I have a timber-frame home with stress skin panels (not structural, the interior side is sheetrock). Internal (all non-load bearing) walls are constructed with metal studs. The finish carpenter installed the baseboards/trim by shooting finish nails at an angle thru the baseboard and into the sheetrock. I’m replacing some of the baseboard and need some advice.
- When I remove the old baseboard it seriously damages the sheetrock. Any hints to minimize the effect?
- Is there a better installation method than angleing finish nails? I’ve thought about gluing nailing strips and routing a slot on the back of the new baseboard to accomadate the strips, but that seems like a lot of work for limited value.
Thanks for the help
glen
get some plywood the same thickness as the sheetrock and cut it down to just shy of the base height, screw to the studs and apply the base board to the wood with nails. cant help with the nails damaging the rock, just go slow.
that works on the interior walls, but not on the exterior stress-skin panels. All that's under that sheetrock is foam - nothing to attach the plywood to. but I could glue 1/4" plywood to that sheetrock and just make the baseboard thinner.
glen
Why not just skip a step and glue the baseboard onto the rock ?.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
I assume basic yellow glue is just fine.
glen
In the past, I have used construction adhesive like Pl200 or 400( liquid nails might be OK) but the trick was to get the baseboard to hold immediately, so use a hot glue gun in strategic places to hold the base in place until the adhesive grabs.
Yellow glue just doesn't do the job, as Dealin has written, you need an instant grab adhesive specific to the job. I've used No More Nails (LePage) and EnerBond, both work..
Phill Giles
Unionville, Ontario
Has anyone tried the new adhesive call Power Grab ? It's also LePage, and I saw a demo where they put a bead of this stuff across a brick, held it against a piece of drywall for 60 seconds, and it stuck - got my attention..
Phill Giles
Unionville, Ontario
To prevent the removal damage, punch the nails through the molding (with a nail set or other punch like tool) instead of pulling them off with the molding.
GLENR3,
Punch the nails completely through the baseboard with a nailset. If you use trim head screws to reinstall, there is no need for adhesive.
Just be sure to smack the plumber, who originally installed mouldings, in the back of his head. (I call him a plumber, cause it sounds like something my father-in-law woulda done!)
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
are you saying the trimheads will grab the sheetrock well enough to hold the baseboard?!?!?! That seems unlikely - trimheads would grab the plywood that was glued to the sheetrock though. I never planned to glue the baseboard to the plywood. Either finish nails or trimheads.
Did I misunderstand you?
The trim heads grab the metal studs. No need for the plywood.
J. D. Reynolds
Home Improvements
Edited 6/6/2002 3:59:38 PM ET by JAYBIRD
That'll work on the interior walls. The exterior are the stressskin panels, just sheetrock and foam. But you're right - If I can find the studs.
glen
magnet.
