Bathroom subfloor help
sandking | Posted in Construction Techniques on April 8, 2013 10:07am
I’m in the process of redoing our 2nd floor bathroom.  We’re down to studs and I removed the dryrotted 15/32″ subfloor that was there.  Yesterday I purchased some 3/4″ OSB and glued and screwed every 6″ as part one of my subfloor.  The original floor joists are 2×8’s 16″ on center, so I ended up doubling each of them up for additional strength since I had the kitchen gutted downstairs under the bathroom.  It’s a small bathroom 5×9 and I was planning on using procelin floor tiles.
Am I screwed since I used OSB instread of plywood?   I was going to put down 1/2″ durarock and then Ditra on top of that, is that a bad idea?
Thanks in advance
  1. AndyEngel | Apr 08, 2013 10:11am | #1
    I don't think so
    Structurally, OSB and plywood perform about the same. Keep it dry and you should be fine.
  2. DanH | Apr 08, 2013 08:58pm | #2
    Yes, definitely screwed.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
