Baseboard or Tile first???
Chaz5500 | Posted in General Discussion on October 14, 2005 06:38am
What is the “standard” sequence to finishing a new bathroom?
Install trim such as doors, molding, baseboard,  then ceramic tile.  Or install tile first.
Thanks in advance.
  1. BryanSayer | Oct 14, 2005 07:01pm | #1
    I did tile first, and I imagine if you have the option that is the prefered way. Although I can imagine that certain designs might need trim first. But usually, in retrofit jobs, the trim is cut to allow the tile to slide underneath it.
  2. PhillGiles | Oct 14, 2005 07:15pm | #2
    In my limited experience, it depends on when they can schedule the trim guy, the painters and the tile layer - in tract houses they seem to prefer to put in the base first to get it painted and do the tile later; in upscale houses, they usually paint the wall, put down the tile, hang the base.
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  3. csnow | Oct 14, 2005 09:19pm | #3
    I vote tile first.  Otherwise you create a 'well' for water to sink into under the baseboard.  Also looks more finished, since it hides the seam.
    Though, wooden baseboards in bathrooms would not be my first choice.  I prefer tile part way up the walls so you can really hose things down.
    It's easy to find really nice tile pieces that have fancy trim profiles now.
  4. jrnbj | Oct 14, 2005 10:33pm | #4
    Sad but true fact, almost no one does the old style, where wall cove tile goes first, then floor field tile butts to it.....lay it out well, & there aren't noticably odd cuts in the field tile, and no ugly gaps btwn the tile & base
    (I eagerly await the inevitable "but where's the expansion room" comment...LOL)
    txlandlord | Oct 15, 2005 01:08am | #5
    Old time custom builder here, also done lots of remodeling and additions.
    We install trim / doors / shelving / cabinets / etc. prior to any type of floor covering.
    We raise the baseboard up about 1/2".  Tile slides under and we install shoemold or 3/4 x 3/4 quarter round at the bottom of the baseboard after tile installation.
    Reasons:
    Easier to paint or stain with no tile.
    Reduced construction traffic on the tile floor after install.
    Raised baseboard reveals whole baseboard profile.
    Shoemold or 1/4 round produces nice look and helps with variances.
