Bathtub replacement question
jim11787 | Posted in General Discussion on November 20, 2005 06:18am
I need to remove my tub but don’t have access to the drain assembly from below or a wall. Can this tub be removed by disassembling the drain from topside and installing a new tub in its place? I seem to recall a method where a pair of pliers is inserted into the drain and unscrewed from above. Any good links/advice would be helpful- thanks.
  1. piko | Nov 20, 2005 09:44am | #1
    Do you have to replace? Around here there are co's that'll either respray, or put a molded plastic 'cover' over, the same config as your extg tub.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
    1. jim11787 | Nov 22, 2005 01:26am | #6
      Thanks for all your posts. I have considered this option, but thought it would be a good idea to change all the plumbing to the tub if I doing the whole bath over. But you guys bring up excellent points about checking for leaks. I think I'll investigate having the tub sprayed (it has 1 chip in it, but I'm sure a refinisher can fill that befoe spraying).Best wishes for a Happy Thanksgiving to all,
      Jim
  2. DanT | Nov 20, 2005 02:21pm | #2
    You can use needle nose pliers and unscrew the drain from the top and remove the overflow cover via screws and that will detach the drain from the tub.  If (as is often the case) the drain sticks and will not come loose take a metal cutting blace in a reciprocating saw and carefully saw through the part of the drain you are trying to remove.  If done carefully you won't damage the threads on the "shoe" and can simply thread a new drain trim piece back in when the new tub in installed.  Or replace the entire drain assembly when the tub is removed.  Either way you don't have to deal with the drain from the bottom.  We do it all the time.  DanT
  3. Shacko | Nov 20, 2005 06:16pm | #3
    You can remove the drain from the tub top side, but the new tub may or not match the rough-in, that means that you have to change the tub overflow, it can be done but it is a a pain in the azz, even if you manage to do this you have no way to check for leaks. I think that you have to make access to the back or bottom of the tub. Sorry that I'm negative, but I've been there too many times. Luck.
    1. HeavyDuty | Nov 20, 2005 09:56pm | #4
      Shacko, I'm with you.
      I like to see exactly what I'm doing, no key hole surgery. If there is any chance of a leak I want to find out now rather than later.
  4. JTC1 | Nov 21, 2005 01:54am | #5
    What Shacko said, unless you are also able to peel an apple with one hand while the apple is in your hip pocket.
    You need access to check for leaks if nothing else.
    There is a special wrench which does a great job for removing the old drain - looks like a small dumbell with a cross in each end to fit different sized drains - turns with a ratchet. Local big box may have them - cheap and handy.
    Luck.
    Jim
