Azek Fascia Trim.
blownonfuel | Posted in Construction Techniques on January 8, 2009 06:03am
Hello. I would like to add a decorative fascia to our addition and was looking at using Azek. Does the trim come in this shape or does it have to be built up from different pieces? I attached a pic. from the Azek website. If it is a single piece can you tell me what it is called and if not a single piece how can it be made?
  1. Pelipeth | Jan 08, 2009 02:15pm | #1
    I believe that's a stock Azek profile of crown molding.
    1. blownonfuel | Jan 08, 2009 04:10pm | #2
      Pelipeth is that just added on top of a flat piece of Azek? Crown moulding over flat?Thanks
      1. Pelipeth | Jan 09, 2009 03:42am | #15
        Yes, most likely 1x8.
  2. MikeSmith | Jan 08, 2009 04:18pm | #3
    it's a two-piece
    it's crown on 1x
    probably about 2 1/2 crown  on 1x8  .... the 1x8  could be 1x4 because that is all you see
    notice that they are using  colored aluminum drip edge on both the rake & fascia... that's what we do also... but it hides the top of the crown
    also.... Azek  has a high expansion rate  so you would  probably want to glue your crown miter but allow a scarf joint slip detail on both the eave and rake run
    1. blownonfuel | Jan 08, 2009 05:47pm | #4
      Thanks Mike. I assume this same look can be done with wood crown moulding?Does the roof sheathing run all the way to top of the crown or is it just the drip edge that goes over it?
      1. MikeSmith | Jan 08, 2009 09:08pm | #5
        the crown can run  flush with the bottom edge of the plywood sheathing
        or plane into the top edge of the sheathing.... the drip edge will cover  more  ....or less
        you have to  decide....
          build a mock up to help your decisionMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
        1. blownonfuel | Jan 08, 2009 10:10pm | #6
          I can't find anyone in my area that has even heard of Azek much less having it in stock. Can I just sub pine moulding for the Azek?
          1. frammer52 | Jan 08, 2009 10:14pm | #8
            you can probably get away with that in Texas.  Maybe our Texans can respond!
            Mike and I live in the Northeast where we worry about rot.  That is why we love azek
            Edited 1/8/2009 2:15 pm ET by frammer52
  3. JohnCujie | Jan 08, 2009 10:12pm | #7
    I built an "L" shaped piece, the vertical being the fascia and the horizontal a 2X extended about 1/2" past the crown mould. That way the drip cap goes on the 2x and the entire crown mould is seen.
    I tacked the crown mould in the "L", cut the whole assembly to length with my slider, removed the crown mold, attached the "L" to the subfascia, then installed the crown mould. A perfect fit.
    Wish I had pictures, best fascia I ever did.
    John
    1. blownonfuel | Jan 08, 2009 10:16pm | #9
      Great tip John, thanks. Was this all in wood?
      1. JohnCujie | Jan 08, 2009 10:19pm | #10
        Yes. About 10 years ago, all clear heart KD redwood. From Beronio in SF, not sure where you are. Who knows the cost now.John
        1. blownonfuel | Jan 08, 2009 10:28pm | #11
          Texas John. I'm pretty much stuck with pine.
          1. MikeSmith | Jan 08, 2009 10:31pm | #12
            sure...you can use pine......  it's been used  for crown for about 300 years
            just make sure you backprime it and  keep the water out Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
            mmoogie | Jan 08, 2009 10:39pm | #13
            >>it's been used for crown for about 300 years<<Even longer if you count those folks across the pond ;-)
          3. blownonfuel | Jan 08, 2009 11:10pm | #14
            Thanks Mike.
Old House Air-Sealing Basics
