Basement Wall Covering
BARMIL48 | Posted in General Discussion on December 29, 2003 10:13am
My house’s basement has a ceramic block foundation, apparently not uncommon in the early 20th century, and because of water issues, the interior masonry coating has sloughed off the blocks. I wish to replace the coating, now that the water issue has been solved, and I’m open to suggestions as to what material to use. The original product seemed to be somewhat lightweight, so it wasn’t a heavy mortar. I would want something that would readily stick to the blocks. Any ideas? TIA.
    CapnMac | Dec 30, 2003 12:57am | #1
    Just to be sure, do you have regular-sized block with a glazed coating, or is a unit with some sort of vitreous glaze?
    1. BARMIL48 | Dec 30, 2003 04:41pm | #2
      The block has a smooth glaze on it. Color is light reddish brown.
        CapnMac | Dec 31, 2003 12:50am | #3
        Wanted to be sure.  Helped demo a couple of dorm on campus a ways back.  Structure was 16 x 16 x 8" wide terra cotta blocks.  About a 1" thickness, too.  Left hollow, too.  Middles of the blocks are wher they usually broke.  The dorm also had vitreous glazed "sanitary" block for partitions in the shower/bath areas (structural walls had matching tile over the TC).
        Now that I'm more certain you have a masonry block wall (it's tc not concrete block, is all), then the answers will be (relatively) easier.  Best way to keep the moisture out is on the outside, before it gets in.  As to your interior finish, my inclination is to tell you to veneer a finish wall, just like with any other block wall.  You could use furring strips & DW--but only if you solve the moisture problem.
        Depending on how cold the wall is, I'd also be tempted to get some rigid foam in between some sleepers for the finished wall.  Fairly standard stuff, really.  Other than what's 'behind' the wall.Occupational hazard of my occupation not being around (sorry Bubba)
        1. barmil | Jan 02, 2004 12:13am | #4
          Thanks for answering. My intent isn't to finish the wall but to recoat it, as this is in a utility area. I think parging is an appropriate term for this. The original masonry sheathing has fallen off from the moisture I mentioned originally, and I'd like to resurface the block. Just wish to know what material could best be troweled over the block without sagging off. I've had this happen a lot with plain mortar, so maybe there's something a bit thinner and stickier, yet also substantial.
            CapnMac | Jan 02, 2004 10:38am | #5
            You may want to to ask for a bonding agent.  You put a thin coat on, and it makes a "bridge" between a slick surface and plaster or cement parging.  Brain refuses to cough up proper initials, but it is a thin white liquid, that does not seem like it would add anything at all to the adhesion.Occupational hazard of my occupation not being around (sorry Bubba)
            IMERC | Jan 02, 2004 10:52am | #6
            CBA
