Bathroom help needed
smitch | Posted in Construction Techniques on August 28, 2024 05:23pm
Having had a home where the previous owner used silicone along the meeting walls of a shower stall, I hesitate to do the same thing. What that produced was soaked walls with mildew that needed an entire replacement.
My current home also has a stall shower. Minor cracks along the meeting walls. So I used Custom Building Products Simple Fix grout repair product along the meeting walls and around the bathroom where the walls meet the floor. All joints were previously grouted where wall tiles meet the floor tiles (an old house). This grout manufacturer recommended  removal of the old grout and replace with silicone, and did not like the idea of silicone over the grout. But this is not practical as the old grout is very hard and I would surely crack tiles. I was also cautioned that grout sealant ( have TileLab grout sealant that’s a few years old) would not penetrate their material well and advised not to use silicone over the grout.  Even their professional silicone.
So my first thought was that silicone over the grout seemed like a good idea to me if the materials are well prepared first. I doubted that was done on my previous home.
On second thought,  I’ve become wary that if the silicone should become loosened over time, or otherwise permit moisture under it’s surface, it may just permit water to soak the grout, and I don’t want a repeat of my first experience.
So the untreated grout will at least have opportunity if wet to dry out.
Any useful input would be appreciated.
  1. smitch | Sep 16, 2024 09:26pm | #1
    Wow, not a single reply. No one with any idea here? I must ask easier questions. Maybe go somewhere else.
  2. trueframe | Sep 24, 2024 05:19am | #2
    Silicone over grout can trap moisture if not properly applied, but repairing the cracks with new grout and sealing it properly is a safer long-term solution. If you use silicone, thorough preparation and ensuring it's watertight is the best possible solution I know of.
  3. 1095mike | Sep 24, 2024 12:25pm | #3
    you can use a grout removal blade on a multitool to get the old grout out of the joint
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
