Basement slab question
n74tg | Posted in Construction Techniques on May 13, 2006 03:36am
Am building a house with a small basement; roughly 12’x22′.  Basement and foundation walls are concrete block (dry stack method).  I plan to form up and pour the footers; then form up and pour the basement slab; then build the block walls outside the slab (on the footers) installing expansion material between slab and block walls.
My question is do I have anything to gain by permanently tying the slab to the footers with rebar stubs in the footers -or- would I be better off just letting the slab float on the footers.
Slab is well below frost line and footers are all the way down to the rock layer (shale).
Edited 5/12/2006 10:01 pm ET by n74tg
  1. Piffin | May 13, 2006 05:34am | #1
    normal is to build walls firsst, then do the slab.
    regardless, be sure you have well compacted soil under the slab
  2. durhamcontracting | May 13, 2006 06:11am | #2
