bathroom lighting
| Posted in General Discussion on November 5, 1999 05:33am
I’m getting ready to add some recessed lighting to my small 5×8 bathroom and need to know if both lights need sealed trim rings. One is to be located directly over the shower so I know that one is a given, the other is over the vanity about 5 feet away.Will this light be affected by the moisture from the shower?
  1. scott_koczela | Nov 05, 1999 05:33pm | #1
    I'm getting ready to add some recessed lighting to my small 5x8 bathroom and need to know if both lights need sealed trim rings. One is to be located directly over the shower so I know that one is a given, the other is over the vanity about 5 feet away.Will this light be affected by the moisture from the shower?
  2. Guest_ | Nov 05, 1999 05:33pm | #2
    an electrician could help w/this. the new nec i believe deals with what you ask. 6 ft comes to mind b/4 no gfci circuit. god knows we all change the bulb while on an aluminum ladder near the cast tub with our wife in it. darn, i forgot to take off that janitor key thing that pulls out.
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
