I’m in the process of refinishing my basement and and have recently been studying the pros and cons of the various methods of preparing the finished sub-floor. One method I like is to install rigid foam directly against the concrete floor, then install 3/4″ sub-floor on top, fastening through the foam with Tapcons. This is so far my preferred method as I have the ceiling height to accommodate the 2 3/4″ or more that it will take up. My major hangup with this method though is fastening through the foam – you obviously loose the vapor barrier properties that the foam provides by puncturing it? Is there a better method? No moisture issues…. thanks.
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
You're thinking of the vapor barrier like it's a bubble and you can pop it. It's more accurate to think of it as a condensing surface. A few holes and it will still work.
