I am getting ready to remove a bathtub and cant remember how the drain disconnects from the plumbing.
The bathtub is circa 1974, so it should be pretty standard.
Is it threaded in? Thanks
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
The basket in the tub is connected to a piece that connects to the overflow pipe. That connection -- to the overflow -- is (most likely) a slip-joint fitting.
The overflow is then connected to the trap using slip joints as well.
Unless you're the lead dog, the view just never changes.
