BASF Sonolastic NP 1
edwardh1 | Posted in Tools for Home Building on April 12, 2009 12:35pm
my hardware store says this “caulk” is the best stuff made, especially for roofing. Its polyurethane, and the spec says it stretches 25%.
Anyone use it on roof flashing?
The tube itself says very little about the product- the on line spec sheets say its great everywhere cept underwater.
  1. Marson | Apr 12, 2009 02:18am | #1
    I've used it in a number of places. It's wicked good stuff. Cleanup isn't any fun, but it guns as smoothly as latex caulk. I believe it is primarily designed for expansion joints in concrete. It would be fine for roof flashing.
    1. atrident | Apr 12, 2009 03:29am | #4
        We  use SL 1 for expansion joints in controlled atmosphere cold storage. Its self leveling,  wont do verticle stuff. There is also a primer that is used on the concrete first.
  2. ted | Apr 12, 2009 02:56am | #2
    I've used it before. Bought it at a masonry supply house. performs as well as any of the better polyurethanes.
  3. FastEddie | Apr 12, 2009 02:57am | #3
    NP1 is great stuff.  High quality.  Don't get it on you or your clothes.
    Just remembered a story about using it to do somehting, memory's not quite that good.  Anyone, went back the next day, a gecko had touched it with two feet when it was wet, then the ants came along and picked him clean.  Morbid but fascinating.
    Edited 4/11/2009 7:58 pm ET by FastEddie
  4. KFC | Apr 12, 2009 04:32am | #5
    NP 1 is a very good urethane sealant.  I personally haven't noticed a big difference between it and Sikaflex or other high end urethanes in the final analysis,  but I know a few folks who absolutely insist on it, and it makes them sleep better at night to use it.
    I believe it has a different solvent (xylene?) than a lot of other urethanes.  That's good to know for clean up and some compatability issues.
    k
  5. Malo | Apr 12, 2009 03:11pm | #6
    I've used only when it won't be seen, tooled or ever have to be repaired/replaced. Such as a conduit passing through a foundation.  I have a love hate relationship with most urethane caulks.
    1. shrek | Apr 14, 2009 04:46am | #7
      great stuff use it for everything.  We use it for around doors bonding to concrete.  And tooling is easy with a little soap and water and a rag
      1. DaveRicheson | Apr 15, 2009 07:37pm | #8
        I use  soapy water and a foam brush. Trim them to fit whatever contour you want. Throw them away when they start to load up and you can't shake the excess off.
