Bath remodel: shower window or skylight?
We’re going to be remodeling our master bathroom, and taking space from an adjoining unused closet. It’ll be about 5×12 (long & narrow), so the best set-up would have a big 4×5 all-glass shower stall at the end of the room, against an exterior wall. A 60″ double sink and the toilet along the right wall would lead up to the shower stall. We want to get a lot of natural light into the bathroom.
Question is – what would be better, to put in a couple of awning windows up high in the shower, or put in a skylight that would bring light into the main part of the bathroom? Or both?
I’ve heard the negatives about both, between the inevitable rot of a window in a shower, or the possible leaks and moisture condensation caused by a skylight. Obviously a lot can be avoided by good installation and good ventilation, but does anyone have thoughts about which method is the “least bad” way to get natural light into a bathroom?
Thanks for your thoughts!
MGS
Either could work. Much depends on other factors such as climate, exposure, roof configuration, etc.
I put a cathedral ceiling and 4x4 skylight in our 6x7 bath. There is a nice southern exposure and it fun showering with the sun streaming in. All that ceiling height and light makes the room feel bigger. The skylight looks fine neatly positioned in the center of the roof.
In the shower, you could use a vinyl awning window positioned high in the wall with cement backer board and tile all around. With no wood and no direct water spray, rot shouldn't be a problem.
Al Mollitor, Sharon MA
I like both, as long as the window is up high so as not to get splash. The window is also nice as to get more ventilation.
Skylights are nice too, however I have notied that with all the moisture the trim around the velux get a little water stained
YOu can also consider a suntunnel. Nice option and bring in lots of light. can flex around trusses. however you cant see the sky
In any case , dont forget the bath fan to get the steam out
