basement insulation w/ rigid foam
ChrisCut | Posted in Energy, Heating & Insulation on February 17, 2008 04:43am
To insulate the masonry walls of a basement, I planned on installing rigid extruded foam panels (interior side has reflective aluminum skin) and ½” sheetrock mechanically to the block walls with masonry screws and finish washers. I have read enough to stay away from fibreglass batts, but mainly because space is a premium and did not want to stud out a wall for it. I will hold the assembly ¾” off the floor.
The question is, do I or not install a vapor barrier between the rigid foam and the block? I can’t seem to determine if a vapor barrier will enhance any growth of mold, or will the extruded foam panel be sufficient?
the basement is composed of cinder block walls in a 55 yr. old masonry house. the first floor is nearly 3′ out of the ground. the overhead joist height is 7′-4″
Thanks,
Chris
Edited 2/17/2008 8:43 am ET by ChrisCut
  1. mike_maines | Feb 17, 2008 07:13pm | #1
    Where are you located?
    1. ChrisCut | Feb 19, 2008 02:21pm | #2
      central New Jersey
  2. MikeSmith | Feb 19, 2008 04:06pm | #3
    chris
    couple things:
    anything to do with basements, i usually limit my foam to EPS treated with borates
    if you  use foam i'd put it in direct contact with the block, and the minimum would be 1"  ( r-5  to r-7, depending )... the foam will act as a vapor retarder
    i'd mechanically fasten it with furring strips  16" oc and ramsets
    the furring will successfully hold the foam and allow  good fastening for the drywall
    if you wanted some extra protection, you could saw cut, all along the wall on the floor, a drip channel to catch and divert any water that may get thru the wall
    the furring will add 3/4" to the thickness , but will save you countless heartaches,
     you will even have a space where you could  install  some electric devices, either pancake, recessed into the block, or surface mount
      popawheelie | Feb 20, 2008 07:37am | #5
      That 3/4" comes in real handy for electrical.
    Jeff_Clarke | Feb 20, 2008 07:20am | #4
    Chris - in our climate (central NJ) might make sense to use non-paper drywall in the basement (re:  mold).
    basswood | Feb 22, 2008 02:49am | #6
    Owens Corning makes 1-1/2" XPS panels in 2'x8' that are part of the InsulPink basement insulating system. The panels, when stacked on top of one another, provide a recess for a 1"x3" firring. I like the system and use Tapcons for fastening. Here is a pic.
    Let me know if you want to know more.
A New Approach to Foundations
