Basement Closet to Hide Backwater Valve – clearance to door
patrick1 | Posted in Construction Techniques on May 11, 2019 08:47am
I’m finishing my basement and plan on building a closet to hide some plumbing cleanouts and a recently installed backwater valve.  Because the cleanout fittings were partially under the foundation footing, the plumbers had to install the backwater valve inboard of the cleanouts, placing it a good distance away from the foundation wall.   I do not want to make an excessively deep closet.  For the closet doors, we were planning on doing 2 sets of bifold doors (two 50″ wide rough openings with 4 studs in between).
The valve is currently proud of the slab by 2 inches but it should be close to our finished floor height once the subfloor and finished flooring are installed (Delta-FL, 1″ high compressive strength XPS, 7/16″ OSB, vinyl plank).
How close I can push the front of the closet framing to the backwater valve?   Would there be any issues with having the valve cover just inside the rough opening?
I’ve attached a photo showing the area and where we want to put the doors.
    tfarwell | May 11, 2019 10:11am | #1
    I'm no expert in the code for it, but your idea seems pretty good to me. You will clearly have access to it in the future. Good luck.
  2. cussnu2 | May 11, 2019 11:26am | #2
    Without much to go on, it looks like it is fairly close to footing inside a standard sized closet. I would start there as a minimum in case anyone wants to hang something in there.
    Usually you are talking about a minimum usable (ie from finished surface to finished surface) interior depth of 24 inches but 28 is much better fit for storing winter coats. Since it is a basement and someone’s winter gear (think skiing, hunting or other bulky gear not particularly popular with the wife) are likely to be banished to the basement, I would go with 28” interior depth as the starting point.
    1. patrick1 | May 11, 2019 11:38am | #3
      We always planned to use the closet for winter coats and clothes. With our winters here in Ottawa, you need a tonne of storage for the puffy parkas, boots, snow pants, etc. Before the plumbers came in, we were targeting a depth of 30", which has worked well in our other closets in the house. Now, we'll end up with a depth of around 37" once the drywall is on.
