Basement wall framing and insulation
JoeTesta | Posted in Construction Techniques on August 23, 2010 08:48am
I have seen conflicting opinions on the use of plastic sheathing as a vapor barrier between the stud wall and the concrete block along basement walls. My method of construction was 4 mil plastic then stud walls with pressure treated sole plate, followed by kraft faced insulation and then blue board(moisture resistant) drywall. I have been told that I should not have used kraft faced paper in conjunction with the plastic as it will trap moisture in the insulation. I have most of the drywall up and have been advised to slit the kraft paper to allow breathing prior to the drywall completion. I have not had any visible moisture problems in this basement. Any thoughts? Thanks .
Joe
  1. DanH | Aug 23, 2010 04:54pm | #1
    Most authorities recommend unfaced insulation, slitting the face, or using foam in that situation.  But I don't think there's enough of a potential problem there to merit tearing off drywall that's already up.
    1. JoeTesta | Aug 26, 2010 06:04am | #3
      The majority opinion seemed to be that I needed to remove the plastic, so I did. I Was able to pull nearly all of it out without taking down much of the dry wall and batt insulation. Thanks for your input.
      Joe
  2. DanH | Aug 25, 2010 08:36pm | #2
    If the moisture is trapped between the masonry and the plastic, what's going to mold?
  3. JoeTesta | Aug 26, 2010 06:08am | #4
    I live in Ohio and the terms "blue board"and "green board "seem to be used interchangably. I used M/R board because it is a basement and more suseptible to moisture. The major opinion was that I should remove the plastic , so I did. It cost me most of a day but seems to comply with the current thinking on this issue. Thanks for your input.
    Joe
