baseboard heat
mrfixitusa | Posted in General Discussion on November 15, 2009 09:05am
we are selling a house with a finished basement
there is no heat in the basement
in order to qualify for FHA financing a home must have a source of heat for the basement
Basement is 1,000 square ft
Main floor of the house has hot water heat and baseboard heat registe
We want to install something permanent- something that attaches to the wall – not a heater you set on the floor and it must be 12″ from the wall – (like they have at HD for $49)
Thanks for any suggestions
Edited 11/15/2009 1:06 pm by mrfixitusa <!– MRFIXITUSA –>
Edited 11/15/2009 1:07 pm by mrfixitusa
  1. mrfixitusa | Nov 15, 2009 09:05pm | #1
    We want to install something permanent- something that attaches to the wall - not a heater you set on the floor and it must be 12" from the wall - (like they have at HD for $49)
    Edited 11/15/2009 1:06 pm by mrfixitusa <!-- MRFIXITUSA -->
    IMERC | Nov 15, 2009 09:16pm | #2
    use panel radiatiors... hook them into yur current system... zone thewm even...
    http://www.buderus.net/OurProducts/RadiantHeatProducts/tabid/94/Default.aspx
    WOW!!! What a Ride!
    Dinosaur | Nov 15, 2009 11:42pm | #3
    You want quick and cheap, electric baseboard radiators. For a thousand SF in your climate I'd say you'll need eight or ten four-footers or an equivalent number of shorter or longer units. They come as short as 24" and as long as 96". Run on 220VAC; wired with 12-2 with a ground but no neutral.
    Or, for a bit more dough, put in a decent woodstove.
    Dinosaur
    foolish men call Justice....
    1. bobguindon | Nov 16, 2009 02:33am | #6
      Electric baseboard would be an excellent choice.  Relatively low cost of install, and probably not very expensive to operate as supplemental heat in a basement.  If he doesnt' already have a code-approved flue for a wood stove, that would probably be prohibitively expensive.  Also, I would imagine that FHA is looking for an 'automatic' heating system.
      Bob
  4. Scott | Nov 15, 2009 11:53pm | #4
    Gosh, too bad it got "finished" without a heat source. Are you faced with cutting out drywall to run wires or pipes?
    I would think that extending your existing heating system would provide better resale value, as most people know that electric baseboards are cheap to buy, but hugely expensive in the long term.
    I like Dino's suggestion of a wood stove, as long as FHA recognizes it as a "real" source of heat.
    1. fingersandtoes | Nov 16, 2009 12:22am | #5
      I like baseboard heaters, especially as back up for a wood stove. They are 100% efficient and make it easy to zone a house, allowing you only to heat where you want to. They are also quiet and don't blow dust around, have no duct work and are easy to replace. Probably not cheap to run where you are, but for many areas not too bad.
  5. mrfixitusa | Nov 16, 2009 03:09am | #7
    Bob thanks to you and the others for your suggestions
    This is a situation where the basement stays warm and probably doesn't need anything in reality, but will be req'd for the loan
    In other words we will buy it and provide it but the new homeowner probably won't even use it
    We'll find something that can plug into an outlet(s) and go from there
    thanks again to everyone
      Dinosaur | Nov 16, 2009 03:48pm | #8
      Hard to be sure from here, but I'd tend to think that if it 'plugs into an outlet' it won't be considered a 'heating system' but rather a 'portable heater.'
      You're probably gonna have to hardwire units designed to be installed on a permanent basis.
      One advantage of electric baseboard heaters for your situatioin is that you can put a cheap thermostat directly on the unit(s) and so avoid having to snake wires for wall-mounted t-stats.
      Dinosaur
      1. mrfixitusa | Nov 17, 2009 06:08am | #9
        Thanks I appreciate itI talked to an electrician today about the baseboard heat and he is directing me to Lowes to buy an 8 ft baseboard heater that will have a built in thermostat
  6. mrfixitusa | Nov 18, 2009 05:35pm | #10
    thanks for the tip on the radiators
    we're still looking around - lowes has a bigger selection than HD
    but here's what I'm looking for today - chrome legs for a bathroom sink
    http://www.antonline.com/p_L65-001-GP_332167.htm
    The house I'm working on is close to Federal and I-70
    George Sanders and HD do not have the chrome legs
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
