Barn, remove post and ??
jeffwoodwork | Posted in Construction Techniques on April 30, 2008 02:54am
Need to remove the second post one with the radio on it. Span from post to post is 10′ in between, span in width is about 34′.  Not much snow load in this area.  I was thinking  of turning the rafter into a truss but not much support on either end.  Other possible was to run a beam from post to post about 20′ to support the missing post, seems though I would need a hefty beam.
Now as I think out loud  the end of the rafter is supported by the wall post.  I could sister a post to it and set the bottom cord on that.  Still some major in place truss building.
Any ideas?
Thanks Jeff
  1. frenchy | Apr 30, 2008 04:17am | #1
    jeffwoodwork
      those type buildings are engineered to a minimum amount of redundancy. If you remove that post the ceiling will sag or give way completely in a high wind.. a truss is not a good answer either because you are transfering load to beams already near the minimum size for the job..
  2. DavidxDoud | Apr 30, 2008 04:24am | #2
    here's a pict of one possibility - trussing with cable/wire -
    frenchy has a point about design limits -
    "there's enough for everyone"
  3. dovetail97128 | Apr 30, 2008 05:52am | #3
    On the other side of the ridge, is there an identical set of posts?
    And yes a competent wood products engineer can design a truss design that would work. I have done that work and had a really good engineer who set me up with the correct solution with no problems.
    1. Piffin | Apr 30, 2008 01:38pm | #4
      Right - I wouldn't attempt this one without an engineer. Wind loads are part of the formulae too
    2. jeffwoodwork | Apr 30, 2008 04:52pm | #5
      Yes posts are the same on the other side as well. They use a tractor to get those big square bales in there, if I wait long enough they will knock that post down!)
      1. dovetail97128 | Apr 30, 2008 04:56pm | #6
        OK. I thought there would be but wanted to check. Engineer is my recommendation.
Picture-Perfect Pergola
