Ballpark plumbing rough-ins for a modern drawer/shelf vanity (photo attached)
SwissCarpenter | Posted in Construction Techniques on March 5, 2015 09:07am
Question for those plumbers out there.  I’m trying to do a plumbing roughin and I’ve got a really crappy spec sheet to work off.  The atual vanity is still 4 weeks out so I’m trying to avoid a delay.  Looking at the attached crappy spec sheet, can someone give me guidance of roughly where I could locate the drain and shutoffs without me having to delay the drywall install or have to cut the drywall back out?  As trendy as these vanities are I’ve never installed one of these before, but my guess is there isnt a lot of room behind the drawers and you wouldnt want to install the valves in the space behind the false front drawers.  Any guidance based on experience would be great.  Feeds are PEX coming straight down from above and the drain is 2″ PVC coming straight up from the floor. The manufacturer is Bosconi and theyve been of zero help in getting me better specs.
The vanity on the web: http://www.bosconi.com/ProductDetails.asp?ProductCode=SB-250-3WH
  1. mark122 | Mar 05, 2015 07:03pm | #1
    your sink depth is basically 7 3/4'' and a standard drain and tail is 8 1/2''. i would set the drain at 20'' from the floor. put your shut offs on the left and right of the drain at the same height or a little higher.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
