Has anyone seen the vid clip of the Bobcat attachment that has the log cutter and splitter in the same unit? Very cool. I couldn’t attach it to this thread as its 4 mb in length but can send it to anyone if they want to see it.
Use tinyurl.com
That will change it into a short one.
Bill,
Good idea but its an .mpg
Mike
That should not make any difference. It just takes the URL and saves it and generates a short one.When you click on the short one the site redirects you automatically to the real URL..
Bill,
What he's saying is that he received the file, not the link. So he had to upload the whole 3mb file if he wanted to post it.
Got it now..
A log Cutter????
Here is a screen capture from the vid clip.
I got the video in email today and it is pretty cool . I thought abought trying to make one for my bobcat.
This one??
http://www.tetongravity.com/forums/showthread.php?t=158220
Pretty cool
YEAH! Thanks Boats! Is that cool or what?
I wonder if its a production item or did some custom make it? Either way cooler than hell!
That is pretty cool.I could have done without the video being 4:15 long. After the first few times, I think I pretty much had the concept down. I kept waiting for something new and exciting to happen, but no dice.
Wow, gotta' get me one...............gotta' build a big fireplace & BBQ pit so I can tell the DW I NEED one.
I'm not flippin' you off.........just counting cubits
That may possibly be the coolest thing I have ever seen.
Makes me want to go buy a skid steer just so I can buy one of them!
Shawn
Checker Contracting - SE Michigan
I've got one I'll sell ya!
You could always get a big one.
http://www.timberwolfcorp.com/firewood_processors/video.asp?id=3
Or this monster.
http://www.youtube.com/watch?v=7iqvBHAVoeY&feature=PlayList&p=3CDA83D83956CFF6&index=20
Someone sent me a movie file that I can't find on the web, but this is close to it.
Check this out:
http://www.youtube.com/watch?v=qK_nUgO7iuE
http://www.youtube.com/watch?v=1fI0CGVNmwQ&NR=1
Toys, gotta love em No one should regard themselve as "God's gift to man." But rather a mere man whos gifts are from God.
I agree as I thought the same thing!!! And I live in Florida where firewood is not a prime commodity!
Now if only they could come up with a similar attachment to open those plastic clamshell packages....-t
from the vid looks factory... since it's their website I'm guess'n they'd sell you one...
that thing is cool...
count the actions...
loads the logs with tongs/forks
power feed of the log
power stop to stop the log
powered spliter wedge that goes up & down to get equal splits per size log...
power to run the saw...
power to plung the saw....
with one power take off on the bobcat (hyd) and all i can do is control the flow... high & low and reverse...
you'd need dc powered valves and a control box in the cab of the bobcat to operate it...
if you can build a single function machine... then I'm say'n you could build a multi function one also...
I think with enough time and watching the vid enough times I believe it's not that complex... yeah i think you can build one... just post pics
p
your machine must be older? mine has plenty of switches for all those functions.
for real? i have a 2001 753 bobcat... it has a couple switches... but with only one set of aux hyd. fittings the only thing you can control (without wires) is the flow in & out forward & reverse hi & low flow
btw i have thought about the spliter.... you could build it in stages....the first function is the split... then i'd add the adjustable height on the splitting wedge... then the log grab & feed & cut
yep.... now if i had a need for firewood... i'd think about it more
:)p
mine has 4 switches at each hand and in and out flow also i misunderstood you and thought you would have to put extra switches inside with you i'mpretty sure you should be able to plug in and use the switches already there.
btw... i have an extra larger concrete mixer... without a motor... i'm just waiting til i have the time to convert it to hyd... so i can mount it on the bobcat and save a step... mix & dump... i also have a power broom for a 3 point hitch... that i need to build a mount for the bobcat... just another project ... or 2
p
