Barn/Shed Door Stops
OverKnight | Posted in General Discussion on August 15, 2009 06:50am
I’m building a shed with 36″ wide double doors.  I’d like to install a mechanism I’ve seen on old barn doors that acts as an adjustable door stop, but I don’t even know what they’re called to do a search for them.  Basically, it’s a steel bar attached to each door with a hinged mount.  This bar slides through a slot in another steel part that is attached to the inside of the door frame.  The sliding bar has some notches cut on the bottom edge.  Gravity makes the bar drop into the notches, holding the door open; to release it, there is chain on the inside of the door connected to the bar with a simple lever mechanism to lift the bar.
I hope this is clear enough; it’s a simple mechanism, but not easy to describe.  Does anyone know what these are called, and where I can get them?
Thanks very much.
    Huck | Aug 15, 2009 07:15pm | #1
    Its called a farfugnugen, and they're available at Candy Mountain Hardware - so says Leo the leopluridon!!
    (bump)
    View Image bakersfieldremodel.com
    1. Piffin | Aug 17, 2009 12:45am | #4
      So Leo's still wonking there, eh?
      I'm surprised, what with the pot-O-gold he's sitting on!
        Huck | Aug 17, 2009 01:26am | #5
        pot of gold, what pot of gold?  Now move along...View Image bakersfieldremodel.com
    Huck | Aug 16, 2009 06:30pm | #2
    Sorry, my bump didn't seem to bring the pundits out of hiding!
    I posted several links for barn door hardware in this thead (didn't even get a thank-you!).  Check them out, you may find what you're looking for there.
    123226.1
  3. Piffin | Aug 17, 2009 12:43am | #3
    I can picture that in my mind from the text, but don't know what they are called. Similar to some older casement window control bars.
    Huck | Aug 17, 2009 01:27am | #6
    You ought to be able to have a welder fabricate you one pretty easily, based on your description.  I couldn't find any online that fit that description.
    1. Piffin | Aug 17, 2009 11:55am | #13
      Maybe a machinist. I don't see any welding in this thing
  5. Howard_Burt | Aug 17, 2009 03:27am | #7
    sounds like your describing a form of overhead door holder.
    Maybe something like this would work.
    Here's a link to the Glynn-Johnson catalog. Take a look at page 6-9.
    http://www.glynn-johnson.com/pdf/2002_gj_overhead.pdf
      Huck | Aug 17, 2009 04:20am | #9
      I haven't quite got it figured out, but I'm picturing something like this.View ImageView Image bakersfieldremodel.com
      1. Howard_Burt | Aug 17, 2009 04:39am | #11
        I assumed he was talking about swinging doors as opposed to sliders.
        All your missing in your drawing is the springloaded pawl that engage the teeth of the bar.
      2. woodway | Aug 18, 2009 01:44am | #21
        That's it, only the horizontal part in mine would be fitted through a hole, the bar would be longer and notches would be less "saw like" and more like crude notches. Idea is the same.
        Edited 8/17/2009 7:03 pm by woodway
  6. dockelly | Aug 17, 2009 04:11am | #8
    http://barndoorhardware.com/
    Did a search and found this site. Didn't see what you describe but they have a phone number and may at least give you a name for the thing.
    Good Luck
    Kevin
      Huck | Aug 17, 2009 04:23am | #10
      and I'll add:
      http://www.barndepot.com/
      http://www.doorhdwe.com/
      http://www.crown-industrial.com/
      http://www.specialtydoors.com/View Image bakersfieldremodel.com
  7. bobguindon | Aug 17, 2009 05:39am | #12
    I hope this is clear enough; it's a simple mechanism, but not easy to describe.  Does anyone know what these are called, and where I can get them?
    Actually, your description is perfect, but your timing isn't.  It seems that this was a popular item back in 1919.  Your desciption brought me back to my childhood, in the garage at my grandmother's house.  She's been gone almost 20 years now, and the house has long since been sold.
    A quick search revealed the name:  'garage door holder'.  This link brings up a print ad from the Stanley Works, dating back to 1919:
    http://tinyurl.com/lj8pk6
    Edit:  The above link brings you to the text of the ad.  Scroll up to see a drawing of the door holder.
    I can't find a current, domestic source for anything like this, but there is a similar product available in the UK:
    http://www.acleigh.co.uk/PDFs/Door%20Holders-acleigh.pdf
    Hope this helps to get you started.
    Bob
    Edited 8/16/2009 10:40 pm ET by bobguindon
      Jeff_Clarke | Aug 17, 2009 02:26pm | #14
      ToolFreakBlue | Aug 17, 2009 07:12pm | #15
      Those are for metric doors and won't work on a 36" door. ;)
      TFB (Bill)
      1. bobguindon | Aug 17, 2009 07:42pm | #17
        I figured that if the OP was in a humid region, the doors might swell up to a metric size...
        Bob
          ToolFreakBlue | Aug 17, 2009 08:18pm | #18
          I had not considered the humidity aspect, good point. :)TFB (Bill)
  8. MikeSmith | Aug 17, 2009 07:21pm | #16
    all the  hinged garage doors  had  them  when  i was a kid..
     they  were steel.. and  usually  rusty..  there  were  two  positions.... open/closed
    try  garage  door stops... or  garage  door  openers
      Jeff_Clarke | Aug 17, 2009 11:29pm | #19
      Gee Mike that ad is from 1919 ;o) LOL
      1. OverKnight | Aug 18, 2009 01:40pm | #22
        Thanks, everyone, and sorry for the delayed response; I was out of commission for a few days.  Bob, your links are exactly what I'm looking for.  I rented a garage (actually a stall in an old carriage house) in Poughkeepsie, NY about 20 years ago which had these and they're great.  Being as simple as the are, I could fabricate them, but I really don't have the time, especially if they aren't expensive.
  9. woodway | Aug 18, 2009 01:38am | #20
    Your description is sufficient to "get the idea" and I must say, it's a good one. So simple in fact the just about anyone could make one from scrap parts and a rope/cable. Thanks!
Fast, Accurate Wall Framing
