Backer rod
jyang949 | Posted in General Discussion on November 6, 2007 12:34pm
I’m recaulking the top edge of the bathtub. The old caulk and loose grout are gone, but the gap is too large to fill with caulk alone.
The largest section of gap is 3/16″ across and 3/8″ deep, and the rest is not much smaller. I couldn’t get the backer rod (3/8″) to fit into the gap.
One website said that
(a) caulk should adhere to the sides of the gap but not the bottom. Too much contact area leaves the caulk less flexible and more likely to pull away from the sides.
(b) as it cures, caulk shrinks and is released by the backer rod, leaving just two areas of contact for more flexibility.
Assuming that’s true (but I haven’t heard it anywhere else), what else can be used in the gap? Should I backfill it with grout or mortar?
Janet
  1. FastEddie | Nov 06, 2007 02:03am | #1
    You can buy foam window or door weathrstripping, usuallu square section and black, at HD & Lowes.  Leave the paper backing on and push it into the gap with the paper and sticky side ttoward the back.  They are correct that you only want the caulk to adhere to two sides, and not fill the groove.
  2. JTC1 | Nov 06, 2007 02:35am | #2
    What Fasteddie said provided you cannot find 1/4" backer rod.
    PLUS, once you have the caulk backer in place -- fill the tub with water and stand in it while you caulk.  Leave water in tub while caulk cures.  Drain water.
    Caulk compresses better than it stretches without breaking any bonds.
    Jim
  3. JHOLE | Nov 06, 2007 02:43am | #3
    I agree with the other posts.
    But this is important - what are you using for caulk?
    Remodeling Contractor just on the other side of the Glass City
    1. jyang949 | Nov 06, 2007 03:31am | #7
      I just bought "DAP¯ KWIK SEAL PLUS¯ Premium Kitchen & Bath Adhesive Caulk w/MICROBAN¯", solely because it was available in tints. I also have GE Silicone II in clear and white, but decided not to use them. Clear would show the gap (or its shadow) and white would make the uneven edge of the tile more noticeable. Can I layer different types of caulk? That is, use the tinted caulk to camouflage the backing and uneven edges, topped by silicone caulk because it won't mildew.
      1. DanH | Nov 06, 2007 03:41am | #9
        You generally can't get one caulk to stick to another, especially with silicone.
      2. DaveRicheson | Nov 07, 2007 02:30am | #10
        Look in your Yellow pages for a concrete accessories supply. The places that sell rebar, wire mesh, sono tubes, cur'n seal, etc. Not your local big box or hardware store. The supply source  will have backer rod from 1/4" to 1 1/2" or larger in 1/8" increments, and sell it by the foot.
        I always buy more than I need cause it is so cheap.
        Anyone come up with a decent storage method for unused backer rod?
        Dave
        1. dovetail97128 | Nov 07, 2007 02:32am | #11
          Large freezer bags. Zip locking, place to write the size on. Will hold about 25' depending on diameter.
          1. calvin | Nov 07, 2007 02:36am | #12
            That's much better than my system that in fact does work pretty well.
            In a full sized garbage bag place the half dozen coiled like climbing rope bundles of backer.  Fold the air outta the bag and slide (push) this package on left rear side of van, back behind the AdrianSteeler tool cabinet.  Keeps the drywall square pole sander stuffed in there from rattling around.
            thanks A great place for Information, Comraderie, and a sucker punch.
            http://www.quittintime.com/
          2. DaveRicheson | Nov 07, 2007 02:55am | #13
            Thanks for the tip.
            I use ziplock freezer bags for lots of odd ball parts, just never thought of the larger size for backer rod storage.
            Dave
          3. JTC1 | Nov 07, 2007 04:04am | #14
            Dave,
            Dovetail has it right.
            Bags don't have to be the 2 gallon size though could be.
            I use 1 gallon size for 25' - 50' of 1/4", 3/8" or 1/2".
            Jim
        2. jyang949 | Nov 07, 2007 08:10pm | #15
          > concrete accessories supply will have backer rod from 1/4" to
          > 1 1/2" or larger in 1/8" incrementsThanks, Dave, that's what I'll do. Janet
  4. DanH | Nov 06, 2007 03:02am | #4
    Yeah, what you read is entirely true, and understanding it is key to getting a good, reliable joint.
    Any flexible material will work for backer -- you could stuff tissue in there if you wanted.  But foam is better since it's less apt to mildew/rot if a little moisture gets through.  As stated, weatherstripping foam is one option, as is simply slicing the rod with a razor blade.
    1. FastEddie | Nov 06, 2007 03:06am | #5
      Maybe he's not allowed to use sharp tools.  but that's a great idea.  Wish i had thought of it."Put your creed in your deed."   Emerson
    2. jyang949 | Nov 06, 2007 03:22am | #6
      I thought that the rod had to stay intact...something about the closed cells staying that way.
      1. DanH | Nov 06, 2007 03:40am | #8
        Nah, you can let a few prisoners escape.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
