Bad door hinges?
| Posted in General Discussion on October 20, 2004 07:58am
In several of the homes I have built I have had complaints about the hinges on the interior doors.   They are making a very fine black dust.  oiling dose not provide a long term fix.
Is there any thing i can do to fix this with out replacing all of the hinges?
  1. DanH | Oct 20, 2004 08:14pm | #1
    There are no bad door hinges, they're just misunderstood.
    I suspect poor quality alloys, or doors that are too heavy for the hinges.
    1. JohnSprung | Oct 21, 2004 01:55am | #3
      Where were the hinges made?  Perhaps China?  Metalurgy QC there in some cases isn't what it should be.
      -- J.S.
  2. DanH | Oct 20, 2004 08:15pm | #2
    Actually, lubing with a teflon-bearing lube (eg, Triflo) will probably provide a longer-term fix than oil. But nothing will really solve the problem other than replacing them.
  3. FastEddie1 | Oct 21, 2004 02:33am | #4
    What you are seeing is the residue from the knuckles grinding against each other.
    Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
    Sphere | Oct 21, 2004 02:44am | #5
    simple, so simple..got a torch? Heat (LOW) and rub a bees wax candle or some o' the best of David Douds cake wax..all done.
    Or, get brass.
    1. BAYbuilding | Oct 22, 2004 08:21pm | #6
      Thanks i will try the wax   would a heat gun work?
      Mick
      Bay Building
        Sphere | Oct 22, 2004 11:36pm | #7
        probably..try it.
  5. MrBill | Oct 23, 2004 02:30am | #8
    Mick,
     I have had the same problem in my own house. It seems to be worse on the bathroom doors so the moisture must have something to do with it. I have replaced several hinges with "good" brass ones and they seem to solve the problem so I am also going with a material problem.
    Bill Koustenis
    Advanced Automotive Machine
    Waldorf Md
    1. VaTom | Oct 23, 2004 05:07am | #9
      Bathroom doors generally have more activity than others.PAHS Designer/Builder- Bury it!
      1. m2akita | Oct 24, 2004 08:08am | #10
        What??  Yours doesnt stay open all the time like mine??!!  How are you doing?  Been meaning to drop you a line....... just havent done it.  Will do it soon.
        -Matt
        1. VaTom | Oct 25, 2004 12:52am | #11
          You clearly aren't married to my wife.  Some things she just doesn't want to share.
          Just returned from tidewater.  My mother's 93rd b'day.  We don't miss them at this stage.  Life's OK up here, come on up.  Isa called last week looking for more help.  I didn't volunteer, but sent her a couple of guys (neither carps).
          But where's the sun?  We didn't move to Seattle exactly because of this kind of weather.  Still have copper to get on a roof.PAHS Designer/Builder- Bury it!
