Bathtub on concrete floor?
Senna | Posted in Construction Techniques on August 18, 2004 08:50am
How do I plumb for a bathtub on a concrete basement floor? The tub I have has drains the are beneath the bottom of the tubs plywood base. Is that normal?
A couple of years ago I worked with a friend – a plumber by trade – who helped me install the correct plumbing for a basement bathroom. We capped the pipe for the tub/shower so I now I have to install a trap and connection for the tubs drain. Do I have to cut out an area of floor for the drain pipes under the tub or should I rest the tub on sleepers?
    IMERC | Aug 18, 2004 09:14am | #1
    Either..
    The old shower drain should have a trap in it...
    Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
        WOW!!!   What a Ride!
    1. Senna | Aug 18, 2004 06:34pm | #3
      It's a new install which I did with the help of a plumber. We plumbed all the drains and vents right up to the trap. We stopped short because I wasn't sure what tub/shower unit I wanted to use.
      At the time I was thinking more of a shower than a tub. I am not sure how a tub gets plumbed when there is a concrete floor in the way.
      Edited 8/18/2004 11:37 am ET by ASENNAD
        IMERC | Aug 18, 2004 07:21pm | #5
        Cut out the floor and make all the room you can get for the plumbing...
        Dig down...
        Install the trap..
        Put yur tub in like it was sitting on any floor..
        Replace the busted out CC with CLEAN sand....
        Get the SO in there with you and test drive..
        Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....        WOW!!!   What a Ride!
        1. Senna | Aug 19, 2004 08:48pm | #7
          "Put yur tub in like it was sitting on any floor..
          Replace the busted out CC with CLEAN sand...."
          So no need to replace the concrete? Just sand? Don't have to worry about bugs and things? Sure would make life simpler I guess.
            IMERC | Aug 19, 2004 08:52pm | #8
            Clean sand and and add a bit of bleach to the sand if yur worried about bugs..
            IMERC | Aug 19, 2004 08:53pm | #9
            If yur only busting out a foot square or so..
  2. DanT | Aug 18, 2004 01:28pm | #2
    If it is a correct new install Imerc is right it should have a trap already installed.  Otherwise you need to cut out a section of the concrete or space the tub up so you can get the trap under it.  Hope its all vented and the sewer line is low enough for it all to flow down.  DanT
  3. Dirtpatch | Aug 18, 2004 07:13pm | #4
    We just did this a week ago with our new house. First, the plumber installed his roughin plumbing in the gravel below the location of the tub drain. Then we built an 8"x8"x8" block of framing lumber and placed it directly above the roughed-in drain. When we poured the slab there was a nice space left for him to build his trap in.
    Hope this helps,
    Scott.
  4. MojoMan | Aug 18, 2004 08:08pm | #6
    You can rent an electic jackhammer. It's easier than you might think.
    Al Mollitor, Sharon MA
      CapnMac | Aug 19, 2004 11:31pm | #10
      While you are at the rental shop, get a 12" saw; then down to the bix box for cut off wheels for the saw (or just the one diamond blade).  A saw kerf makes a much cleaner joint.  Which is easier to cope with if you patch back the concrete.  Which is not absolutely necessary as has already been pointed out.Occupational hazard of my occupation not being around (sorry Bubba)
  • Fine Homebuilding's Author Guidelines
