Basement Rim joist insulation
jimmiem | Posted in Energy, Heating & Insulation on December 23, 2010 05:54am
The walls of my basement are studded and insulated with fiberglass. Ceiling is not insulated.  Rim joists are not insulated.I would like to insulate the rim joists. From what I’ve read spray foam is the best way to go followed by rigid foam. I’ve seen comments about fiberglass and moisture problems…my town building inspector said this should not be a problem unless the basement is wet or finished.  Is spraying worth the cost..besides the fact that I won’t be doing it myself?
  1. cussnu2 | Dec 24, 2010 03:16pm | #1
    Right or wrong, I caulked each rim/joist bay only because the builder didn't.  Then I stuffed it with unfaced  r 19 fiberglass and then put in 2 inch foam caulked in place that buts up to the side of the sole plate and runs up between the joists to the bottom of the floor.  that will leave you a lot of 1 1/2 x 1 1/2 inch open spots underneath each joist so I cut 2 inch foam and filled them in too.
  2. MikeSmith | Dec 24, 2010 07:02pm | #2
    jim
    we insulate  the full joist bay at each sideof  basement....we make a hollow  box with 1" foam
    on the end joists we  make a  12" hollow box  box with 1" foam ....then we blow all of these boxes with dense-pak cellulose
    so the entire peimeter is insulated
    of course, we also  use 1" foam against the walls and stud the walls and dense-pak them too
    1. jimmiem | Dec 24, 2010 07:18pm | #3
      Rim joist Insulation
      Hi Mike, I haven't seen you on-line recently..but I haven't been on-line that much myself recently.  Hope everything is well with you.  You have been the best source of info.  When you do the side boxes (where the first floor joists butt perpendicular to the rim joist) do you pre-build the box and slide it in or slide in the pieces individually (i'm assuming that the boxes are 4 sides worth of foam).  Also when you build the boxes how do you attach the sides, top and bottom together?  Sounds like a time consuming process.
      Thank You
      1. MikeSmith | Dec 24, 2010 08:06pm | #4
        each bay
        gets 2 pcs....a bottom and a  front...they are all pre-cut and foamed in place w/ gun foam
        the front  pc has a 1 1/2" hole bored in in it to  blow in the cells
        on the parallel bays   we just use a bottom...foamed in place w/ gun foam, and  holes every  3 - 4 ft.
Mortar for Old Masonry
