Bath fan in sloped ceiling
rfarnham | Posted in Construction Techniques on June 2, 2007 09:48am
I am hanging a panasonic bath fan in a bathroom where the ceiling is the bottom of the 8/12 roof joists. The instructions talk about mounting the fans directly to celing joists, and gave no indication that the unit had to be ONLY horizontal or vertical, but not sloped.
When I mounted it, the backdraft damper wouldn’t close fully, it hung open. I didn’t think it would be a problem because any wind blowing through the vent from the outside would close it the rest of the way. This turned out to not be true. I arrived after a windy snowstorm to find a small pile of snow on the floor under the fan, and the vent pipe was nearly full of snow.
Any suggestions for fixing this problem? I’d prefer to not build a small soffit/box that hangs down from the ceiling that keeps the unit horizontal, but that is the only solution I can come up with. It just doesn’t look very good. The pipe run to the roof vent is very short (6-12 inches) so there isn’t room for an other backdraft damper (like one of those “butterfly” dampers).
Thanks,
Rich
    McDesign | Jun 02, 2007 10:00pm | #1
    I just hung one like that theis morning!  A really quiet Nutone one I like to use.  2x8 rafters; sloped ceiling.
    I always use the vent hood kit that has its own little flapper in it - about $18 at Depot.  I'll post a pic of the install this afternoon.
  2. pinko | Jun 03, 2007 12:59am | #2
    Or you could turn the unit around so the damper faces uphill..gravity holds the door closed..
    Been there, done that.
  3. cliffy | Jun 03, 2007 03:16am | #3
    I glued two pennies to a fan damper once with silicone to hold the damper closed. It must still work fine as I see the client regularily and if was a problem she would tell me.
    Have a good day
    Cliffy
    Edited 6/2/2007 8:17 pm ET by cliffy
  4. DanH | Jun 03, 2007 03:59am | #4
    Install an inline damper.
    McDesign | Jun 03, 2007 04:08am | #5
    Okay - took some pix
    There is a little flapper behind the screen here -
    Edited 6/2/2007 9:22 pm by McDesign
  6. DanH | Jun 03, 2007 04:18am | #6
    The roof vent should contain a damper too. Otherwise that snow (and wind-driven rain) will just build up in the duct and melt.
    1. Piffin | Jun 29, 2007 12:47pm | #7
      not to mention what squirrels will do with that nice warm hole
        McDesign | Jun 29, 2007 03:28pm | #8
        Slow connection?
