Working on a bathroom remodel, upon lifting up some of the laminate notice there was a layer of waferboard and then about 3/8” layer of sheathing under that.
The 3/8 looks in good shape, plan was to pull up the waferboard and add 23/32 TG OsB subfloor over top the 3/8. I want to then ditra and install 3/8 12×24 ceramic tiles. 16” oc joists and the deflection shouldn’t be a problem according to calculator.
You think this would be okay?
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
Take out the 3/8 and block between joists at walls. Use 3/4 ply not osb (more water resistant) then ditra. I don't know what climate your in, but the ditra with heating is really nice on a cold winter morning.
