BASEMENT FRAMING
user-53712 | Posted in General Discussion on December 16, 2005 03:48am
A basement that I’m remodeling had some water damage and the paneling and the furring strips needed to be removed. Most of the wall are cinder block.   What is the most efficient way to hang the new furring strips.  ie cement nails, tapcons, ramset etc…….????????????
Edited 12/16/2005 7:54 am ET by nag champa
  1. averagejoe | Dec 16, 2005 03:54pm | #1
    Why are you not framing out the walls? Is there no need for space for insulation or electrical?
    1. user-53712 | Dec 16, 2005 04:00pm | #2
      Good point.  I'm  Framing out the exterior walls , however the interior cinderblock walls have to many things like railing, already narrow door Jambs and most of the electrical is already recessed.  In the areas that we are adding new outlets the electrician is going to knockout and recement new boxes.  on the exterior walls I have to frame with 2x4's because ther is wall anchors and we are going to in fact insulate and the electrical is currently out of the wall so it needs put in conduit.
      Thanks for responding
      MARK RUSSO
      WASHINGTON PA
    JeffBuck | Dec 17, 2005 01:16am | #3
    sheets of foam insulation against the block ... tape the seams for a good vapor barier ... steel stud framing set on a pt wood sill.
    cut the foam tight so it's a friction fit ... the steel studs are set as tight as possible to hold them there forever ... seal any penetrations ...
    run mechanicals ...
    drywall and paint.
    PT wood bottom plates can be glued and wither tapconned to hold till the glue sets ... or shot down with a remington gun.
    Washington PA? wife is from WashPa and inlaw's still live in town.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. user-53712 | Dec 17, 2005 04:04am | #4
      I graduated Trinity high School in 94 went to Indiana university, studied woodworking  and psychology, moved to Boulder CO, and back home with wife aand daughter kaya to help ill father ( double lung transplant) with real estate, also to purchase a few homes where affordable.
      My name is Mark Russo and my father has been a barber in this town for over 30 years. Ask her if the name rings abell.
