Bathrooms: Removing a Cast Iron Tub
Wylcoyote | Posted in Construction Techniques on February 23, 2004 10:01am
Any body have any tips on removing an old PINK porcelin over cast iron tub?  I hear the technique involves giant sledge hammers, flak jackets and a high risk of personal injury.  Any other options?
Signed,
New to bathroom remodeling
  1. glatt | Feb 23, 2004 10:45pm | #1
    Don't forget the earplugs.
  2. DanH | Feb 23, 2004 11:03pm | #2
    Some folks have claimed success with a Sawzall, but I've never totally believed them.
  3. DanT | Feb 23, 2004 11:04pm | #3
    We do a half dozen of these a year. Throw a packing blanket over it to catch the spray and start hitting in the inside bend area between the floor of the tub and the wall of the tub in the corners.  Use a heavy sledge, ear plugs and safety glasses.  Break till pieces are to your liking.  Don't forget to turn off the water first just in case.  DanT
  4. KWOLSEN | Feb 23, 2004 11:13pm | #4
    I had same problem, I covered the tub with cardboard to slow down any flying shards and nailed it with a sledgehammer, worked great and I was amazed how easily it shattered.   Had saftety glasses and safety goggles on, just is case.
  5. jimkidd2 | Feb 23, 2004 11:13pm | #5
    And wear heavy duty gloves when you're picking up the pieces.
    "I want a good clean fight. No head butts, no rabbit punches, and no hitting below the belt. Break when I say break, and protect yourself at all times."
    1. Wylcoyote | Feb 23, 2004 11:18pm | #6
      Thanks to all for the good advice.  I will armor myself appropriately to protect against shrapnel.
      Cheers
      Sledgeman
    JeffBuck | Feb 23, 2004 11:24pm | #7
    circular saw and a cheap abrasive blade.
    get it loose ... ghet it into the center of the room ... flip it over if possible ...
    ear protection ... easily cut away.
    No flying tub parts to damage you .. or more importantly .. the rest of the room.
    I usually cut it in half ... then that half ... in half.
    4 easily carried piece that fit thru doorways ....
    nice and neat.
         Artistry in Carpentry
    1. AndyEngel | Feb 23, 2004 11:28pm | #8
      Where's the fun in that approach?Arguing with a Breaktimer is like mud-wrestling a pig -- Sooner or later you find out the pig loves it.
    2. Wylcoyote | Feb 23, 2004 11:29pm | #9
      that certainly sounds less dramatic and destructive.
      I was sort of looking forward to all the smashing
      1. davidmeiland | Feb 24, 2004 12:08am | #10
        I had one I could not break. It was a first floor bath adjacent to the driveway so I used a come-along to pull it out the window and into my truck.
        1. Wylcoyote | Feb 24, 2004 12:53am | #11
          big window!
          1. armin | Feb 24, 2004 01:30am | #12
            Sawzall doesn't work worth beans, the enamel is really tough stuff to cut. Sledge hammer makes short work of getting it out, we covered the tub with pieces of old carpeting to dampen the shrapnel. Wear face and eye protection, heavy clothes help as well.
          2. Lateapex911 | Feb 24, 2004 06:00am | #13
            While I normally do the "right" thing, this is one time to go nuts, and get the sledge out, and have at it.  If it's pink, I bet you're doing the whole room, so why not?
            Man do those bits fly! Plug your ears, wear goggles, hat, gloves, the whole nine yards. Enjoy!Jake Gulick
            [email protected]
            CarriageHouse Design
            Black Rock, CT
          3. peteduffy | Feb 24, 2004 06:24am | #14
            I tried the sledge hammer approach, thinking I had a cast iron tub.  It was steel.  Didn't do much, but Quasimodo would have felt right at home.
            Pete Duffy, Handyman
          4. junkhound | Feb 24, 2004 07:07am | #15
            for real fun an' excitement bustin up cast iron, try leaving the stings on and whaking the cast iron frame of an old upright piano!
            Have not done that for a LONG time, but learned very fast to put well shod foot over strings and cut them first with cold chisel before bustin teh cast iron.
