Basement subfloor
smiley | Posted in Construction Techniques on April 22, 2008 11:26am
Greetings All
I recently had a flooded basement. The strapping, vapor barrier and 5/8 T&G all had to be removed. I’m thinking of 1″ EPS foam sealed and taped . Here’s where my questions start.
1. Can I apply an engineered wood floor over the EPS?
2. If you think I need a layer of wood between the EPS and the flooring, Can I use T&G OSB instead of T&G plywood?
Edited 4/22/2008 9:47 pm ET by smiley
  1. rez | Apr 29, 2008 06:14pm | #1
    Hiya smiley,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Click here for access to the Woodshed Tavern
    Click here to visit the beginning of Breaktime
  2. rez | May 08, 2008 05:08pm | #2
    Let's run this thru one more time again.
    bump
  3. BigBill | May 08, 2008 05:57pm | #3
    First solve your flooding problem.
    And, yes, I believe that you need a subfloor under the engineered wood floor.
    I think that I might use 2 layers of 1/2 inch ply or OSB stagered as the sub floor.  Glue (sheet vinyl flooring adhesive works great for this) and nail / staple them together.
    Awhile back there was an article on basement wall and floor insulation and there is a web site on building practices that would be good for you to read.  Maybe someone will remember the names and dates as I seem to be haveing a senior moment.
    1. smiley | May 08, 2008 10:05pm | #4
      Hi BigBillI have the article, and this is probably the way I'll go. I was just curious if anyone had any feed back on the 3 in 1 underlay for engineered flooring. My brother just installed it recently, so I was looking for a longer term opinion.
      1. k1c | May 14, 2008 07:02pm | #5
        When I was finished laying down my house with real wood veneer (bedrooms) and formica (kitchen) engineered floorings, I made test scraps with each type glued to form a joint.  I was curious about finish lamination to backing and how the joint would hold up, especially in the kitchen.  I left the pieces outside for months, sun, rain, snow.  I figured this was sort of fast track test of how my floor would hold up.  I was impressed.  I did not see delamination or mushrooming at the edges.  The joints held as well.
        Having said this, if you ever get another flood, you will have to replace the flooring, just to get the underside dry and healthy.  I don't know why you flooded, but you should correct that problem.  Engineered flooring can not be saved if flooded, even if they look undamaged.  Hope this helps.
        1. smiley | May 14, 2008 08:33pm | #6
          Thanks for the info, I have the problem corrected, and don't expect it again, as someone in the past used fiberglass insulation and silicone to seal the hole that my well pipe comes through. I've removed and re-sealed with hydraulic cement. I don't think anything less than tile won't have to be replaced after a flood. I think I'm going to go with engineered wood.
          1. RusselRenos | May 15, 2008 09:47pm | #7
            EPS soaks up water.  You should be using XPS underneith at least 3/4" Plywood.  Read FHB article by Andy Engel, The No-Mold Finished Basement, Mar'05.
            Personally, I would never use hardwood or carpet in the basement, but that's just me.
            Good Luck!!
          2. Billy | May 16, 2008 04:16am | #8
            Actually, I think Andy recommended EPS in his article.  But I agree with you that XPS is much better for this application.  Both of them have enough vapor permeability for a basment in the thicknesses someone is likely to use (maybe 2-3"on walls and 1-2" on floor?)
            Billy
          3. smiley | May 17, 2008 10:45pm | #9
            I agree hardwood does not belong in the basement, carpet I think has merit in certain applications, although I will never install carpet in my house. We are a hardwood, tile and engineered floor family. (I have children, with allergies) I know the articles sais EPS, but it has been recommended to go XPS, and I may install 2 layers of 1/2" plywood or OSB . Although I may try the 3 in 1 underlay under engineered flooring.
