Balloon Frame Headers
Waterbear | Posted in Construction Techniques on March 24, 2006 05:39am
I’m not much of a framer, and discovering this balloon framing in the process of a kitchen remodel that has me scratching my head.
It’s a 1937 story and a half and the wall shown is a gable end.
The drawing outlines the existing, dotted lines are openings I need for windows (lower) and a range hood vent (upper.) I apologize for the size of the file…
The way I’ve worked it out seems like way too much lumber so I started to question if I’m missing something.
I searched the archives and found some good info. on the process for bracing and placing the headers, but can’t seem to wrap my mind around the layout.
Anyone care to give me a hand? Thanks
    razzman | Mar 24, 2006 05:51am | #1
    'Nemo me impune lacesset'
    1. Waterbear | Mar 24, 2006 03:15pm | #6
      Thanks for resizing! Do you know if there's a downloadable resizing program for MACs?
        razzman | Mar 24, 2006 09:59pm | #11
        Waterbear,
        Thought to ask of the local mac users as I don't know, but seems there would be.
        We'll see if Cloud of Newf can help you with that.
        Cheers
        'Nemo me impune lacesset'No one will provoke me with impunity
        Edited 3/24/2006 3:00 pm ET by razzman
      2. splat | Mar 27, 2006 08:47am | #12
        google graphic converterits shareware and pretty much industry standard for many many years.splat
        1. Waterbear | Mar 27, 2006 03:11pm | #14
          Thanks, I'll check that out.
  2. philarenewal | Mar 24, 2006 06:03am | #2
    The whole wall look to be about 10' long.  Only thing that springs to the top of my head is run a single header across so you don't have three complete sets of kings and jacks.  At that point, the rest of the framing isn't structural so you can get more latitude in trying to save sticks.
    "A job well done is its own reward.  Now would you prefer to make the final payment by cash, check or Master Card?"
    1. RalphWicklund | Mar 24, 2006 06:18am | #3
      At this point someone will drop in and suggest you consult an engineer.<G>
      Note the drawing shows a let in ledger with either ceiling or floor joists bearing on that gable wall. If you go with the single header idea you will need to account for that loading and be able to direct the load path to a proper bearing at the foundation.
      Then you can feel free to fill in the simple framing for your windows and vent.
    2. Waterbear | Mar 24, 2006 03:13pm | #5
      Yeah, I knew I was going to hear about an engineer from someone. That's probably what's going to happen but I thought I'd bounce it off you people first. Your single header idea is a good one, but by my calculations that means going with some steel (?)Back to the drawing board...Thanks for taking the time to look it over.
      1. philarenewal | Mar 24, 2006 03:22pm | #7
        Wow!  Steel for a 10' long header on a gable wall.  Commercial bldg?  Piano showroom?  ;-)
        1. Waterbear | Mar 24, 2006 03:30pm | #9
          -Evidently showing my ignorance... Off to the engineer I go, and to place a call to my framing buddy.
    SamT | Mar 24, 2006 06:23am | #4
    Unless you are extremely interseted in saving the existing siding, I would replace, below the let in, those six studs with a conventionally framed wall with a double top plate.
    FWIW, I don't know why, but my gut's telling me to drop a tight fitting block in between the existing studs next to the let in. ???
    The more I look at the sketch, the more I want to use a 2" x 1/1/2" block well fastened to the let in, the studs, and the new top plate. ???
    SamT
    1. Waterbear | Mar 24, 2006 03:26pm | #8
      "I would replace, below the let in, those six studs with a conventionally framed wall with a double top plate."Hmmmm, I hadn't thought about that. I would still need three sets of kings/jacks, but at least it would simplify the picture in my mind. -And the house is being restuccoed anyhow..."FWIW, I don't know why, but my gut's telling me to drop a tight fitting block in between the existing studs NEXT to the let in. ???"You mean BEHIND the ledger to block in the studs over the existing window? I guess I'm not following. Thanks.
        SamT | Mar 24, 2006 06:42pm | #10
        Yep. But the full length of the replacment wall. Like I say, it's a gut call.
        View ImageSamT
    McDesign | Mar 27, 2006 12:52pm | #13
    Use Simpson HH-4s (header hangers) and no jacks, if the studs are truly 3-1/2" wide.
