Baulister Spacing
MrSQL | Posted in General Discussion on February 18, 2010 02:36am
I had an excerpt downloaded from the internet regarding baluster spacing.
It said for balcony baluster, they had to be 4″ apart or less.
For the stairs themselves, it said they could be 4 3/8″ apart.
Do you know what code is for baluster spacing on the stairs (4″ or 4 3/8″)?
It makes the difference of needing 3 iron balusters or only 2 on each step.
thanks,
Roger (AKA Mr SQL)
    MrSQL | Feb 18, 2010 05:15pm | #1
    bump
    1. AGRACE | Feb 18, 2010 06:04pm | #2
      in my area code states that a 4" sphere can't pass through any part of the ballustrade. there are different height requirements between the landing and the stair rail here.
  2. Snort | Feb 18, 2010 07:15pm | #3
    Roger, I'm in NC, also. For meeting code, I have never seen anything other than a 4" or less spacing on any kind of vertical balusters... never trust anything you read on the interenet, ha!
  3. MGMaxwell | Feb 21, 2010 11:02am | #4
    Perhaps the 4 3/8 was referring to spacing on center of balusters which then accounting for the diameter of the balusters themselves would leave you with 4 inches between them. Though that would indicate really slim balusters.
    Just take a toddler and see if you can jam his head between them and you should be good to go :).
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
