Hi All , I have a job were I will be attaching base cabinets that will form a island topped with granite counters, The question I have is what would be the best way to attach the base cabinets to an concrete floor. The island counters will overhang the cabinets by one foot on one side.. Thanks Mike
MDR
I'd go about the same method as if fastening to any floor-install blocks (usually a 2 by whatever flat). The concrete poses a problem, but provides just as good an anchoring system as floor joists. I'd use drop in anchors rather than something like tapcons or Powder Actuated Device-shot nails. I usually span across the toe kick space front to back and allow enough slop (1/4") so I don't fight getting the cabs over and around the blocks.
I'll then screw through the cabinet into those blocks. (not drywall screws). This b/4 a finished back or toe kick cover is applied.
Will the cabs be back-to back, or just a single unit deep? Will the overhang be on all sides?
With a single cab, especially with an overhang on only one side, you need to be a little careful about tipping. (Never can tell when 4 teenagers are going to decide to sit on the island.) Be sure to fasten both front and back.
(Of course, absent the teenagers you hardly need any fastening -- the granite will keep things from moving.)
The cabinet guys I have seen use 2x4s shot pined or TapCon'ed into the concrete, then anchor the cabinet to that.
Base cabs on concrete.
Thanks for all the replys. There are teens in the house I will go with the 2x4' s on the flat attached with drop in anchors.. Thanks Mike.
Mike
Make sure what you are fastening "through" is up to the task as well. The toe kicks are usually 3/4 particle board, the backs.............might be close to nothing. Beef them up if you can from the inside. This is semi critical on the side opposite the overhang. Nobody is going to "lift" the cab up, but the prying action of a couple teens horsing around (or the adults for that matter) on the overhang side can make for quite a lever.
Best of luck.
