Bathroom Ceiling: Skim coat, or more?
![](https://secure.gravatar.com/avatar/6bd65d885f1df8de65ea572f30df2170?s=52&d=https%3A%2F%2Fimages.finehomebuilding.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I’m fixin’ to get started on my bathroom ceiling. Here’s what I know: Originally plaster over lath, somebody came through and tried to fix cracking with fibermesh tape and probably regular joint compound. Now, there are lots of hairline cracks and many places where the repair is spalling off, most chips are the size of a dime or so. Some of it is puckering. If I run a still knife over it, I can get most of the chips knocked off, but the stuff that remains is pretty sturdy.
I’m hoping there is a recommended fix that doesn’t involve tearing it all down or adding another layer of drywall over the mess.
Would any of you advise this: knocking as much off as I can, skimming the rough spots flat with setting-type compound and then going over the whole thing with a drying-type “putty” coat or “skim coat”? When/where should I use mesh?
http://www.fry-wagner.com
Not to sure about the answer link? you gave? I thought he was looking for some mud advise?
Come on' its obvious. The header in that web-site said "Moving into the Future".
You must do the same. Remove the plaster (you really wouldnt need to remove the lath), and move into the future with safe, clean, Gypsum board.
Cut to fit, paint to match
Edited 8/8/2008 9:24 pm ET by MSA1
Do I smell a d-mix thread heating up?
be a lot easier to add a sheet of SR over it
The reason you have the flaws now is that whoever tried to fix this before screwed up and did not get a good bond for whatever reason.
That means to make it happen, you need to start by removing all their junk built up, then clean the surface left, then roll on a bonding agent, then you are ready to start anew.
All that with a 60% chance it will work out fine. a bathroom is a hostile environment for this sort of thing.
I saw a fix by a tile setter I thought was impressive. I would never have tried it myself.
He cleaned the ceiling down to solid surface, then skimmed a coat of Keraflex. It had enough tooth to hold onto a skim of joint compound. He didn't mind a rustic (rough) look and painted that.
It's in his house and I curiously check on it each time I visit him. About eight years and no signs of trouble.
What's Keraflex?
A brand of thinset
Thanks.
If it works for him, that's great, but I don't think I would ever try it. Not only does it seem hard to apply, but I would be concerned about the additional weight.
grab 2 sheets of 1/2 rock,mark your joist and hang some new rock with 2" screws and your done forever. you will be glad you did.larry
if a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
