Basement Sub floor Help
user-465873 | Posted in Construction Techniques on October 7, 2013 07:27am
I am installing a locking vinyl plank floor in my basement.  I was advised to use Spycore sub floor without plywood or OSB.  (This is the dimpled plastic product)  I am a little hesitant due to the warnings and instruction from vinly plank installers cautioning about installing on a smooth surface.  Does anyone know if installing Vinyl plank directly over Spycor is a good idea?  Thank you for your help!
  1. AndyEngel | Oct 08, 2013 01:31pm | #1
    I would be out of a job if everyone heeded this advice, but have you checked with the flooring manufacturer to see if that's an acceptable practice?
