Backfilling ICF – Updated Post
billd60 | Posted in General Discussion on May 12, 2006 04:03am
I should have been much more specific since you guys know your stuff!  I have already applied the ARXX membrane from footing to the top of my walls and backfilled with bank run gravel.  All is great there.  I am trying to address the area between siding and finish grade and ahven’t been real excited about the parge coat idea.  I have a brick ledge but also look at the prospect of ALL THAT cultured stone as more than daunting.  Any ideas on a material I can fill against that will also provide a good looking transition from siding (cf) to grade?
  1. CRF | May 12, 2006 06:20pm | #1
    So you are asking how to finish the white of the ICF block from the finish grade up to the siding transition?
    I have not got to it yet, but on my own ICF I plan to do some of the cultured stone and also some scratch/parge coat where the stone is not needed (under the deck, etc).
    If you decide on the scratch coat you can trowel it on fairly smooth and it will give a faux appearance of a regular cement wall.  At least that is what i will shoot for.
    How much exposed ICF do you have showing above grade that you are trying to finish?  I supposed you could install the siding down almost to finish grade.
    I'm in the same boat so I'll watch the responses with interest, but I don t think that there are many other options...
    1. billd60 | May 12, 2006 10:19pm | #3
      A foot would do it.  I've never done the parge coat so I guess I'm a bit unsure.  If it's easy then that wold probably make the best fix for me.  I definitely do not want to face with stone since I probably have close to 300 linear feet to address.
  2. VaTom | May 12, 2006 07:46pm | #2
    Copper works great.  My house is sheathed with it, dull brown now, down into the dirt.
    Use brass screws or copper pop rivets.  Or glue.
