Hi everyone, I had cut and broken a section of our basement floor ( 4″ thick/no rebar ) to move some plumbing around for a new bathroom. As I was working we had a few good rainfalls and noticed, despite the fact that the house is built on clay and there is weeping tile all around the footing, a decent amount of water building up in puddles where i had dug out to place new drainage lines. I understand it’s quite normal to get some water running underneath the basement floor (had to pump some out in order to re-pour). I have since noticed a continuous crack develop along most of the 45′ length of the basement. Should i assume that the crack(s) is just stess releif from when i broke the slab ( this floor is 40 years old and showed no evidence of cracks )? Should i be concerned about water seepage through these cracks and into what will be a finished basement? I was hoping on getting away with not putting any sub floor down since head room is a concern ( we’re below 8′ ). Thanks for all your help and comments.
Framing the floor inside a crawlspace foundation keeps a gable-end addition close to grade.
A subfloor is going to add only a couple inches or less. Use Dricore, then flooring.
A forty year old house - it could be that your original perimeter drain has begun to fill with fines and does not work as well as it should. The day may come when you need to replace it. Meanwhile, consider digging and installing a sump pit and pump inside the cellar.
