      basswood | Nov 04, 2006 07:49pm | #2
      The fences I make are fairly ordinary, but the MDO is a good material to use...just wanted to encourage people to give it a try (without hijacking the other thread).My crown jig/fence is worth posting a photo of though (in the next week or so).
      basswood | Nov 16, 2006 06:36am | #5
      Here is the crown jig I made for 4-1/4" and smaller crown. It holds the crown at the proper angle for "upsidedown & backwards" cutting. The fence and curb are 3/4" MDO and the table is 1/2" MDO. The curb is screwed on to the table with 1-1/4" pocket hole screws. For smaller crown, I slide spacers behind the curb.The fence is 3-1/4" tall and has close to zero clearance so small pieces are thrown less. As pictured, I sometimes use Collins miter clamps on the set up. The jig is also nice for cutting small base, casing and other moldings like base shoe, etc.I sometimes put a filler where the table gets cut out, to keep small pieces from dropping in.The last picture is of a crown return I did today...based on something I saw at BT.
      1. wrudiger | Nov 16, 2006 08:30am | #6
        Thanks for sharing!  The best solutions are often the simplest, aren't they?
          basswood | Nov 16, 2006 03:42pm | #8
          --"Thanks for sharing! The best solutions are often the simplest, aren't they?"You're welcome. Simple is good. The jig also holds crown nicely for coping.
      2. nikkiwood | Nov 16, 2006 10:25am | #7
        That crown end detail is terrific............Is that snow on the ground? No snow here............. yet.********************************************************
        "It is what we learn after we think we know it all, that counts."
        John Wooden 1910-
          basswood | Nov 16, 2006 03:58pm | #9
          I really like that crown detail too...I ripped that idea off from someone here. It was made easy by:*poplar crown...nice to work with
          *23 ga. pinner
          *Collins miter clamps
          *"the jig"That jig makes cutting those itty bity return pieces go very smoothly. I can also use the jig to hold all the pieces together while I glue and micropin the return. Then I slide the return end of the crown assembly down so it is flush with the end of my jig and I pull my tape off of the end of the jig to mark my cut at the other end. That way I know exactly how long that run of crown is. So basically, I start at the end...rather than ending there. <g>Yup that is snow, we got about six inches here last Friday.
          1. nikkiwood | Nov 17, 2006 03:21am | #10
            I have a similar jig that I use for crown. Only mine uses a 3/4" base, which provides enough thickness so I can through-cut the crown without cutting all the way through the base. And my curb is 1/2" baltic birch about 2" wide, with slotted holes (with pan head screws) so I can adjust the curb to the size of the crown I am working with.Do you use the regular Collins clamps, or do you have their pliers?What do you use for coping?********************************************************
            John Wooden 1910-
            basswood | Nov 17, 2006 04:40pm | #11
            I've done jigs with a 3/4" base too...sooner or later I forget to set the blade height and one 8' jig becomes two 4' jigs. <g>I have the pliers for the Collins clamps. I just bought the clamps at the JLC Live two months ago and I am finding new uses for them all the time.If I have just a few joints to cope I use my coping saw. Otherwise I use a jig saw or grinder (depending on what is at hand).
  2. estacado | Nov 15, 2006 08:58am | #3
    wheres the pictures?
      basswood | Nov 15, 2006 04:12pm | #4
      I'll take some today...been stuck in demo & drywall mode on two kitchens. Yesterday it was finally back to trim and today I will get to install 60' of crown using a jig on the saw.
      1. estacado | Nov 18, 2006 08:16am | #12
        Looks like a good jig. thanks!
