Banging pressure balance valve
JD12 | Posted in General Discussion on December 1, 2005 07:26am
I have a Foremost Pressure balance valve installed in our shower.  I have replaced the valve at least three times in the last 5 years.  The first two valves had a rubber diaphragm in the middle of the valve that failed…rubber was torn.  The third replacement they sent was of a new design with full brass body and apparently a mechanical balance valve.  I was delighted they had beefed up the design but the brass design has always been noisy, every time a faucet, toilet, dishwasher in the house is turned off it sounds as though that balance valve slams to one side and creates a loud mechanical knock which seems to have gotten louder over time….I’m thinking it may have had a rubber bumper on it that has been flattened (haven’t had it apart recently).  Even if a water source is gently shut off you can hear the valve oscillating back and forth for a second or two. (like a ball in a spray can rolling back and forth)
Has anyone else experienced this kind of problem?  Does anyone have a solution? I have read about “water hammer” but I’m quite certain that’s not what this is.  If I shut the valve off using the isolation valves the noise is gone.
Any help would be much appreciated.
Thanks!
  1. DanH | Dec 01, 2005 07:31am | #1
    Hey, what you do in the privacy of your own home is your business, but do you really want your mother reading about you banging a pressure balance valve?
    happy?
    Edited 11/30/2005 11:32 pm by DanH
Choosing a Paintbrush
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
