Bathroom flooring
selenavaz | Posted in General Discussion on October 12, 2012 10:46am
What flooring suits best for small bathrooms to make it look big and big bathrooms too. What flooring, colors suit and help the size illusion. Kindlt share your ideas on this.
  1. DanH | Oct 12, 2012 11:15pm | #1
    A medium-sized pattern -- not mosaic size and not big 12-15 inch blocks.  Generally something in the 6-8 inch range, either ceramic tile or patterned vinyl.
    Small bathrooms tend to be dark, so a light color helps brighten things up.
    xxPaulCPxx | Oct 14, 2012 10:57am | #2
    Breaking the tile pattern helps too, it keeps your mind from measureing out the space based on block sizes.  Here is what I did in my 5'x7.5' Mini Master bath:
    1. Scott | Oct 14, 2012 09:52pm | #3
      Paul, you serious?
      I don't know whether to love it or hate it, but it certainly is interesting. How'd you handle the transistion with the dotted stuff? Is it really one layer of tile over another?
        xxPaulCPxx | Oct 16, 2012 10:50am | #4
        Well, tile OVER tile is a recipie for disaster!
        I saw something the Bryon tile guy did awhile back that kind of inspired me on this.  I wanted organic lines mixed in.
        I accomplished it by making color photocopies of the different tiles (1"=1" scale), then laying them out in diferent ways until I got the desired effect.  My theme for the bathroom was "where the sand meets the sea".  I then cut the paper shapes and transfered them to the tile pieces by tracing it with a Sharpie.
        I took those tiles to a little 5" tile saw, and initially notched the cuts in the vertical plane, knocked the waste off, then finished the cuts by running each tile horizontally across the leading edge of the blade to do the tight contour work.
        1. Scott | Oct 18, 2012 12:49am | #5
          Pretty cool, I say.
  3. JimBerry | Nov 03, 2012 05:27am | #6
    Light colored tiles and paint on the walls make  bathroom look much bigger in size than it actually is. Moreover, you can also get mirrors fitted on one or more walls and make it large.
    1. DanH | Nov 03, 2012 08:01am | #7
      Most people don't want to see that much of themselves while in the bathroom.
        xxPaulCPxx | Nov 03, 2012 03:49pm | #8
        Speak for yourself, it's everything I can do to not kiss my reflection every time I walk by.
        Was that TMI?
