Basement Insullation
Cincycottage | Posted in General Discussion on February 10, 2006 05:29am
If I’m renovating a basement in a 1985ish condo and they already have that silver blanket type insulation on the concrete, should I still cover the walls with foam panels?  I was going to cover them with the foam and then build 2×4 walls on top.
Any ideas?
    Matt | Feb 10, 2006 06:30am | #1
    >> silver blanket type insulation <<  OK, I'll bite, what's that?  Foil faced fiberglass batts?  Something else?
    1. Cincycottage | Feb 10, 2006 07:55pm | #3
      Not sure, didn't look closely.  Its thin but has a foil face but its more like a thin "quilt-like" material.  It has some type of insulation between the foil but I'm not sure of the Rvalue
      1. andy_engel | Feb 11, 2006 03:58am | #4
        If it's got foil, it's likely a vapor barrier. I'd tear it out. Vapor barriers tend to trap moisture in basement walls.Andy
        "Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein
        "Get off your dead #### and on your dying feet." Mom
  2. dmauck | Feb 10, 2006 06:39am | #2
    you might want to check out the building science corp. website: http://www.buildingscience.com/resources/basements.htm
    It has some of the latest research on insualting basements.
A New Approach to Foundations
