Hi All,
I inherited a craftsman bandsaw. When I powered it up it attempted to turn but couldn’t. I hand turnrd it a few times and tried again, turned fine. But as soon as I try to cut some wood, it stops. Unfortunately I don’t have an owners manual, and can’t seem to find one online. What do you guys think could be the problem?
Kevin
so -
is the belt slipping at the motor?
that was it,thanks Dave. Do these bandsaws require an lubrication?
I'd look for oil holes associated with each shaft/pulley - likely the machine has sealed bearings, unless very old - as general principle I shoot penetrating oil on every threaded assembly - nuts, adjustments, hinges, etc - "there's enough for everyone"
A weak motor? Guide blocks set too tight? Blade installed backwards?
The Max Duginske book on tuning woodworking machines would probably help you out a lot.
It was the belt, might look into that book just the same.
Not sure what the problem is, but this will surely slow the pinewood derby car construction.
Dave guessed right. Just cut a scrap of wood in the shape of a car, no problem. Went to a basketball game with the kids and their dads, seems like everyone will be building their cars in my garage, painting them at home. Should be alot of fun.
That will be fun to have the group at your place. Have sun and be safe.Trey cut his car out this morning, Going for speed not style.
I cut out mine for the "outlaw races" too.TFB (Bill)
at these outlaw races, are there cocktails, gambling?
It's at the school, so only on the locker room.TFB (Bill)
I don't know if you go to these breaktime fests, but a derby might be a cool addition to the event. After all, men never really grow up:) At least that's what my wife says.
We could use exotic wood or Azek, and piffin screws for added weight.The Azek has me rethinking my design.....Hmmmmmm.TFB (Bill)
possibilities are endless, have some simple rules like you outlaw races. I prefer no motorized stuff, just 10 oz max. All else is fair game. Maybe a length limit as well.
depending on the model and depending on how old it is, you may be able to find a copy of the manual over on the old woodworking machines website. http://www.owwm.com/
Thanks Stuart, I'll give it a try.
